25
Everything posted by nipper
Lifetime warrenties are a safe bet on the autopart sellers part. Most parts are not replaced more then once in a cars life time (water pump, alt, master cylinder, etc). the other gamble is that the owner of the car wont have the reciept anymore. So they get to charge more for the lifetime warrenty part, which usually is not rebuilt to any different standard then the non lifetime part (keeping in mind that there is no defanition of what rebuilt part is). you screwed up their business model. how dare you nipper
Any trnasmission from 1985 is a very differnt creature from a 1993. You have a computer controlled transmission with several davantages over anything pre 1990. -1 less moving parts then an older transmission -2 Better engine integration with the transmission operation -3 Faster shifts The older trannies would use accumulators and other forms fo hydraulic buffeing to smooth out shifts. They would not cut back engine power during upshifts, so there is alot of heat generated and wear. Computer controlled engines reduce engine torque momentarily to take the strain off the transmission while shifting. This is a huge wear saver. Also with a computer controleed they can engage two gears at once during an upshift as opposed to the older ones which could not (due to valve body limitations). This also saves alot of wear on the tranny. You can see over 200,000, possibly 300,000 miles on a subaru tranny as long as you regularly change the lubricant, and dont ignore any tranny warning lights. nipper
Here is an idea. Fill the tank with gasoline. Since you have a guy that does work, he sould have an exhaust sniffer. This sniffs for hydrocarbons. Using the sniffer under the car, sniff around the tank, the filer neck, inside the areas under the access panels. When the meter spikes, thats where your problem is. nipper
Thats almost unheard of for both (diferentials) of them to go bad. That can happen by way of the car being abused, low lubricant, or really bad torque bind. This is something that subaru can't be blamed for, but the previous owner can. You spent 6000 canadian (which is 6000 us i think) for the car, its worth fixing. You can get parts for it used. Get another opinion, and ask them how they came to that conclusion. nipper
Or take a lesson from VW nipper
Also a new ground from the tranny to the battery may help. Blu has always had a hard 1-2 shift under most cricumstances, and he's got 220,000 miles on him, so i consider it normal. A too soft shift is very bad. SUbarus have a little bit of an odd shift feeling to them, it takes a little getting used to. nipper
YOU DO NOT NEED A CAT! i will beat that into you using a VW fan belt if i have too You are not listening to us at all. The dealer sounds like a bad place to deal with. If your not overheating or leaking, lest skip the headgasket for now and take things one step at a time. Go to a subaru supplier on line, and order the front O2 sensor and install it. Untill you do that, you can not tell anything else. A bad knock sensor can make the car run poorly You can replace both things yourself failry easily. now listen to us on this, we are trying to save you a ton of money nipper
Been there done it from Chicago to Pittsburgh. Baby the car and dont push the speed. Be prepared to have to replace the wheel bearing, hub as well as the driveshaft. In my case we woulcdnt tell what failed first, but we think it was the CV joint. It took the wheel bearing due to vibrations, then the hub followed. It was really bad by the time i got it to a shop, the only thing holding the wheel on was the axle nut. Personally I would say try to fix it where you are. that drive was not only physicaly uncomfortable, but left a huge knot in my stomach for 8 hours. nipper
Wow slow down. If you take a car to shop with one complaint, and they find 4 others, its time to find a nother shop. Lets take this one at a time. Was the car overheating? Are there bubbles in the coolant. Oil Leaks - Wash the engine and drive the car for a week, then look. I bet the cam and main seals (and maybe the oil pump seal) is leaking. this is not unusual at this age. They should have been done with the timing belt. The rear main seal rarely goes bad, thats why its a safe assumption on the plate, but if the front seals are leaking bad enough, it can look like the rear is leaking. Cats - if you do not have a CEL, the cats are fine (lets assume). If you do have a CEL you start off by replacing the front O2 sensor. You can get a false bad cat code if the o2 sensors are bad. The front sensor needs to be OE. Hit the cats with your hand. If they dont rattle, they are probably ok. Trnasmissions rarely go bad on subarus, but 2000's do have a delay issue when shifting from r to d. I think someone said an additive fixes this (someone wiil chime in). Read the codes. I doubt the cats are bad. A lot of dealers and shops. come to this very wrong conclusion. Forget everything the dealer said, and start all over. Sounds more like the dealer just did not want to work on the car. I am assuming the car has been taken care of and not abused. nipper
Do not leave the car with them. Drag a tech out (not the service writer) and have them listen to the car, and show it to them. Let them hear it. Service writers mostly don't know anything about cars (I was one, and was shocked that they didnt know a thing). Bravo for subaru telling you to get a second opinion. nipper
