nipper
    25
Everything posted by nipper
  1. Thats normal. It helps defog the window. nipper
  2. Have the system tested, then price an ALT at one of the on line suppliers. Check all your engine grounds also. nipper
  3. There arent many things that go wrong with a tranny thats cheap. Hopefully this is just a bad inhibitor switch. Sounds like the switch is borderline or needs adjustment, along with the linkage. nipper
  4. no, its purpously doing it to mock you hehehe its working as its supposed to nipper
  5. A few more thoughts: Lazy Thermostat Lazy O2 sensor bad knock sensor lazy Engine temp sensor nipper
  6. Can we try something basic? Get yourself a vacum gauge and tell us what it reads. I think this car sat in water for a while. nipper
  7. your hoping for the best, but its something else. With a sudden no warning failure, i would suspect either the Torque converter, or the front pump went out. Without either your not going anywhere. Anything else would have given you warning signs. Drop the pan and see what if any horrible things are in it. nipper
  8. 10% gasahol isnt going to do a thing, especially in NY, as its been here since the 1980's. So thats not a valid reason. Your supposed to get 20/27, so 23 is a little low. Now that 23 is at the old test method of 55 mph. Thats note #1. #2 is tire pressure and brand make a differnce. The higher mileage rated tire, the harder the rubber, the less rolling resistance. Your right foot is huge reason for gas mileage, you may need to retrain it. A scantool or a mechanical vac gauge will help with that. We have also changed to winter blend fuel (nov 1) and if you have had cold weather, your mielage will be lower. nipper
  9. any postion sesnor you arent really loking for resistamnce, your looking for an AC heartbeat. YOu need to go one full cycle and make sure all the teeth are read by the sensor. Its not unheard of to have a tooth break off. nipper
  10. Do you hear the fuel injectors clicking (how do you know you have plenty of fuel). Crank sensor is spark, cam is fuel timing. Double check your timing belt marks. Check the cam and crank sensors for proper heartbeats in one full turn of the crankshaft. Check compression. Check the engine temp sensor. nipper
  11. The heated switch is illuminated with the parking/head lights. There is supposed to be two bulbs in the switch, not one. One is on an extension. The remote window switch is not. The heated mirror illumnates when it is on with a little orange telltail. nipper
  12. Will be interesting to se how this engine ages, since you already have 105K on it. nipper
  13. The newer car was a different animal. Thgis one may be as simple as getting a brand new ignition key made from the Vin number then a new cylinder. nipper
  14. for the shifter bulb, it might put up a huge fight to get it out of the socket. Just wanted to warn you. nipper
  15. It's dying, its hurt and fading fast, poor thing. But seriously www.cars101.com will explain. Its the alarm that needs to be reset, if the 4 ways arent on. nipper
  16. IF you have OE wires, yes you should look at that possability. Something else to try, swap wires from 2-4 to 1-3 and see if the miss moves
  17. It shuts off #1 cylinder. Your over thinking what im saying. Its a physical hairline crack in the coil tower. Another test. With the engine running, wet the coil, wires, with a mist of water. This is best done in the evening. Look for blue sparks. nipper
  18. Your best solution is just another set of valve cover gaskets. nipper
  19. Would be interesting to see what happens to #4 Could be as simple as a cracked coil tower. nipper
  20. ME ME ME ME please Just one nipper
  21. Lets try basics. With the engine running, remove one spark plug at a time. Does the miss go away? this will tell us if its a single cylinder issue or a floating issue. nipper
  22. If it is an alt, buy one from OE, as they have been cheap enough of late from the on-line suppliers. nipper
  23. Have you done the basics? new OE wired and plugs? nipper
