25
Everything posted by nipper
Could be as simple as a buggy evap canister or evap hoses (especially if it is only at startup). nipper
wrx crash
nipper replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You need new freinds, or if he keeps this up, he (sadly) may solve that problem for you .... nipper -
wrx crash
What took you so long :-p nipper -
wrx crash
Your really lucky. A car can be deisgned to have the occupants survive an accident, it cant be designed to survive stupidity. nipper -
Any work recently done to the car? Before you do what was suggested, take an ohm meter and see if there is a dead short to ground at the motors. NExt check the relays to see if they are shorted. This is an unusal circumstance, but it sounds like a dead short. There isnt much to the system, so as long as no harnesses are pinched,should be easy to find. nipper
SO if you have flatness gauges that can read in the 1000's and a gauge block then your right. Also the surface finish is critical, and that you can not check on the bench, as its an extreemly fine number. Surface finish is almost more important then flatness. Google "why head gaskets fail" for more info i am unsubscribing from this thread since it seems to be getting no where. nipper
Odd i think the 2.5 is pretty good once it gets off the line. Also remember the ford was Not AWD. You have two drive trains to move, not just one. Thats eats up alot of power. Also the escort is lighter. Its comparing apples an oranges. The most common simple cause for an oil leak is a loose valve cover. The stop leak stuff only works on gaskets that do not seal against anything that rotates. Get the codes read, see what comes up. The problem with subaru oil leaks is that they drip on the exhaust pipes and that smoke gets pulled into the cabin by the HVAC (or anything else that leaks on them for that matter). Another possible leak is power steering fluid. nipper
There in lies the failure. YOU ALWAYS have to have the heads sent out to a shop to at least be checked for flatness (even more important with aluminum heads). Unless you have the proper equipment, its hard to do at your workbench. You should consider yourself lucky that the other two worked, not that this one didnt. Since you never had them checked, i wouldgo ahead and send them to a shop and have them checked. if they are warped, thats why the HG failed. Have them machined and do it again and you should be fine. nipper
Weird "harmonic" vibration in '80 Brat
nipper replied to bratgrl's topic in Historic Subaru Forum: 50's thru 70's
show off nipper -
Its either the U joints in the driveshaft, or the carrier bearing for the driveshaft. It will get more prounounced with time, but also you will find your top speed slowing down due to the vibration. A simple inspection of the joints will tell. nipper -
Two possabilities : 1- The drain hose for the HVAC system is clogged and water form the ac is collecting in the box. 2- Air in the radaitor. Start the car with the cap off. Let ti warm up enough for the car to spit up (thermostat opens) and top off with the car running. Put cap back on and rive around the block. Make sure the overflow is at the middle level, shut off car let cool. Check coolant level when car is cold. nipper
96 outback wagon
nipper replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Car needs to be running to check for Torque bind. Does its start? What condition is it in overall. The engine is a complete unknown, so at 250.00 it would be a buy, maybe. Its hard to buy a aluminum engine car with a blown HG as so many other things can be wrong with the engine. Now if you but it with an engine swap in mind thats a bit different. nipper -
In all AWD subarus the tank is split in two by the driveshaft. This nescetates the dual senders a "jet" pump (fuel siphon). The jet pump siphons the fuel out of one side of the tank to the side with the electric pump. They work in conjunction with each other. You can not use a AWD sender in a 2wd car. nipper
http://www.cars101.com/oldsubaru.html#1985 nipper
