25
Everything posted by nipper
Gas gauge broken...or is it?
nipper replied to Zebisko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The light doesnt work off the float. It has its own sensor. nipper -
pedal vibrates during braking...
nipper replied to mrdeep2001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i wonder how old the hardware is on the rear drums. Springs do get tired after a while and need to be replaced. nipper -
cost vs value. T stat has been around 100 years, and it works and works well, and is dirt cheap to produce. Just because something CAN be computer controlled doesnt mean it should be. As the emissions gets tighter, then yes you will see an all electric cooling system. Thankfully since the idea of a 48 volt electrical system fell flat on its face (for now) we have a reprive, but it is coming. nipper
i never assume anything. It could be as simple as some ice on the wheel or rotor. If it doesnt come back dont worry about it. When was the last time the breaks were done on the car? nipper -
do you have abs? nipper -
But but they dont work ..... nipper
Sadly no. Replacing a front pump is possible, but in the long run a replacement tranny is easier to deal with. the front pump is the heart of the automatic tranny. Take it to an independent shop to have them confirm it since i cant hear the noise from here. I can be wrong. Get a haynes manual , chilton isnt great. nipper
Oil Leak
nipper replied to NewKens1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
if not they sure do before the next timing belt change. You change these seals weather they are leaking or not. nipper
