Everything posted by nipper
Hot Alt!
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWont know till you load test the system. Like i said it may be normal. nipper
Dual battery setups
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2006117/p-2006117/N-111+600010098/c-10107 21.00 plus shipping 70 amps should be fine for what your using the battery for. nipper
So, whats with springs 'settling'?
nipper replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe SS brake lines wont show any differnce today, but it will in a year or two ro longer. As normal break lines start to give a little, yours wont. nipper
rear struts
nipper replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXer um Mouse milk? First off, who would even think of milking a mouse mmmmmmmmmmmmmmmmoooooooooooooooooooooooooooooosqueek? Thats a new one on me nipper
Dual battery setups
I would use a dual battery isolator, This allows for curretn to be pulled from one battery, and cgarges both while running. It wont pull current from the main battery. nipper
Air in Brake line
The seals are tired in that wheel. The are no longer flexable, so they cant adjust to the dimensional change caused by extreeme cold. nipper
Cargo Baskets for the Stock Roof Rack?
HELL YES! I want one too. nipper
Metal in the oil....
Only good way to tell is by an oil anylsis. As long as those chunks arent big and dont look like a gear or a connecting rod don't worry about it. nipper
installed HELLA 500's today
nipper replied to 86ruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi got those too in my album nipper
Hot Alt!
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBatteries it depends on how long you plan ion keeping the car. I always buy the mid priced battery for what ever time ive decided (36/60) i have found 70 month batteries to be planning too far ahead. i avoid walmart brand anything. Sears is good, along with delco and interstate. Altenators are nonly as good as thier rebuilder. nipper
best off-road lights!!**i want pics of your car w/ lights!!!**
i use hellas and they kick but, not only are they long throws but they are wide too. nipper
Flash code P0131 and cruise light flashes
nipper replied to mlebioda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsame thing you should have done the first time, take it to the dealer. The car is still under warrenty, let them figure it out. You may have a lazy 02 sensor, the car may not be warming up properly to make the sensor happy. No one likes to get out of bed when its -5F including cars. nipper
Removing Brake Line from Wheel Cylinder
There is an old tool i use for that. I have a spring loaded plier, resembles a plumber tool that is great for soft nuts. Your going to have to use vice grips, some nut buster, and prbabably will have to replace that line (if your planning on keeping the car till the next break job) nipper
What you think about imprezas?
nipper replied to mrdeep2001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.cars101.com/impreza_archive93_96.html#1993%20impreza Rust isnt really a problem here in the north east as long as the car has seen a car wash and isnt in the rust belt. nipper
2005 3.0 HO Outback Questions
nipper replied to bsevic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeep an ear out for the automatic chain tensioner (yes it has a timing chain). There has been some problems with these, but subaru has a fix. Beleive it or not there are over (are you sitting down) 100 bolts to get to the timing chain. So this is not something you wnat to do yourself. On the bright side the chain is supposed to last the life of the car (which i am assuming to be 200K) Nothing lasts for ever. nipper
Hot Alt!
nipper replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot very. Altenators can get very hot, and thats normal. Yes burning yourself can happen. This come up from time to time. Its NEVER a good ideal to touch ANY part of your engine untill the car cools down. Here is an example http://www.prestolite.com/pgs_products/products_0.php rated for 93 degrees C. remeber 100 C is 212 degrees. I thinkg you can burn yourself at anything over 120 (not sure). Cooking of flesh is not a good way to tell if something is too hot. http://autorepair.about.com/library/a/1h/bl185h.htm I would look at your bettery first. A hot alt (depdning upon what hot is) means the alt is working very hard. If you have the lights on etc, i would expect it to be hot at idle. Batteries can become big resistors at times. regulators can go bad an overcharge as well as underchrage. Get the system checked. nipper
Power Steering Pump Failure??
nipper replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXConsidering how trouble free the PS is normally, i would replace the pump. Sounds like something is wrong inside it nipper
1998 outback purchase
nipper replied to nomoaudi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds fine to me, thats all you do to heads on a "cooked" engine is resurface them. When was the engine replaced? Resurfaced and rebuilt, hell, that can be better then new. nipper
Opinion, plz...
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes things like, was there a swat team involved, did anyone had to make bail, did it make the local news, and the ever popular how many firetrucks showed up. nipper
learning more about Soobs/cars
My father got me started with the Audles book, even at 5 i liked the pictures. Dad was a mechanic in the navy. After that it was every shop calss i could take (except weilding for some reason). I miss that man. nipper
ABS killing battery
nipper replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need an electrical relay (49.00 on subarugenuineparts). Look on the relay and see if there are any markings on it. Sometimes if its marked you can get it from another source. Also a relay is a safe itenm that does not have come from subaru.
Was ac an option for 80' Brat?
a HUGE hole. Releasing refrigerent is not a one to one, or even five to one ratio, its a exponential chain reaction. a FYI, if you see a licensed shop releasing freon into the air, its 10,000$ fine. Gets who gets the procedes of the fine? the person who reports it (or at least thats how it was) http://en.wikipedia.org/wiki/Haloalkane nipper
NE Pine Barrens NJ Runs UPDATED PICS!! and VIDS
There still are, but it requires a state permit, and i have no idea how to get one. There are spots on Jones (Beach) Island, and Robert moses, and out by montauk point. I am sure there are more. nipper
clutch kits on ebay
nipper replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you ever tried driving a stick in bumper to bumper traffic stop and go traffic with no clutch? I did and let me tell you its not doable. I have also had a cable snap in vw during non rush hour, and that was more managable. Things dont break when its convient to you, usually when its inconvient. Better to replace them on your terms. nipper
driving in sand...
Get youtself an air compressor and reduce the tires way down to 15? psi. Also if you get stuck, slightly apply the breaks while giving the car gas. This transfers power to all four wheels at the same time. nipper
