25
Everything posted by nipper
i was talking about the snow silly nipper
Manufacture date from VIN?
nipper replied to CornerHard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try this for a Vehical Identification Number Decoder (sorry it doesnt come with a ring) http://www.cars101.com/subaru/vin.html just for fun http://www.answers.com/topic/subaru-vin-codes hope that helps nipper -
no one likes a show off (still waiting for real snow) nipper
well er um, its summer thats a huge heat exchange rin the front of the car. nipper
If he lived in minnisota or alaska i would agree thats all hes going to get. But i think it s t stata issue of some kind. Not too many things cause over cooling. nipper
Check the thermostat (start car with the radiator cap off, watch the coolant, there should be a burp when the T-stat opens). I know you said you have a new one, but the temp gauge is a dead give away. Also make sure your cooling fans arent on. I bet your gas mileage is down too. nipper
I would go with OE. There is another brand that is recomended, but i forget who they are (someone will chime in). If you go aftermarket google the name. Since your mechanic hasnt done one before, make sure he replaces the throw out bearing clips. That seems to be a trouble spot when people reuse the clips, they have problems not long after. nipper
Actually i was referring to a stuck thermostat. If the car doesnt reach at least (i think) 170 degrees, it stays in open loop. this means the car is running off a program and not the actual value of the sensors. This can lead to dramatically lower gas mileage. A bad temp sesnor would throw a code, or make the car stall. A bad T-stat wont. nipper
I would question the o2 sensor. In modern cars, plugs and wires last about 100k (subaru is way to aggresive at 36k for a tune up). At 100K or there abouts I usually do plugs wires and the o2 sensor (front) if i am having any performance or gas mileage issues. The o2 sensor is the nose of the FI system. If that is lazy, it wont throw a code, but will dump the mileage. One more question, does your car war up properly? nipper
This is a manual. Can be a bad clutch switch, bad neutral saftey switch, or bad starter solenoid contacts, or dirty battery cables. Try cleaning the cables first (how old is the battery). I dont recall if the manual has a NSS or not. If you park the car in gear, try one night leaving it in neutral and see if it starts. nipper
You have a typical subaru oil leak, albeit a little early. On the bright side, you may do a timing belt a little early, but Do the cam main, oil pump seals, timing belt, water pump and tensioner all at once and youll be good for at least another 90K if not 106K. Oil is leaking on the exhaust gasket, and its usually a cam seal. you may have a valve cover leaking, but sometimes tightening them up solves that problem. nipper
