nipper
Everything posted by nipper
  1. 2.5L DOHC engines Blow the HG (internally) 2.5L SOHC engines leak externally Turbos seems fine. from 1997 it seems to 2003. I dont see what the confusion is, i think your over thinking the issue. nipper
  2. Any car with an aluminum engine can blow a HG at any time. Any engine that blows one over 140K is more age related. Use the search, there are some rather extensive threads on this, and one where i explained what the cause is. The only car from the 90's that you can say with any confidence that blows them all the time is a dodge neon (and chrysler wont even give you the time of day). Not all subarus blow HG's. There is no fixed mileage point for it either. Want to get away from blown HG, by a car with a cast iron block and head. nipper
  3. and once you loose steering, you loose control of the vehical. Like i said ABS is there help you maintain control of the car, not stop shorter. nipper
  4. You know all of us have skipped one vital question.... What kind of tires do you have? nipper
  5. Ok then, well i am bowing out of this thread. Good luck with whatever it is your building. nipper
  6. thats ok, there are a lot of days when my hands arent connected to the grey matter either nipper
  7. (its called a tuneup) :-p Yes lots of people have changed PCV valves here. Usually its oil consumption as the reason. nipper
  8. Sure, abandone me, see if i care *sniff* *sniff* nipper
  9. on the bright side, its a 2.2L so they are fairly robust. If you get it all figured out, do an oil, change too. nipper
  10. Are you asking if he gets in touch with his inner headlights? nipper
  11. i think your looking for the word "fork" if you mean the internal part of the tranny that actually engages things. Otherwise you may mean linkage. nipper
  12. http://www.ultimatesubaru.org/forum/showthread.php?t=64761&page=2&highlight=resistor+pack search is a wonderful thing. and i have seen them on the net for about 35.00 new. nipper
  13. The 2003's are suspicous. There have been some leaking Hg on a few of those. A minor tehnicality.. blown HG is internal, leaking HG is external. Once again its about 15% of US cars. nipper
  14. engaging 4wd on a hard clean surface maybe? nipper
  15. You may have to start explaing what a ford falcon is first. nipper
  16. yes but it tends to scare on comming traffic nipper
  17. i was assuming it was the 1981 too. Vacume line would show an even arc of timing change, not a jumping around. Unless he was seeing an even arc and thought it was jumping. nipper
  18. my 1987 GL Hatch D/R 5 speed got a little notchy on the 1-2 shift (it was fine if you didnt shift fast). The D/R worked fine. The car was retired at 180,000 miles due to frame rot. nipper
  19. Get yourself the haynes manual, it covers tranny R and R. I would imagine it takes the better part of a day. Since its a pump failure, check the fluid (when you drain it) for metal. This will help you determine what to do about the Torque Converter. If there is a lot of metal in it you may need to do a flush after the install of the tranny. I am sure someone else will chime in at this point. I havent R and R a transmission in ages. nipper
  20. Well thats what ABS does. It doesnt shorten the stopping distance, and never was meant to (compared to dry). It allows you to maintain control of the car. It also allows for shorter breaking then when the wheels are locked up. The only time that ABS is a negative is unplowed snow or loose dirt/sand. There is a simple way to wire an on off switch, but it sounds to me that it was doing exactly what it was meant to do. ABS doesnt kick in unless the wheels lock up, and from the description you gave, it sounds like they did. Remeber to leave plenty of room between you and the other car, be careful out there folks. nipper
  21. http://www.ultimatesubaru.org/photos/showphoto.php?photo=12863&cat=917 http://www.ultimatesubaru.org/photos/showphoto.php?photo=12862&cat=917 there they are on nipper
  22. I guess im the only one with a rear fog light http://www.ultimatesubaru.org/photos/showphoto.php?photo=12864&cat=917 nipper
  23. It means you need a new distrubutor. nipper
