Everything posted by nipper
Interesting HG info
nipper replied to Ranger83's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmakes perfect sense. i just couldnt figure out the cause and effect. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyour not allowed to play with tools anymore. nipper
90 Legacy Atmospheric Sensor
nipper replied to Richard1296's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDamn its raining torque bind and tranny problems... NO ONE PARK NEAR MY CAR! i dont want it catching whats going around Richard whats your email, i have some info for you nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?p=487134#post487134 look here its tells you how to test the duty c nipper
No CEL when oil pressure sender is disconnected?
nipper replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell indirectly its a big deal. One would like to know when one has low oil pressure. the ecu really could care less if the engine seizes from lack of oil nipper
0-60 time on 93 Legacy Wagon?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnow now be nice, an hour glass will do nipper
Sensor?
nipper replied to George9219's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope. Go to an autzone and have someone read the codes for free nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcause we said so how good are you with electrical testing? nipper
nipper replied to Richard1296's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes explain further nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyuppers nipper
Torque bind problem fixed
nipper replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat i dont know. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsee mountainbiker's post nipper
Floor vent always on and very hot..
nipper replied to sara's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a cable operated door that works the temp. If you look under your glove box towards the center of the car. It is the only cable there. It attaches to a lever. once you find it move your temp setting. if the nothing moves, then the prblem is at the temp control. If the housing moves and cable doesnt, the clip may be broken. You can manually adjust the temp by moving this lever. nipper
1990 Subaru Legacy TCU codes 12 and 24...
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow do you know its functioning properly. It can be stuck open, shorted, or failed. We know its not failed. We dont know about the others i can send you something but i need your email nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXone foot note. the duty c solenoid has to be able to be powered to turn off the AWD. Thats why you cant shut off the awd, the solenoid is burned out. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi hope you read my revised post
Legacy wagon steering problem
nipper replied to volkswoman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave him change it again, as that can cure torque bind 90% of the time, if that is what it is. nipper
torque bind/tranfer clutches...whats the difference?
nipper replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou bought time. The fact that you grind still is not a good thing. Start saving money. Torque bind is very easy to tell. you make a tight turn both forward and reverse, the car should be able to do it without you pushing the pedal, or lightly pushing it. If the TB is heavy, the car wont go without alot of pressure on the gas pedal. Also the car will sort of lurch while making that turn. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX( i do not mean this to sound hostile, i re read it and it did so i changed it a bit) First off i suggested if hes been driving the car like this the damage has been done. The plates get chewed up very quickly when the duty c solenoid fails. Secondly he said that hes not very good with transmissions, and from the sounds of it hes not equiped to do it. Not everyone has a garage or a driveway (i know i dont). When you have heavy torque bind, like i did, and like he does, it means the clutches are gone. If it was light TB then yes by all means just replace the solenoid and see what happens. He also said the fuse is NOT working. The light is on a seperate circuit from the duty c solenoid. If the light was on the same circuit the FWD light would be flashing with the duty cycle of the solenoid. The temp light is blinking 16 times at startup indicating a electrical fault (in this case the duty c solenoid) has failed. He can pull the codes, but the dealership or shop wil do that for him as part of the diagnoses. Also a dealership wont replace the clutches if they arent needed (assuming you found a reliable one). nipper
Thumping on acceleration-Driveshaft?
nipper replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget under the car and shake the driveshaft you have universal joints down there, plus a bearing and a bearing bushing. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive posted my exact cost here on another thread. Mine was 875.00 plus 95 for a busted tranny mount. It took a week as they had to measure the plates then get the parts. 1997 obw. i am very happy with the work. nipper
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXonce the solenoids are freid a flush is a waste of money. That is sort of like chaning the lightbulb because there is a blackout. nipper
Major AWD issue
nipper replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXat that low mileage its safe to just rebuild the AWD unit. nipper
are expensive spark plugs worth it?
nipper replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPS http://www.se-r.net/engine/platinum_copper_ngk.html http://forums.nasioc.com/forums/showthread.php?t=518633 http://www.modularfords.com/forums/2003-2004-mustang-cobra/brusk-plug-spark-pattern-picture-14475-print.html (brings up an excellant photoshop point) once the spark jumps to a ground, its jumped. Thst it, you wont get a multiple path of current. i looked everythwere for a valid test for these things, i cant find one, so im calling it snake oil. nipper
nipper replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlooking at the charts, i dont see much of an increase. Also word to the wise, unless they specify the conditions and engines, fuel and ambient (temp humidity barometer) the test is not valid. Also it takes more thenone test to determine an increase. There is also a correction factor that is required to compensate for change in weather conditions from run to run. Also with such limited increase in performance, if it is a real increase, what works on car a may not work on car b. Also if it was a tue valid test they wuld stae the location of the test, and the calibration date of the dyno, and the brand of dyno. Ive seen this all stated in other performance magazines when they do tests. You need a certin level of increase to get out the "error" zone to make it valid. If i remeber correctly they were sold here as for afew years as oil burning plugs. If you had a tired engine that burned oil, they wouldnt foul (and they worked well that way). Be very leary of dyno tests without the proper given info, otherwise they are just selling snake oil. nipper
