Everything posted by nipper
Waste-Spark Anomaly?
nipper replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX(joke)
nipper replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits the flux generation thing or your flux capacitor is acting up nipper
DIY Struts R&R?
nipper replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow is that odd ..... thats where harbor freight stuff comes from anyway nipper
Running on all...3?
nipper replied to funcle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXor hit road debree, now that we know it all happened at once. Total loss of VSS sensors make the car drive really weird. nipper
Time to part with Outback?
nipper replied to CPAScott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsee ive never had a problem with stop leak, as long as you use it the right way, Put the stuff in the tire and drive the car for a couple of miles to evenly spread it out. I think if you fix the ar youll end up keeping it, so fix it and keep it nipper
nipper replied to CPAScott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see nothing wrong with this car aside from low mileage 1-replace the seals with the timing belt (and waterpump) when you do this is up to you. The interval is 105,000 miles. Whnever you do it it will be good for another 100,000 miles 2-This can happen to any car at any time. 3-I think the wheels can be fixed, but usually a can of stop leak will correct this situation. 4-Depends upon the how the car is driven. It can be 60,000 miles it can be in excess of 140,000 miles. 5-Have an autzone pull the code for free before any more movement on this issue. why replace a HG on a car that doesnt need one, thats foolish. Valve cover gskets are probably just lose bolts. Dont rebuild the caliper replace it, its easier. Low mileage cars will ned work, sometimes more wirk then high mileage cars since they arent driven as much. Fix the car and keep it. Intrest rates are going up, and then there is that new car insurance thing. nipper
Addons to used basic Forester X?
nipper replied to Hank Roberts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeven im thinking of tint on blu nipper
Pulling Driveshaft
take the carrier bearing too if there is one. nipper
AC on 96 legacy 2.5
nipper replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtis ok, sounds like there may be moisture in the system. What does your site glass look like, and what is the temp at the ac vents. nipper
Can't remove key from ignition!!!
nipper replied to justwalkaway's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy do i get this feeling your tool box holds a hammer, vice grips a few srewdrivers a saw and a hot glue gun nipper
nipper replied to Hank Roberts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany generic tranny cooler will work. nipper
nipper replied to Hank Roberts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheheheh like i said, unless a subaru is a wrx , says turbo, or is the only car parked on the block, your fairly safe. And think about this, if they have master keys, what makes you think they dont have a code scanner. Japanese cars are pretty good about key combinations. Now if it was a american mfg then i would worry. My freinds and i had chrysler products, out of 7 mopars in a 8 year spread, four keys would start each others cars, two keys would open the doors. nipper
nipper replied to justwalkaway's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you try jiggling the steering wheel? nipper
OOPS...a question on fuel and AC discharge.
nipper replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk the a/c system, unless your using the compressor leave it alone, Just swing the compressor out of the way. SInce i have an Federal AC license i cannot tell you anything else (doesnt mean no one else can't). WHat ever you do choose to do wear work gloves and goggles, do it someplace with ventilation, as accidents do happen while handling AC systems. Fuel system, ive never really had a problem with pressure in the system when its on a non running car. You have the bigest threat a non issue, a hot exhaust system and engine. You dissconnect it at the fuel filter and you should de pressurize it, as there are no check valves in the system Your going to get a minimal amount of fule out that is pressurized. What prep work are you going to do to the engine before installing it. nipper
1996 2.2L Idle too Fast
nipper replied to larrygs71's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi agree tps may have a short or open when hot in it. get one or three from a yard, as they are really pricey. You can test it, but i think on the bench its going to test fine, as its a hot failure nipper
Installed!! JDM WRX GC8 Rear Wiper Assy!
nipper replied to Subie Gal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat looks great. i always thought the wipers made more snse on sedans the wagons. nipper
90 legacy purge tank selinoid
nipper replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbench test the solenoids with 12 volts, use an ohm meter to make sure they arent shorted or open, or if they are in an easy place to change on the car just swap them, but first at least check with a meter nipper
g/f crashed the impreza today
nipper replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits an honest to goodness explosive that is set off with an electrical charge. nipper
AC Belt Tension nut broke
nipper replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeeek you went to the dealer, thats got to hurt. You nedd several parts then, and i would need to see a schemtaic to tell you what. Would be easier to go to a yard (and much much cheaper) to get one. nipper
TIMING BELTS - '95 Legacy Wagon 90k or 120k?
nipper replied to subiedoobiedoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhats that puddle in your driveway? :-p nipper
nipper replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe only FTW i know is F*** the world. A come-along is a ratcheting winch that is rated for a few 1000 lbs or more. Its a wonderful thing YOu need the air bag and the sensors. the sensors are made for a single use only. They destruct upon impact, so the ABS light will always be on even if you just change the bag. nipper
96 Legacy stalling problem
nipper replied to nebmaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDamn there is a bunch of these. Its the ignitor, it can drive you madd. nipper
nipper replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi could have sworn i answered one just like this before. Its a screw that adjusts the pulley. The screw is porbably frozen where it goes through the pulley Its easier to get the entire part then just the screw off another car, since it is obviously frozen. nipper
1999 Legacy Speedo
nipper replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think in every state you can get a ticket for driving with a broken spedometer. There are these bizzare things called speed limits. They are there for a reason so im told. Something called saftey. Without a spedo you cant safely tell your speed, especially when the usuall limit has been reduced. Then there is the other side, you cant tell when the car is maxed nipper
'96 Outback Knocking Problem
nipper replied to flit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits one of the air door motors that are making the noise. Its cycling cause it cant tell where it is. nipper
