25
Everything posted by nipper
crank angle sensor itself never fails since its in a nice dry happy home, unless the dist beariings go bad then it will just give you an odd idle. Still the ignitor. Try and get them from a scrap yard from a bent car. If the car is straight a bad ignitor may be the reason its there. Otherwise they are a bit pricey nipper
trailer hitches http://www.hitches4less.com/trailer-hitch-classes.html mud guards protect the paint and the cars behind you. security upgrade adds an alarm, but you have to ask yourself, who in thier right mind would steal a forrester. bug deflectors do work but the can also reduce the ventilation in the car. Just means you have to use the fan more. It moves the auir flow up and over the roof and reduces the air pressure pocket at the base of the window. Back window deflector, if you have a rear windsheild wiper, thats good enough. It does help keep it clear, not clean, but adds drag to the car and can slightly lower gas mileage. nipper
For those who have ever wondered what the AWD repair costs Parts were 459,78 Labor was 510.50 The extra part was a tranny mount at 95.00. Surpirsingly they rebuilt a cv joint for 250.00 instaead fo replacing the axle like i thought they would. They said it looked like the tear happened in the last day or two. Bonus was they fixed all my loose heatsheilds for free. When i bought the car the previous owner was quoted 400.00 to replace the heat sheilds. The dealer said they just rewelded them allThey said the car ahs some minor leaks (well duh) but is otherwise in great shape. nipper
your making asumptions - this is a electronics problem. Electronics have wires and solder joints smaller then a human hair. it doesnt take much heat to make them fail. Let the car warm up, ************ it off then try to restart it. Another scenario. Let the car sit in the hot sun for several hours then about 2pm try to start it. nipper
dead spedo is odd on that year. You have two VSS sensors. If one goes bad, the other takes over and the cel wil come on. At this point you will have no AWD so be careful. A dead spedo would mean both are dead. If all these happened at the same time check the wiring to see if anything is damaged. DO you think your running on three cylinders or another issue. CHeck the electrical stuff first. These cars are real dogs on three cylinders so i doubt its that. You dont complain of no acceleration. Pull the codes and let us know. nipper
