25
Everything posted by nipper
hrmmm Hayns manual says zero. Also the way that the sensor opertaes tells me that it should be zero. Its a piezo quartz sensor that generates an ac signal that is sent to the ECU. The strength of this signal depends on how bad the knock. Any path to ground the ac signal would immedialty go to ground and never get to the ecu. im going to have to look at that manual, you have a link? nipper
nope the o2 sensor is in the exhaust pipe. Irt tells the ecu what adjustemnts is has to make in order to have the best combustion. The air flow meter, air sensor, meter (goes by many names) tells the computer the rate of air flow into the engine and its temperiture. 60K is way to soon for an o2 or af sensor. Maybe the knock sensor. The knock sensor adjusts ignition timing and that can cause hesitation. nipper
Radiators for Loyale vs. GL/DL/RX
nipper replied to robm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i use www.radiator.com They are very knowledgable and will answer questions. My last radiator cost 105.00 US for my GL (a few years ago) nipper -
AT Temp light
nipper replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
16 blinks on the temp light means that there is a fault electrically in the transmission and the codes need to be pulled. I am in the same boat, as my duty c solenoid fried , the car goes to the dealer thursday. You need to have this investigated sooner then later. nipper -
you cant do a compression test with a bad timing belt. I doubt you are done as the 2.2 is not an interfernce engine. you need a timing belt. The timing belt controls the valve timing. the valves need to close to make compression. The guy just doesnt want to work on the car. Its very rare for a sooby to just quit and die without doing something else first. Find a new shop or do it yourself. nipper
ok i wasnt sure nipper
