Everything posted by nipper
Vibration when in drive
nipper replied to TurboTbird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need more miles, my 98 leagacy with 178K never did it, and my 97 OBW idles as smooth as glass. nipper
putting seat heaters in 97 legacy
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou mean the heaters are good? nipper
97 legacy wagon. rear wiper relay. Where is it?
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont really know, just remeber it from other threads. You may have to remove the left inside rear panel to find it, unless somone chimes in. nipper
Thermostat or Head Gasket?
YOu can have somone do a due test to find the leak. They but dye in the coolant then use a black light to trace the source. nipper
resealing an ej22. what to replace before install
nipper replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmad at the oil pump (reseal or replace)? Since the engine is out of the car i would do the spark plugs too. Do both main seals. Also replace the tensioner. do cam seals, water pump, the stupid plate if its plastic. nipper
Where did my brake gnome go?
nipper replied to stevecd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNONONONONO Bad Biped no biscuit. NEW hardware. NEW springs and retainers. You may be able to get this from a autoparts store, but you will prbbly have to go to sooby. nipper
air conditioner
nipper replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have 182,000 and it will still freeze you out of the car. nipper
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits buried near the power window antenna (if you have one) on the left rear side of the car nipper
Intermittent headlights on 01 OB
nipper replied to shorinjin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the head light relays, and the plug at the headlight. May need a new pigtail due to corrosion. nipper
New B with 96 Legacy Outback NO start
nipper replied to BP18Protege's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is off by one tooth, it wont start. nipper
nipper replied to TurboTbird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen was the last time this thing had a tune up. i bet from the low mileage the plugs are fouled. if this is all local driving go to a slighty hotter spark plug. Give the car a full tuneup, plugs wires and filters. If your doing maint by the mileage and not by the calender, switch to the calender. This thing is way over due for a tuneup if it hasnt had one and a tranny oil change. nipper
nipper replied to stevecd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you replaced the hardware in the Parking brake (springs and retainers) inside the drum. Hardware gets tired over time and needs to be replaced. Culd be the heat from normal braking is causing the springs to yeild and the shoes to drag. nipper
Head gasket? Radiator? both?
nipper replied to acey doosey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits a HG. Has all the classic signs. Get the exhaust test for the radiator. Also look for bubbles in the coolant. Radiators dont seem to clog up untill higher mileage, and usually only when the AC is on. You can get a raditaor for about 100 i think from raditaor.com. ALso change your oil when you have the HG fixed. Oil isnt keen on being over heated either. nipper
seized engine 98 OBW ... any advice
nipper replied to bearahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi agree. For 3500 you could have got a rebuilt engine installed with a 3 year warrenty. That dealer not only ripped you off, but royally screwed something up. i'm not seeing how the block can be warped but that point is moot. It sounds like they somehow blocked the oil Jounal or debree got in the journal to the camshaft. Usual failure mode after a HG from an engine being baked is a spun connnecting rod bearing. Also i question why you got a valve job, as soobys tend to rarely need one. Something stinks here. Document everything. Take notes, even on phone calls. Get everything in writing. MAYBE you will luck out by dealer #2, but i can tell you myself its hard to diagnose a failure when someone else has taken the failed item apart. Send an oil sample to a company that analyzes oil. They can help rule out causes. Explain to them what happened. Be prepared for a fight. Stand your ground, prepare for a fight. This is defanitly a failure due to oil starvation. An empty crankase makes for a very noisey engine, and wiped out bearings and possibly connecting rods. nipper
no dash lights on 97 legacy wagon
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok i dont feel as bad then. as long as you found the source. My diagram didnt show the relay. nipper
Time for a new car...
nipper replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is one of the things that can cause sway.worn bushings can cause suspension parts to move more then designed. Then add in to the mix alot of cars (including subaru i do beleive) has some sort of passive steeing in the back of the car though wheel movement.add all this together you can get sway. Since everything else checks out, i would inspect ALL bushings front and rear. Bushings are cheap enough to get a pair and replace any in question. Sometimes you cant get a true feeling for them untill you remove them. Some bushings have a steel sleeve inside them and can be a challange to get off. nipper
nipper replied to BP18Protege's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe timing belt? if you truly mean the timing belt itself, i hope you didnt use those "marks". You use the marks on the cams and the crank pully only. And even those can be tough. nipper
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere we go... There is an illumination control module that is the amplifier i was talking about. I would test the stalk by removing the trim on the steering column, dsiconnecting the harness that leads to it (do NOT touch anything if in doubt..as the air bag wiring is stuffed in there too). Airbag wiring is wrapped in colored tape so leave that alone. You have blue/red blk/red brwn/red coming from that rehostate. Using an analog meter, there shold be no opens and values should change as the dimmer is rotated. If that all works out its the illumination control module. nipper
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou dont know untill you try, but i would say at the very least get the under seat wiring, the switches, and the console wiring. Also CHECK to make sure the seat heaters arent electrically open, then its not worth the work. nipper
Main Pully Bearing Lash
nipper replied to akeven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo need for locktite if it is properly torqued. Thats the reason for the torque spec. If its a manual thats one way to do it, have somone stand on the brakes with the car in 5th gear to get rid of the mchanical advantage. There is a access hole in the bell housing for the ignition timing marks. You can lock up the engine there with a heavy screw driver or some other method. SOmone should chime in. nipper
nipper replied to BP18Protege's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes the spark sem like it is happening at the proper time, and is it a strong blue spark. are the injectors firing properly. could be the engine temp sens for the ECU i am assuming you took the engine out to fix the heads, double check all your wiring nipper
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXill let you know after i read the wiring diagram, unless somone else wants to answer nipper
nipper replied to BP18Protege's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need fuel air and spark to run. DOes the car crank DO you have spark DO you have injectors operating DId it run b4 you replaced the HG How many miles on the car nipper
nipper replied to jasonhughes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like the dimmer switch is bad. i dont know if its the switch, or an amplifier hidden someplace. Most stalk controlled items are not directly wired to the circuits as the load is too high. nipper
tire comparison
nipper replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom personal exp i agree 100% except for the french part. nipper
