25
Everything posted by nipper
They will last longer then they say, but they are NOT all weather tires, they barely handle the rain, and forget snow or ice. At the very least put the mini tire on the rear and a good tire on the front. You can get a ticket for driving on the fake tire if the same cop sees you over and over again. Can you at least buy a used tire? nipper
If you want peace of mind, have someone do an exhaust gas test on the cooling system. You can also have them pressure check it to see if you have a leak someplace. Also look for air bubbles in the coolant. Could be as simple as a bad radiator cap. i would replace the cap and see what happens. My gut feeling is that you dont have a headgasket issue, or its just too early to tell. Get yourself a gallon of premixed antifreeze, and have a good and safe trip. nipper
First off the car does not have a transfer case. It has a clutch pack at the end of the transmission (if an automatic), or a viscous coupling with a differnential if its a manual. These systems can go for 100,000's miles with just regular maintanence. These are very robust systems, and you really need to examine WHY its going bad. Are all your tires at the same pressure. Are all your tires of equal wear. The quickest way to kill the AWD is to have mismatched tires. If its an automatic did you check the transmission level. What are the symptons that you have. nipper
HA i got you all beat ..... i may have set a record. Just filed up the car, and i got 10.5 mpg. Of course thats over a month, been driving one trip of 5 miles, and another 0f 2 miles every ther day, and using the remote starter a lot. Normally around town i get 20 mpg. It just goes to show a lot goes into gas milage, not just the car design. nipper
good deal. Too any people rely on the puter to throw a code to tell you whats wrong, when good ol fashioned detective work works best. the puter will only throw a code when the sensor constantly senses something out of range. If it is an intermittant problem, the cel may go on and offf, or never show at all. nipper
maybe the ignitor ...or a postion sensor cam/crank, or ecu engine temp sensor. This sounds like an electronic component issue. I think that these are the only things that can keep the car from starting. Another thing to check is the fuel pump relay, but i think thats a longshot. The ignitor can drive you nutty. Can you rent a code reader from autozine and use it the next time it happens, it should be able to tell what is not working. The computer wont hold a code if the sensor failes, then starts working again. Can you make it happen, so you can test things in your driveway?
warming up?
nipper replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
er um, what does this have to do with this thread nipper -
If the whine gets louder with speed, its your ring gear on your differntial. This is one of those things you can keep driving untill it gets unbarable. i have heard them pass by me at 50' away and be incredibly loud but still work. Once you hear the noise, the damage has already been done. Unless its really bothering you, you can drive it this way for a while. Me i would fix it. Next time you get an noise like this have the oil put through a paint strainer and see what is suspended in the oil. It would have slowed down the oil change, but i bet you would have seen alot moe shiney things then you would at the plug. nipper
warming up?
i disagree. the pump for the transmission is connected to the outside of the torque converter. Whenever the engine is running, the oil in the transmissionis moving. The input shaft of the transmission is connected to the stator, or the guts of the torque converter. This is standard for all automatic transmissions. The oil is not doing any work, but is circulating all the time. This is the same reason you check the tranny fluid level with the car running and not off.. If it wasnt circulating it would be the same as the car is off. nipper -
i go buy the tire pressure marked on the tire if the tires have been replaced with differnt tires then stock. Tires should run at their max pressure when hot (basically if you drive to an airpump they are hot) and checked with major temperature changes. All tires need to be the same circumfrence within 1/4 inch (per subaru). You are correct though. i had an 87 GL that i could shift in and out of 4wd as smooth as silk, unless one tire was a little low on air. nipper
