Everything posted by rallyruss
88 gl dies, restarts, dies, etc.
wow not your average parts swaper.but a scope man. I probably dont need to tell you but the 360 signal is for timing control and the 4 is the actual triger. if you have crappy noise or whatever you see on that signal thats not cool. make sure plug wires and disty wires are not rubbing. did you check the power and groung to the disty?
85 gl wagon problems(long)
spideyz- good to find more bay area subers. sorry but there is no relay. bust out the diagrams. sorry Iluvdrt but your question is a bit long. that may be the problem with responce. if the pump did not do well with direct battery power then I think you may have at least part of the problem found. you should get a decent flow.
87 RX: Tuning Time... AWD or 2wd dyno?
good point about the diff lock strength. may not be worth risking it. DR RX I understand what your saying. I should have been more specific. I mean the flange behind the center support bearing. just disconnect the rear section from the front and let the drive shaft spin in the bearing like usual ok im swingin to the awd dyno side a bit. I still think that 2wd would be possible.
does anyone know what this might be??
you can find a version of that stuff at some parts stores. I personally prefer permatex aviation sealant.
awd vs 2wd dyno. if you unbolt the drive shaft and ran 2wd there would be little to no change in how you tune it. all you need to do is be able to load the motor. it does not care how many tires are spinning. if the guys with the simpler 2wd dyno are better and cheaper I would go to them.
when to bleed master cylinder?
you may need to if you cannot bleed all the air out at the wheels. try gravity bleeding first(add fluid to the MC and let it flow out the bleeder) if that does not do it go to vac. or pump methods. I would save bleeding the MC for last if necessary. it can be messy if you dont have the little adaptors that thread into the ports.
vented vs non vent front rotors?
I would assume the vented rotors are matched to a wider caliper. I know thats how the v dubs are set up and I tink sube is the same. if this is the case yeah you need to get some vented rotors. I think 85 had vented. not to sure about the older ones. brake fluid loss:eek: make sure its not leaking any. it may have just taken alot to fill the calipers?
some rally ???
I cannot say that I have tried removing swaybars on my RX then rallyXing. but it has been recomended to me. the general idea is that a good set of springs will give give you all the stiffness you need yet allow free indepenant travle. at the last RallyX I watched a lot of the really fast cars. they had a lot of body roll happening but the tires were getting grip because they stay on the ground. of course there is a real ballance with the rest of your suspension components but am considering the removal of one or more sway bars. probably the front one.
Engine ping while at highway speeds
yeah I am confused about the EGR too. EGR should reduce cyl. temp and therefore pinging too. try 5deg. my 85 gl would not take any more than 5 deg of advance. seafoam carbon cleaner may be helpfull too.
some rally ???
XSNRG mostly good stuff there but I disagree about the sway bar issue. It is considered a bandaid for poor springs and struts to go bigger with the sway bar. the sway bars actualy keep the tire off the ground thru the rough spots by making the suspension function more like a straight axle. I was lifting tires a bit when I ran and it was sugested by the pro rally guys that I may want to remove my swaybars. not tring to pee on your popsicle but its just what I learned at rally school, the rally pits, and rallyX. hence my board name RallyRuss;) I have to say your mods would be great for auto X
Cali shout out
I know Holister hills verry well. used to wheel my toyota there all the time. dont know how good a sube place it is. I try not to Wheel my sube. thats what the truck does best. I took Donald AKA stormtrooper there once and he had fun beatin on his loyal. what he lacked in vehicle ability he made up in driver ability and persistance. he was a real crowd pleaser. yeah those of you with decent gearing would like it.
How tight is 39 Nm?
I just saw your previous post. I would not bother torquing that one if you dont have a torque wrench handy.If you really want to go for it. you would problaby have to go a little tighter to line up the holes anyway. like the german mechanics would say make it gutentite.
Knocking noise
make sure the tranny mounts are cool. no cracks ect. also the little strut on top of the trans to the body?
how to pack wheel bearings?
the sealed bearings are not meant to be packed. 1 time deal. that does not mean I have not tried to. I ended up injecting some redline synthetic grease into them. because they are a press fit(usually) guess it did not help because the right one is just starting to go.
Vacuum Lines (12/1985 EA-82)
just a guess here but the push button 4wd uses vac solinoids just like that to actuate the diaphram to engauge 4wd. I assume you have a lever actuated 4wd. if this is correct you will not need those. yup I just went out and looked at the car and I have those mounted on the drivers strut tower. there was also someone elses cat sleeping in there. good thing I opened the hood to look first. your question may have saved a cats life.
EA82T starts and then stops immediately
unless you have a internal leak or stuck closed fuel pressure regulator it will run with or without the vac. hose connected. it makes the presure rise a bit. the MAF sensor is what tells the car how much air is coming in. If air is getting in somewhere else it will be confused and not regulate the mixture correctly. important things I would look at. the temp sensor on the manifold. (2 wire) the TPS on the throttle body. make sure the fuel pump is running like sugested. you can check this at the serial monitor connector(13 pin connector) blue with brown wire. make sure all connectors by the battery are hooked up ok to eng. harness. good luck
EA82T Delta cam Q, anyone else experience this?
if the cams are agerssive you will be lacking vacume. that is why you have to keep the idle up. probably to be expected.
arrg!! no heat... brrrrr its cold...
blend door not opening. check the control at the dash first then under the dash you go.
Kill Switch
thats how my old 85 gl was set up. I belive 86 is the same. they just used a transistor in the pcm. I recomend checking a diagram but I 90% sure yous is the same and yeah you use the relay to kill the fuel pump and power it up.
Kill Switch
scooby go out to your car and touch both batt posts at the same time. did you get shocked? hmm work on that fuel pump kill switch idea that would be a good one. and if you use a relay you would actualy improve the system.
Help! I broke my Loyale already!
I would double check the drivers side T belt. pop the cap and see if the rotor spins.
Kill Switch
hmm that good you have more in mind than just that. 12V ? knock you out? 12v wont do squat. you need high voltage and lots of it. then you need to isolate the handle from the rest of the car. well Ill stop now Im sure you have a plan. can someone do a write up on wiring in relays to put in the USMB. It seems this is a mystry area. I know we have covered it a few times but it keeps coming up.
Tappet Rappet
if lifters are noisy then they are probably not opening the valves enough. bet it cant breath. have you resealed the pump yet? that does the trick a lot of the time. it may have pressure but it gets air sucked in at the pump. good to see another local here I am in san jo so if you need help with parts or whatever look me up.
Kill Switch
that cut out sounds like a sweet set up. scooby I hate to tell you but I would be past your toggle switch so fast no mater where you put it. all someone would have to do is jumper right at the starter and down the road you go. to answer your other question. yes you have an electric fuel pump its in the right rear of the car. the wireing is under the carpet on the pass side then up under dash. switches are not meant to carry a large load unless they are a Heavy duty unit. thats why you use a relay. they do the real work carring the amps.
!!BUMP!! Hitachi alt. wont come apart
if you have not ruined the brushes already you will soon. I used to work on alternators a lot. trust me take the pully off. cant you go to a local shop and just ask them nicely to buz it off for you? I just did that last week while I was helping my cousin . his alt. died on him away from home. we just walked into the shop and asked. how long have you been messing with it? man if I did not have the right tools I would just get a reman unit. good luck
