montana tom
12
Everything posted by montana tom
96 2.2 best engine subi has made. Completely non interference. Buy a complete exody or luk clutch kit ,with new pilet bearing, throwout bearing,pressure plate/ disk and an alignment tool. question 1) yes, do it now or you will destroy the flywheel . 2) Take photos with your phone at each step, place parts together that go together. 3) avoid forcing the engine back in on reinstall ... if the clutch isn't lined up... pull it out and try again.4)This is one of the easiest subis to pull.5) No !!! leave head gaskets alone, thats more than you need to tackle, and that motor does not have the head gasket issues that the newer ones do.
- 20 replies
- 1
- Clutch Slipping
- clutch
(and 2 more)
Tagged with:
Well if you were a car guy, I would say fold the liner back ... take a hammer and correct size beater , tap that thin sheet metal back and push the liner back in. If necessary a screw or zip tie to keep it there. Since you are not, I would look for that non dealer subaru mechanic. As long as you are not worried about ascetics he should be able to tap it back . If not don't worry about it until you can get to town.
rpm see saw
montana tom replied to MrB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
cts, is coolant temp sensor, dbw, is drive by wire(electric signal only, no cable from pedal to throttle body). Cruise will flash (and not work) anytime check engine light pops on. You need to have the codes read (most parts houses ) and see what that tells us. -
fyi; The newest gates kits now have partial china sourced parts. Not all do, but enough that you must look at each bearing & the belt to confirm country of origin. Amazon will tell you they are all japan parts... they may not be. With an interference motor be very sure of your parts. By the way I think that the crank keyway should be down when crank is proper for checking timing, but I go by the timing marks not the key.
Code 22 ? I have never heard of. Have you changed the coolant temp sensor ? Bad mileage is a symptom of the computer not knowing how cold or hot the engine is. Located on the water jacket, pass side behind the intake manifold , Has a brown 3 wire connector. One wire controls the temp gauge in the car the other two inform the computer what temp the engine is running.
They all eventually fail... but leak externally. Slow coolant and oil drips that find their way onto the exhaust and smell. You can live with this a long time, as long as you keep the coolant / oil topped up and don't mind the smell. However if he doesn't keep the fluids topped, it will overheat and need head gaskets and... that is also the main cause of rod bearings going out. On this particular car I would confirm the timing belt job included all rollers and that quality japan parts were used.+
Looks like a clean car , although I think that 3500 is high for a car that is needing tires and will need head gaskets within 30,000 or so miles. I would offer 2500 to 3000 for it. I should also add that in my opinion sedans do not handle the snow & ice as well as the wagon does..... I'm sure there are others who prefer a sedan over a wagon.
A good tune up never hurts. Is it cranking but not firing ? When its 10 below zero mine might start and die on the first try and then start and run rough for 30 seconds or so. Now my 94 2.2 with 300,000+ on it , takes a little longer ... might even need a jump... of course the battery is 7 years or more, old amazing it works at all below zero. Your in southern fairfield county it almost never gets near zero there.
I can't think of any fuel lines on the passenger side of an american car ? But disconnect the line that comes from the center of the fuel filter at the intake, (should be the top one) turn on key and fuel should come out. If not ,then most likely the fuel pump . You haven't mentioned code reading... any codes stored could point you in the right direction. As far as buying lots of parts... fuel pump is costly but can be stored if you don't need it. fuel filter is always a good idea, buy 2 put one on and one on the shelf. Crank sensor I would wait on , same with fuel pump relay. The temp sensor I like to keep on the shelf as its quite easy to bump one when pulling the intake and that old plastic likes to break. While it crosses my mind its not like -20 outside is it ? Deep cold does strange things to metal and plastic and our wonderful ethanol fuel they sell is known for not liking sub zero weather. Could be froze fuel lines ??
