TheSubaruJunkie
Everything posted by TheSubaruJunkie
  1. Anyone know off the top of their head what the thread pitch for the water temp sending unit on our EA82's are? Im going to be replacing the gauges with new, mechanical gauges and Napa lists like 4 different units. Im not sure which one i need. -Brian
  2. Are you guys talking about a head gasket kit? or a complete engine gasket kit? I priced complete engine gasket kits. Head gasket kits will be missing oil pan, water pump & oil pump gaskets. Along with the valve guides and whatnot. -Brian
  3. Yeah someone has already found your webpage and we've seen this car before. Its a pretty impressive little hatch. What have you done to make all that power? Here's the thread we have of you from the past: http://www.ultimatesubaru.org/forum/showthread.php?t=46392 Welcome to the board! -Brian
  4. You can see it in this picture here: http://gallery.usmb.net/albums/album42/DSC00641.sized.jpg Its located in the block, behind your intake manifold. In this picture, its the little green thingy right above the hole in the block. Your block shouldnt have a hole like this, but you should have a knock sensor there. It maybe easier to get to if you remove the PCV hose from the block. You can follow the wire to the Knock sensor. The plug is tricky to remove, but once you do its easy to remove the knock sensor. -Brian
  5. Yeah Patrick, and I photoshopped this one as well : That was the 1st time I had ever torn an engine apart. I did it about 3 years ago and havent had to do it since. Now im up against the RX and will be doing the same thing as soon as I get a replacement block. I find it best to buy an engine gasket kit. Napa said they could get them for around $200. I opted for the SOA Kit, and was told it was the last in the US (sorry ) Timing belt kits are going for around $70 on ebay, just got a set and they look pretty good. Idlers and all. -Brian
  6. I'd drain the oil 1st and see just how bad it really is. Ive seen milkshake on my oil cap before due to bad PCV but not on the dipstick. Subarian is right, the dipstick should be overfull if the mix is really bad. If you goto drain it and it does this: Then yeah, you probably have a problem. The above picture was from an EA81 I got with bad headgaskets. Prev owner drove it for a couple months until it wouldnt turn over anymore. Took about 10 days to teardown and put back together with all new gaskets. Thats including waiting 3 days for the machine shop to finish my heads, and working only 2-3hrs a day after work. -Brian
  7. Its okay, i understood what you were saying. Something about going through 3 blocks cause you like to blow up subaru engines (sick and twisted bastard you are). -Brian
  8. Yeah my radiator is a new 2 row. I think im gonna do it. Just gotta find the right block. -Brian
  9. You look new. In fact, under your nickname it sais your new as well. Im glad you spoke up. Now I know not to run 15psi through my motor. Im okay with stock boost, i was happy with 10psi but shortly thereafter is when my engine started to burn a massive amount of oil. And then not long after that is when the block went. -Brian
  10. Thanks. Im going to have to find someplace to rebuild my heads and machine them. Im wondering if they can take the heads from the MPFI XT and tap that port in the 1/3 head. -Brian
  11. Ok so this would be like putting a turbo on a standard MPFI engine then. Here's another question? Can i make the VF7 produce LESS than 7psi (what the wastegate is set at). This would be for long hauls, 300 or 400 mile round trips to Reno. Also, it wouldnt be hard to drill through the block to insert a PCV port would it? -Brian
  12. Well sorry but I cant wait for you I gotta get this engine put together. I was thinking to myself earlier and I wondered if the EA82T heads are the same as MPFI? Would having a 9.5:1 block be like having a standard MPFI engine... meaning i wouldnt even need the turbo anyway? -Brian
  13. I came home today to find my gasket kit waiting for me on the doorstep. So now all i need is a block and im set (hopefully i dont need new heads). Im leaning toward the carbbed block. Nothing ive read has convinced me otherwise. This weekend is the weekend to look, who wants to go to the junkyards with me? (Sacramento, then Reno NV if i cant find what I need). -Brian
  14. Cummon, speak up! Who else is out there? Could use your replies here: http://www.ultimatesubaru.org/forum/showthread.php?t=48312 -Brian
  15. Make sure you get the lug nuts from the Peugeot as well. Stock Subie lugs wont work at all. 205/55R15 should work. I ran 195/50R15's and it worked out really well, until i lowered my car. A stock EA82 shouldnt have any problems with the setup your looking at. -Brian
  16. The last 4" Lift I helped install was made from aluminum blocks. We put it in Jibs Brat... installation wasnt as smooth as the steel lift I had, but it worked just as well. -Brian
  17. Nope... neither is the hub. But, front hubs are the same across all EA82 model lines. Rear hubs will need to come from another EA82 with rear disks (any turbo or GL10). -Brian
  18. Also Zap... here's a page i made quite some time ago with all the different guards offered for subaru. Of course, this was like 3-4years ago so there are no custom jobs. Feel free to rob the information and pictures if you'd like: http://subaru4wd.usmb.net/Jan2002/aftermarket/guards.html -Brian
  19. Never got a scoop. I will have the intercooler on the new setup for sure with better air flow. I know all the logistics about turbo's and lower compression engines, and why they need lower compression. HOWEVER... There seems to be a handfull of people on the board who have done the swap successfully. None of them have reported premature engine failure, at least I dont think they have (part of the reason for this post). As far as the PCV stuff.... i dont care about the vent in the block. The bung for the knock sensor is there and tapped already, so it will work. I was going to completly re-do the PCV stuff anyhow, try to keep blowby out of the intake at all costs. Thats a completely different post due in its own time... i just wanna get a running motor 1st. Who else is running high comp pistons? Will... JWX?? I know theres more than just caleb out there. -Brian
  20. Anybody else running a 9.5:1 block on their turbo? Need some more input. -Brian
  21. Thanks hoopty... but that helps me none. -Brian
  22. Cause carburated EA82's are gutless and weak. Primarily owned by older women drivers who dont go past 70mph. I also doubt the Carbbed motors are prone to cyl #3 failure like the EA82T guys seem to have. Head gasket failure, rod bearing failure etc... And caleb is correct. The only part of a carburated engine i'll be using is the block, I will need to use my MPFI heads and all my turbo gear (manifold, intake etc...) Caleb, how many miles do you have on your motor? Is it your daily driver? -Brian
  23. I guess what im really affraid is doing the Carb block with higher compression and then blowing the car up again in a couple months. Or not doing it, using a low compression block and always wondering "What if...?" My car could use some low end power, and I guess i could stick with stock boost. -Brian
