Everything posted by TheSubaruJunkie
WOO!!! The Lift is here!!!!!! (Now with Pics!!)
My front strut extensions were marked for left/right and had arrows pointing to the front of the car so you knew which way they went in. But its not a AA lift. -Brian
Is Justy really Swift?
Dont really see a reason why not. I know of people who have turbo'd a justy, and I know of someone who is planning to supercharge theirs. Ive been thinking more and more about getting one. They're all over craigslist but I havent found the one I want. Which would be a 5spd 4WD MPFI model. -Brian
WOOOT!!!! GOOGLE FTW!!!!!! -Brian
You must not have looked very hard Will. Search google for keywords "SUBARU JUSTY SUZUKI" PROOF: http://www.answers.com/topic/subaru-justy -Brian
I believe you just... dont know what your talkin about :-p Believe us... it is. -Brian
disconnecting 4wd
Cut the button out for 4WD. They'll know your not using 4WD cause you'll be spinning out everywhere. If you want to have even MORE fun... then remove the front cvs joints and run with it in 4WD making it a true RWD car. Also, weld the rear diff before you do so you have RWD and POSI.... then KILLLLLLL ESCORTS!! -Brian
confused - FWD fuse hows it work?
TheSubaruJunkie replied to S13/R32's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy '92 Legacy Turbo had a fuse in its block... but no FWD light on and I know it was in AWD due to AWD Burnouts. My '87 RX has a fuse in its block... and i know its not in FWD mode as well (wheelin trip, 1 wheel in the air rear locker worked like a charm). -Brian
The motor is suzuki... The drivetrain is subaru and same with the body. -Brian
Sorry, i knew there were no EA82 Brats but I guess I didnt read the entire thread. Thanks for clarifying. -Brian
Rapid Fire Noise **FIXED*
Possbilty a CV joint. Do you feel any vibration or clunk in the car anywhere? -Brian
Any peeps with AA lifts get alignments yet?
I think they're talking about camber problems. Our subarus dont have adjustable camber, and unless AA's lift incorporates an adjustment for the camber I doubt an alignment shop will be able to help... Now if your car is pulling to the left then thats something an alignment shop can fix. -Brian
is this an ea81 or ea82 lift? Did AA fix their horrible camber problems? -Brian
need some input???? " Fixed"!!!!!
Start with the timing. I believe you'll want it near 12 degrees if your car is naturally aspirated. if its not that then check with your pcv system. -brian
Calling Mudrat
i take it he didnt call? -Brian
No clutch lockout?
e-brake... -Brian
Who's running 9.5:1 pistons on their EA82T?
I was watching that acetone thread. I think i heard ppl say that solved detonation problems. -Brian
I plan on running stock boost on the stock VF7 with my Saab 900 IC. I was thinking of upgrading to a larger intercooler for better cooling, but for now what I have will have to work. -Brian
RX 2.5" exhaust no muffs...loud!
I suspect my sound will change when i put my 2.5" catless downpipe in. The Stock downpipe is on there right now with 2.5" welded to the end of the downpipe, going to a high flow cat and 2.5" to the end of the car. -Brian
Jeff how are their cars running? I just got my block yesterday. it came from a SPFI in a 1992 Loyale. Block looks great, hope it lasts a while. -Brian
I have 2.5" exhaust with no muffler and its not that loud. Of course, I do have 2 cats still. -Brian
Got my new block... the verdict is in!
Ive had better scores in my day of junkyardin... all different stories for a different day. Here is a pic of the 1/3 side of the block, with the scratches in cyl #1. May not be 56k friendly http://gallery.usmb.net/albums/album43/DSC00668.jpg Also, the surface of the pistons appear to be really filty. Anyhow, here's a good shot of the block: The oil you see is from the power steering pump when we removed all the hoses. On the bellhousing there is a sticker with a barcode and a number on it. Starts with EA82 too. Backside looks just as good: I gotta get my heads cleaned and resurfaced and then I can start to reasemble the motor. I plan on dressing the block up alittle -Brian
Complete motor would probably be between 150-180 depending on who rung you up. We removed everything but the water pump and the oil pump. They looked new as well. When i got to the counter I told the lady it was an engine block (we had it in the wheelbarrow with our toolboxes around it). She was confused cause it still had the bell housing on it and thought it was a transmission. Then i think she saw the cylinders and realized what it was. Anyhow, she rung it up for $89 and she said the timing belt cover i had in the wheelbarrow was free If i would have known she was so laid back I would have grabbed all the PCV hoses... they looked brand new. -Brian
Well.... I opted for the high compression block. I arived in Reno at 10am and met up with Subieman, then we started looking at what the PnP there had to offer. Found a few turbo motors, but the lowest milage was 105k in a pretty beat up black RX. Then I decided to see what SPFI and MPFI engines I could find. I started looking for the newest EA82 and then we found it... It was a 1992 Loyale, 3spd Auto 2WD Sedan. Had been rear ended. The odo had 150k on the clock, but the interior was IMMACULATE! The coin tray was removed from the center console, and there wasnt a spec of dirt or lint or anything under the tray. The seats, carpet and dash was spotless. So i popped the hood and found a SPFI engine that was so clean I could almost see my reflection in it. So we decided to yank it. I was shocked when we removed the timing belt cover. SOA belts that were clean enough to eat off of. WOW i said. I sure hope the rings are still good. We pulled the heads and inspected the block. Crosshatch marks were apparent but Cyl #1 had some slight scoring on the sleeve. I brushed my fingers across the score marks and you could tell something had scratched the sleeve pretty good. I dont know if I should be worried or not about it. I will get some pix when I have the block up on the bench. I have a hard time believing this motor has 150k on it, since there were some stickers on the block like it had been recently purchased. But the car was so clean I guess it could be the original motor. We'll see what happens when i slap some turbo heads on it and get it runnin. -Brian
holy buckets Jamie or (subarugenuineparts.com) ships fast
Yeah she did a GREAT job on helping me get my EA82 gasket set. I couldnt have been happier. Did your timing belt set come with idlers and pulleys? If so Im kickin myself cause I bought my set on eBay for $70. -Brian
Mark your calendars: SubieFest 06
How about some dirt? Or is this 100% tarmac? -Brian
