Everything posted by Scott in Bellingham
Wheeling in oregon callout
good Ill just camp at your house
sjr 4" lift question
my 4" kit comes with all the blocks , everything is dropped axles will only be 1" stressed over stock,
R180 3.9 Diff needed , what interchanges?
got a Nissan 720 diff bolted into my wheeler, I need to go 3.9 as its a 4.38, what will fit? is the wrx diffs and gears the same as in the nissan 720 4x4 front diff?
Walker Valley Feb 4 midday anyone?
Walker Valley anyone Friday 4th mid day?
Pics From 01/29/2011 Walker NWWO
Just WOW never seen a control arm break, seeen em bend but WOW was it a little rusty or ??? Swampers, were they the Best ? or ?
I plan on a Oregon trip this summer maybe a overniter
Lug adapters for 5x100 hubs
looks like hats a 27.1 in tall tire, I ran some aftermarket wheels , thats what I suggest heres some 225/75-15s
ej lift question
on my 4" EJ kit everythings at 3" except the struts are at 4"
New Tires............. Swampers!!!!
cut radius rod in half slip pipe over and weld pipe to shaft
NWWO Jan 22nd Run to Walker Birthday runs!!! Pics at the End Post!!!!!!!!!!!!
] yep ORV park run by DNR
I have 31s on the front of the 5 door white wheeler , I extended the radius rod 1" helped a bunch,
suspension bolts?
12mm x 1.25 -30mm bolts for the radius rods, tranny mount and rear torsion tube, will need 10 with nuts as the rear torsion tube uses longer bolts so keep them on the tube and use the 30mm on the body 10mm x 1.25 -30mm bolts for the front struts, front engine crossmember and the mustache bar , will also need 12 I have all bolts and nuts in stock if you want to buy from me, PM me if you like Scott
Awesome you wont regret it , 31s !!!!!! thats great :brow:
I Wont be there
Lifted Justy
I make lift kits , if theres enough interest I could make a kit
will a 2.5 bolt up into a 2.2 car?
I shoulod of known thanks dude
thanks so a guy with a 2.5 can use my EJ adapter and bolt up a EA82 Dualrange, nother Question are the bolt pattern on the flywheels the same?
is the engine bolt pattern the same on the 2.2. and the 2.5 ?
loyale rear lift
sawzall, also will need to drop the diff
Back to the old school. 01 EJ swap lovin.
Adapters on the way UPS should see it tomarrow , what will you do for the Redrilled Flywheel ?
Thinking about going solid axle
keep us posted
we usually have 1 or 2 jeeps along
Model A Ford Tub Buildup on Postal Jeep Frame and axles
the frame will be reallly low, underslung the axles, the tub will not have doors just jump in over the side, be a fair weather rig no fenders , bare bones, no frills got a 60 Lincoln too, its total rust, may use the rear light, fins and sheetmetal narrowed heres a few from the web
Been thinkin about this build for a while I have a Old Ford I got back when I was 14 its a 30 Ford Model A not much left of it, Im goin to take the windsheild and cowl and make a tub heres a model I mocked up plan to have it up and runnin for the summer, not sure on a moter yet may not be a Subaru, could be the engine from my Dodge Dakota small V-6 we will see i wont be out much, plan on using stuff I have already got a 78 postal Jeep for the frame and axles body comin off stock frame stock postal Jeep spring repacked upsidedown mock up
Lifted Justy
nice Job , so stock gearing with no low range??
