Everything posted by Scott in Bellingham
trying to fund an EJ swap
never had one , not aginst it, would like to know the specs , as long as its a stand alone unit that can play and burn DVDS and can exchange files with my PC , Picture softwere would be nice internet access would be cool too
Laptop computer I can burn and play DVDs on Early ford escort distributer , coil and ignition wiring EA82 4wd flywheels Dual Core EA82 Radiator
WCSS 12 Wheeling
Thanks for showin us ther trails heres a couple pics http://www.ultimatesubaru.org/forum/showthread.php?p=949641#post949641
WCSS12 Liberty Trail Run
Friday evening a few of us went out to Liberty http://www.ultimatesubaru.org/forum/showthread.php?t=114835
WCSS 12 - What YOU need to KNOW
is there a place to wash off your car, say after the mud pit?
Ive done trades for parts , I have the plate and flywheel
WCSS 12 Wheeling
you can always ride with someone,
Few questions about ej22 swap
:lol:
WCSS 12 Update - 1 week and counting!
- SJR 3 Door Coupe GL EA82 Build Thread
sold a car so Im ready to build up another The culpret: I picked up a 86 GL 3DR white Coupe, its a Automatic with a Carbed EA82 1.8 the plan junk the engine and tranny add EJ 2.5 with dual cam heads , all stock wiring and ECU from a 98 Leg Weg add 3.9 Dual Range going with a big lift on this one maybe 6" maybe taller 7 or 8 30-31" tall Mud Terrains Nissan 720 truck front Diff, axles and hubs will replace the rear diff and axles and Hubs , this will give me a stronger rearend and axles and the diff will bolt right in using the stock diff hanger and stock Soobie driveline , also with the rear diff weled I will be able to unlock the rear hubs using the Nissan 720 hubs which also are 6 bolt so I will drill the front hubs to match, this car will become my daily driver and have the EJ 2.5 power to pull a trailer and have some bigger rear discs to stop it, will start the build first with building and installing the lift and pullin the engine and trans, will have Adam at Norhtwest Rally Sports in Bellingham WA wire up the monster engine , Huummmm should I get some Delta cams while Im at it? HhHHhhhhmmmmmmm may be a while before this all starts but Im just excited and wanted to share , been talkin to Adam for a while about the engine, Ive never had a 2.5 befor- WCSS 12 Wheeling
we may come over Thursday , so maybe friday would be a good day, or saturday morning- WCSS 12 Update - 1 week and counting!
Andy would you take me and others on a Tour up there? Scott- W series Toyota trans adaptors
will this be a " one off " or do you plan on building and selling more?- WCCS 12 Site and Location are Set
all right where we gunna go wheelin while were there? would be nice to hit a local wheelin spot, lets get a run organized- WCSS 12 Update - 1 week and counting!
any challeges for the serious offroaders? also any chance camping on Thursday night- Whatcom Skagit Nothern Snohomish Co Convoy to WCSS???
I plan to be on the road early morning- Lifting a ea81
Im asuming on the rear your using 4 indevidular blocks, if so it would be best to tie them together with diaganal stock welded up. Ive seen these blocks bend out the captive body nuts if left single, if its just for a poser your good- 98 Forester when did the rear suspension change ?
thank you , so seams like same time as legacy- 98 Forester when did the rear suspension change ?
I need to know when the rear suspension changed on the Subarus, I think its 99 for the legacys what would it be for the Forester and other styles??- Needing a lift...
stock geometry , on a EA81 I would keep stock axle stress , on a EA82 you can go 1" over without issues , 2" on the front if you really want- GL Sedan the same running gear as GL Wagon?
same , if that sedan has good rear doors/windows I may be interesterd in getting them- 5 speed pushbutton 4wd in a 97 impreza outback?
with a Adapter plate and redrilled frywheel and a modified tranny crossmember and a lengthened driveshaft you could install a EA82 Dual/range its been done a few times- Radiator repair...welding?
if its all copper, then its been soldered , and the solder can be redone, must use flux , solder and heat- Homemade lift tore my axle boots
front or rear? , i would drop the rear diff 1"- Needing a lift...
31" tires, I would go with 27 to 29" for clearence and gearing - SJR 3 Door Coupe GL EA82 Build Thread
