Everything posted by ericem
What?????? fast idle control??? are they talking about the IAC valve?? That is crazy you could have probably just sprayed some throttle body cleaner down the IAC tube and the problem would have been gone. Other thing is vacuum leaks as mentioned. After they replaced it was the problem worse or better? At $500 they better fix it.
Someone on teh board did it. He went to the yard tested it (supposedly) and after putting it all in he starts up the car and once again he found coolant coming out hte vents what a mess I am sure. Eventually he ended up just getting a new heat core. Some tips I think he suggested removing the seats. You need to pull the entire dash. I suggest getting a new core as well. Not worth the hassle of reattempting to do the job.
09 Forester
ericem replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yup I saw it at the auto show as well. I wasn't very pleased to be honest. It was like a mitsubishi with a suzuki rear end. Subaru lost there unique good looking design (IMO). I am sure it will drive well though. -
Hmm. Well verified the problem. Front cv's. They are about to explode lol. One more boot broke on the front and I am guessing it is that one creating the issue. Seemed weird though. Sometimes it sounded like it was coming from the rear. Once my friend in the back verified. There was no noise in the back. I found all the parts I need so I should be good. Reason why it is FWD is, because my transmission is ******* Going to get the new transmission, cv's, and all motor mounts, and rebuild the gaskets on the motor this spring. Should drive like new. All I need then is struts.
Hey. I have a question. Sometimes when you make the slightest adjustment turning right the rear knocks. Not enough though that the suspension would chaange. Not sure what I should do. The rear CV's don't have broken boots. There is 1 CV that is still original in teh back on the right side (car has 307,000km) and there is 1 original bearing in the back as well. What should I look at? Now it is pretty rough just seems like it is soo loud for such a slight adjustment in the steering wheel. The car isn't even working in AWD so the rear wheels aren't being powered.
Thanks guys. I think I will try the method with the wrench extensions. Then try the method with the screw driver before I pull out the motor. How difficult you think it will be to get the tranny engine out together?? I am assuming it is as easy as remove all the engine and tranny mounts bolts and braces. Then remove some connectors. Then I will get my dad to vacuum out the A/C gas if there is any left anyway then he can unplug the A/C line. Remove the rear axle, and undo the pins for the cv's in the front. Is there something else?? Or it just won't be this easy? All I plan on buying is this to work on the motor. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32916 and this to pull the motor. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93840 I already have the toher tools i need. Like impact,torque wrench and socket set.
Hey. Getting ready. Decided were going to fix up our Subaru legacy after all. Also no the head gaskets aren't bad. I found a decent deal got all the CV's, transmission, and a radiator(mine is leaking) for low mileage (under 50k) $500 need to go get them. So far fixed up the rust sanded all the spots and painted it all well. Just need to get the windshield done. So anyway found the engine crane, a engine holder or w/e you want to call it to let me turn the engine upside down, spring compressor, already have impact tools. Now I need to find the tool with 4 bolts that can grab the harmonic pulley. See how it will grab the pulley.
