Everything posted by ericem
wrx crash
ericem replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOL did you guys think you were in the real rally car?
2009 Model Release!!
ericem replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLOL ??????? What SOMEONE ACTUALLY believed those were REAL pics!!!!!!!!
ericem replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hate subaru. j/k just anything that is 2008+
New Plug wires = awesome.
ericem replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon;t forget your plugs people!!!!! I replaced mine, and now my car is so smooth, i payed $1.50 each YES $1.50 each for NGK's.
1993 Legacy L Wagon tire questions
ericem replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi can do 130mph on flat ground without wind :-\ Maybe the auto has better top speed!
2.2 liter legacy burns 2 Xistors HELP!
ericem replied to DTL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy not find one used on ebay? or just go to a junkyard?
Stupid SVX wheels!
ericem replied to wave o babies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat looks hot!
Going to look at another Subie Wed. Night
ericem replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXya!!! ^^^^
Please Help Out a Friend of mine ...
ericem replied to FlyB0y's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe said 5 speed.
93 Legacy: Dead A/C Compressor! HELP!!!
ericem replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwith my 93, my dad used r34B refrigerant, its compatible with r12. Anyway so we filled it up on a cold day, and it was super cold. Waited a day, go out turn on ac and turns on for like a millisecond, then shuts off. Go outside turn the ac and its like impossible to turn. So what we realized was there was to much refrigerant, so we used a recovery tank or whatever its called and took out some refrigerant untill it ran voila! sojust make sure you only fill it on a HOT day, if the compressor isn't under load it will not give u proper readings.
ericem replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdouble post....
Seafoam Carborated?
ericem replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshould be fine using seafoam, says its safe with carbourated and fuel injected. so dump seafoam in the tank and through the carb.
New Subaru?
ericem replied to 2F1R Suby/dub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot neccesarily "new" but cool! saw that a while back, its one fast ATV alright
Spark Plug will loosen but will not come out?
ericem replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm, maybe some of the threads are crossthreaded and now the plug is binded in there. Are u using a proper attachmentt to remove spark plugs, that GRABS the plug, like it has a piece of rubber? maybe u can grab the plug when its loose with pliers but the driver side is kind of difficult.
CNN...... Subaru's do not float well
ericem replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXya! exactly, or he though he could take a "run" at it. and then he said d'oh!
ericem replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi wonder if any water got inside Surprised it died as well. engine air box as above the water, all seals are new, don't see why thye are stopped there.
JDM LEGACY EJ20 TWIN TURBO engine...
ericem replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim sure it can be fit in there somehow, just the steering linkage i heard is a issue.
looking at anouther subaru
ericem replied to Steve455's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo for it thats a awsome deal, even if u need to swap the tranny or change the fluid. Used tranny can run like $500 for a good one which isn't a large price to pay.
How the STI I wanted ended up
ericem replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnow i did. Pretty awful when you hear these stories, they probably would be still alive if they buckled there seat belts.
Can a non oem muffler make MPG alot less?
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks subie94, exactly what i wanted to know!
question about tire pressure!
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm, ok the side wall says 40PSI max. So i did 37 front 35 rear although i didn't follow the ratio of the manufactures pressure, i prefer it like this. Still i don't understand, wouldn't this damage the AWD unit faster?
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi do need to pass or i don't get my sticker and i already pass with flying colours.
Transmission shop recommendations
ericem replied to subieman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suggest you just get a used tranny covered by warrenty, i spent wayyyyy to much on a rebuild and it still doesn't work properly.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, well i set the front tires to 37 exact, and 36 exact in the rear sound fine? see i thought with the AWD system the tires needed to be exactly the same pressure.
ericem replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn top of that the air expands when the wheel is hot, any risk to blowing a tire?
