subarubuddy
Everything posted by subarubuddy
Detroit Lockers, and Subaru's
subarubuddy replied to MoscowSubaruDude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what about locking hubs? if you were to weld the diff but be able to have the rear hubs --or at least of them freewheel then you could drive it on roads and lock the hub for off-road use. may be an more possible than a detriot locker type diff. but i don't know where to get/how to make locking hubs for a subaru. -
3.7 or 3.9 front diff? how do you know?
subarubuddy replied to subarubuddy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes thank you...that is exactly what i need to know!! -
i have a 5-speed dual range tranny already out of a car, but i don't know what car it came from. maybe a turbo maybe not. 85 or later DL/GL(-10)/loyale/turbo(??who knows??) thats all i know about it...so the problem is i have a 3.9:1 open rear diff in my loyale now, and i want to put the d/r tranny in. but how do i even know if it's a 3.7 or 3.9:1 ratio? i don't want to put it in and then tear it apart when i go to see if 4WD works. and obviously it wouldn't help to change the rear diff either because i don't know if i need to. thanks for all your help.
Weight of different car models
subarubuddy replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine says on the door pillar 3400 something. i don't remember exactly. but it is 3400something... that seemed heavy to me but thats what it says. it is a 1992 loyale wagon 5speed 4WD.. -
what about a GL-10??
well i can't tell you for sure, but i have a '92 loyale with the same problem. only i am also not so sure if its supposed to be that way either. i found this post by doing a search because i wanted to find out if it was equipped with both a guage and a light. the guage works but the light does not (if there even is one). i'm starting to think maybe you get either a guage or a light but not both, depending how the car is equipped. But sorry, this probably doesn't really help.
How do 4WD EA82s do in snow autocross?
subarubuddy replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i don't really know for sure. but i'd say the lack of power won't really be an issue so much because you can spin all four wheels in the snow anyway with these cars if you want to. more power won't get you any more traction. so i say go for it! i think rust will be your biggest problem. don't let all that snow and ice sit there stuck in the wheel wells and all that. -
two different mickey mouse gaskets?
ok now we're getting somewhere... thanks for helping -
no both of them are ea82 N.A. the current one is a 92 loyale wagon. and the previous one is a 91 loyale sedan. the 91 was auto. the 92 is a 5speed. both of them are 4wd. i can't figure out how to post a picture of the gaskets here but i got them onto the photo gallery. the photo is named: two different mickey mouse gaskets. sorry but that was the best i could do.. thanks for helping me. -
subarubuddy posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
has anyone else found out the hard way that there's two different mickey mouse gaskets? and is there any way of knowing which one you actually need with out taking the oil pump off? i just found out yesterday that i got the wrong one. it's slightly bigger and it has a flatter part on one side. i told them i had a 91 loyale when i actually have a 92 loyale (i was thinking of my old car) . i realized my mistake but i let it go because i thought they would be the same anyway. does anyone know if they changed that year or if there were two different oil pumps? or maybe there's an aftermarket one on my car already? who knows? -
loyale fuel filter change procedure???
subarubuddy replied to loyalewithcheese's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't get one from autozone. i had three of them leak right at the seam as soon as they were installed. they let me exchange them and i ended up putting an aftermarket one on anyway( also from autozone because they were letting me exchange them since they kept being defective). anyway i put one on that didn't really fit "properly" and that one was fine--same size inlet and outlet as it should be but different shape,so it didn't fit into that clip there. anyway stay away from the autozone ones. even if you eventually get one that works, it won't cost any extra but it still sucks changing those things 4 times in one week! -
you really should releive the pressure first. you'll still spray gas everywhere but not even half as bad.. its very easy to relieve the pressure. there's two very similiar ways: 1. disconnect the plug from the fuel pump (under the car on the right side just in front of the tank) then start the car and run it untill it stalls. then crank it for five seconds or so. thats it! 2. the other way is if you know what fuse is for the fuel pump (i don't remember off-hand) but pull the fuse and do the same thing as i already wrote. -
hi i did a search but i was too stupid and/or lazy to find the info i was looking for.. anyway i was wondering what EA-82 models you could get the LSD on. or if there's an EA81 LSD thats easily interchangable. i'm going to the junkyard this weekend and i'm hoping to find one (yeah i know--fat chance). but it would be good to know which ones to not even bother checking. all i know is to not check the FWD models .and i know the turbo's have a different ratio so i guess thats no good either. or can you just change the pinion and gear from the open diff i already have?
anyone know if new 1st gear set can be made?
subarubuddy replied to Ratty2Austin's topic in Off Road
i had an 1986 tercel wagon with the EL gear... and it was awesome!! (EL in 4wd only...otherwise a 5 speed) -
Need Advice On Clicking Noise
subarubuddy replied to carfreak85's topic in Historic Subaru Forum: 50's thru 70's
I got a set of Timken's from Autozone! works fine -
92 loyale engine question- please help!
subarubuddy replied to cndymyfrnd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Quote: Also, why would bump starting it not work? Quote: Originally Posted by cndymyfrnd But, why would it have "just died" as the prior owner was driving it? bad alternator maybe. that would cause a dead battery and the engine will die. and if theres no power (from the battery or alternator) then it won't run even if you try to push-start it. -
when i got my 91 loyale the CV joints on both axles had been clicking for almost a year. the people i got it from were getting ready to junk it and didn't want to put money into it,then they stopped driving it and it sat for almost 2 years. then they offered it to me for free if i wanted to fix it. the axles clicked nearly all the time even if you were just going around a corner on a road at like 30 or 40 mph. i replaced them right away when i started driving the car. anyway my point is this: they probably won't fail soon.. so save your money for now but replace them as soon as you can.
i think the capacitor would still drain. from what i understand they don't hold a charge all that long anyway. but wouldn't the capacitor drain anyway when you shut off the car??(if the radio is wired as an accesory)... it sucks but the best solution is probably to solve the original problem.
Loyal ignition lock problems
subarubuddy replied to Hayne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it probably is the keys .. when they were copied the burrs may not have been removed well enough.. do they feel or look sharper? or do the ramps look steeper especially on the back side(towards the bow-or handle)? if so the problem is the copied keys. -
Help with 91 loyale 4wd
subarubuddy replied to highopen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
its true..i had a 91 loyale also (automatic though) . it did bind on pavement in 4wd and it NEVER got stuck in the snow. even if i got plowed in to the top of the wheels (rims not the tires). all i had to do was get the snow off the windows and dig out the door so i could get in. then put it in 4wd and that was it. sucked in FWD though, so you should check it out and see if 4wd is actually working right. -
91 Loyale ride height adjust question.
subarubuddy replied to Todd in Seattle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on my 91 loyale theres adjusters at the top of the shocks from what i remember. they adjust the spring preload. theres 3 notches for 3 different heights. its to compensate for worn springs i think. you have to rotate the shock into the notch you need. (i don't know if thats a good enough explanation but maybe somebody else can help too) i think there's only about 1-2 inches of total adjustability though. i don't know if it will make enough difference. but maybe it got new springs and they left it in the "high setting.." -
93 Loyale wont start sometimes
subarubuddy replied to jk4138's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think that happened to me too. (91 loyale-auto) it made a clicking sound from under the dash but after trying to troubleshoot the problem...very poorly i gave up and installed a starter button in the dash. very easy to do and i never had a problem after that. -
92 Loyalle, only 8-9v or so on gauge.....
subarubuddy replied to travis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yup i think so -
Some low-life busted my window
subarubuddy replied to Handtool's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i don't have any now but i know the windows will interchange between loyale and dl/gl cars. i had a loyale sedan. someone broke the front passenger window and i repalced it with one from a gl wagon. don't remember if it was manual tho.
