Everything posted by uniberp
Hard deceleration at 65mph when let off the gas. Transmission?
uniberp replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre your sure your brakes are not dragging badly?
2014 Forester wheel & brake questions
uniberp replied to eyesore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf he needs better wheels and better brakes on a brand new car it probably won't last long enough to make any difference anyhow.
New engine time--what will simply "drop in".
uniberp replied to mcmono50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the 99 forester is Phase II EJ25D - SOHC it should drop right in to replace your EJ251 with no EGR or IAC issues. Maybe someone else can confirm...
Swap axles side to side?
uniberp replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNew brakes since the first occurrence. Tires all new (<10k, rotated at 6k), aligned, since first occurence. I'm hoping it was the slight overfill of the front diff causing a backlash of some kind.
uniberp replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWheel bearings are ok. No runout at all. It happened again coming home on the expressway, a vibration, and when I applied the brakes a rhythmic grinding timed to wheel rotation. This time it seemed to come from the left front, previously I thought it was right. Nothing loose with the axles, at all. I've done many axles on subarus and kinda know this stuff. As I was checking the right front wheel I noticed a little blue plastic cone cap sitting on the control arm edge. It was a cap to a gear oil squeeze bottle. I don't think I ever changed that, but I may have I checked the front diff and it seemed a little overfilled. 30k change recommended, so I did. The oil that came out was cleanish, I'm letting it settle overnight to see if sparkles settle. It scares me when the noise happens, I can feel the grind in the brake pedal, but it self-corrects every time.
uniberp replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hear the rumbling occasionally still, and still it gets corrected with a few low speed tight turns. Kind of a pain when on the expressway. I pulled off this morning and smelled hot boot rubber. Not split or anything, but I noticed the driver's side shaft can wiggle a little along the axis. The passenger side does not. I guess I got a tight or seizing bearing in there, probably heated up. As long as the boot is intact it probably won't catch fire. Factory original axle with 80k miles. At some point it will need attention
Rear wheel bearing replacement 2007 forester
uniberp replied to Georgedean1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, anything but the dealer. I'd try to find a local independent transmission shop and call them. Too many stories about dealers trying to be everything to every car and messing up on the particulars.
Newbie seeking advice on Foresters
uniberp replied to Cheeseburger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXForester is an Impreza. I bought one because the Legacies were getting too big to be pushed (+200lbs) around by the ej25. The 4EAT is as durable a passenger car AWD as I know of, plus it has better AWD. I'd never advise a subaru belt cam engine for a performance nut unless they were ready to swap shortblocks on a regular basis. 4cyl Subarus have lots of underhood space to work. Up to 2010 or so they (all I know), they haven't designed them for ease of initial assembly instead, like so many cars where you are need to drop the subframe to change the starter and crazy things like that.
Rear disc conversion on 95 Legacy.
uniberp replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDrum brakes last a lot longer. They are less susceptible to corrosion, IMO. I've seen several legacy's with very corroded rear discs, partly because they get so much less pressure than the fronts. Myself, I don't need the slight additional braking power or precision of rear discs. My 08 Forester has rear drums.
Rear diff getting hot
uniberp replied to lennie11b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre your tires all the same size?
DIAGNOSE THIS IGNITION PROBLEM PLEASE
uniberp replied to revtim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd say you have 2 choices, either install a cat and put the o2 sensor in or engineer/install an aftermarket injection and ignition system. You're probably wasting a quarter of your gas anyhow.
Donig Rear Wheel Bearings (Lateral Link Bolt)
uniberp replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/topic/145718-stuck-bolt-in-rear-suspension/?p=1224291
Stuck Bolt in rear suspension
uniberp replied to forester2002s's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis isn't pretty, but it can be done. It's impossible to press out the bushing without a press. I cut the hardened bolt head off, it took a couple sawzall blades, found a washer big enough to brace against the rod, backed it up with an open end wrench, and pushed the bolt out with a ballljoint separator. Impact wrenches and hammering are just absorbed by the rubber.
- 17 replies
- rear
- suspension
- stuck
- seized
Tagged with:
2000 Forester dies after approximately 5 miles.
uniberp replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it's an expensive part. Sorry.
pulling steering wheel with airbag?
uniberp replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDisconnect the battery first. It doesn't disable the airbag controller capacitor, but it makes you think about it. Because I'm usually working alone, I never get in the line of fire. I reach in sideways to remove the pad bolts. Store the removed pad away from things. I put it on top of a cabinet. It is an explosive device. The clock spring is an enclosed item as I remember, has a ribbon cable that I doubt can be repaired. Actual symptoms include cruise and horn malfunction.
Wimpy wheels and tires
uniberp replied to Fuzpile's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNarrow tires are better in snow. A smaller contact patch is partly why. The frontal profile is another main reason. 14's give you both. http://www.flickr.com/photos/ekkoj/5425585813/in/photostream/
05 Forester Shaking/Vibration problems
uniberp replied to naldo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGET THE CODE SCANNED. Shaking is a relative term.
07 legacy acting up again. Please help me. This is my first subaru!
uniberp replied to Pathfinder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid the car have its timing belt service done at 105 miles? I've heard of more than one timing belt tensioner failures, I think I caused one myself once, by compressing it too quickly. The knock may mean it has slipped its timing which can cause internal engine damage. If all this is greek to you, do not drive it until it has been properly diagnosed.
Gasoline smell through HVAC when really cold?
uniberp replied to Timberwolf530's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYMM? Check the filler tube for rust holes. Remove the cover, they get full of dirt. In cold dry weather gas fumes may be much more noticeable.
what subaru would you recommend?
uniberp replied to baseketballfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can never tell how a car has been treated or stressed. A car with less than 10k miles likely will not show any abuse that was hurled at it. The stresses on bearings (wheel, main, rod) will not show any symptoms until much later in it's life, but that could be as low as 40k miles. Subarus are good cars, but only if you take care of them. I think they appeal to many DIYers because they are easily user serviceable. Unfortunately the thing that makes them attractive to technically able also makes them easy to patch up and turn over for a quick buck. For a commuter I liked my high mileage car, with new struts, brakes, tires solidly reliable at $4000. As it is, I baby the nice $16000 cross my fingers that nothing goes wrong car. But that's just me.
dead spot in throttle under load!
uniberp replied to kharris360's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAdd a can of Techron at 1/8 tank, change your plug wires. Plugs too but don't if you don't know aluminum thread torque behavior.
HELP
uniberp replied to 509northwest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBad negative ground cable. Double it up with a 24" double ended blade connector cable.
99 Forester AT, odd behavior?
uniberp replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possibly a shifter cable position adjustment issue?
Remote starters
uniberp replied to rhubarbray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is one significant issue with the Avital on my 2008 (I think all are made by the same mfg, just rebadged.) The aftermarket remote and factory are un-compatible, and I've had it back to the installer a couple times. If I inadvertently press the lock on the door itself when I exit, and use the new remote to unlock it, the alarm goes off, and I have to use the factory remote to turn off the alarm. It was a pain until I developed the habit to never touch the door locks. Occasional passengers who are courteously assisting us by pressing the door lock when they exit are greeted by a screeching alarm when we return. I have to be the noodge-reminder-guy to "not touch the door lock." Other than that, it's great.
Non turbo Impreza exhaust
uniberp replied to dmandell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs understand k&N filters allow more air because they have bigger pores. Bigger pores mean bigger particles. http://www.bobistheoilguy.com/airfilter/airtest3.htm
