Everything posted by MR_Loyale
The rats are in my brat!
They have a wet bar and jacuzzi too. I was at a wicked party there last weekend.
Damn rotor screw...
I made a grocery run to Central Market for some good grub. On the way back while driving south on Highway 3 this morning gliding along in my Loyale with some nice tunes and suddenly I hear a clunk and I lose power. Luckily I was near an off ramp and could get off the highway. All the lights on the dash lit up and I slowly rolled to a halt on the side of the ramp. I got out checked the engine, nothing blown up. Cranked it a few times and it wouldn't start again. I thought maybe it was the fuel pump, so I got out and picked up a rock to whack it, but as I was laying down to reach under the back of the car, I figured I should see if the pump was charging with the distinctive growl. Got in and turned the key and it growled so the fuel pump didn't need smacking. After two minutes, I thought to check under the distributor cap and sure enough the little screw is sitting there. I am relieved I know what is wrong (especially considering I forgot my phone at home) but really annoyed that this screw fell out again. Luckily I have a phillips screw driver and got going again. I am home now and found some blue locktite but I am not even sure that will be a permanent fix. I am thinking of riveting the thing on so I never have to worry about it again or perhaps locktite and rivet. Other than requiring drilling if I ever need to change the rotor, does anyone see any big problems with this? This screw is the one thing I hate about the Loyales.
Adding to "Bumble Beast's Relay swap write up"
I second the remark on cleaning and lubricating for optimal window performance.
1991 Loyale Lifters Noisy
Your radio has a volume knob for a reason.
- Loyale not being very loyal
1992 Loyale Alternator Failing - Strange Symptoms
I always just replace the unit and it fixes issue.
'93 Loyale oil leak, coolant loss and gurgling noise. Head gasket?
For coolant leak try this. Open hood and turn on engine. Pull the throttle cable to Rev engine to 3000 revs while watching for leaks on coolant hoses. Frequently self sealing pin leaks do not leak at idle. Revving increases pressure to expose leaks. Gurgling is air in cooling system. Once you replace leaking hose, refill and burp system.
In search of an oil pump
I am glad I put a new one in my Loyale last time I did the seals. I didn't realize at the time they were getting scarce or I'd have stocked up.
Oil pump reseal / no pressure
Just consider the splashed oil extra rust protection.
- FIXED! Bad Neutral Switch Assembly causing HEAVY engine breaking
Coolant leaking from PCV threads
No it stream out like a fountain when I Rev the engine. Let me try to get a bid or pic tonight.
I have coolant leaking like a fountain from around the pcv threads on my Loyale. It only shoots out when the engne is revved to above 3000 rpms or so. Under idle it is dry. Just a pcv replacement or something more ominous? I have never seen this happen before.
Just Got done with the reseal, now help me get it running...
Yes. You need to redo it. There are separate marks for timing belt.
- EA82 ECU experimenting
Quiz Time
Was there a check valve you forgot about?
Ea82 spfi air idle control valve issues.....maybe.....
While you have it out, examine the back of the connectors where the wires attach. Gently tug on each wire to ensure they are secure the the connector and not intermittent.
Try willing and jiggling the harness, gently of course.
Electrical connectors...
I believe so. I ordered mine from Powerwerx (see my earlier post for link) it was about $2.99 and of course $5 shipping lol.
Connector came Friday and I got it put in today. Seems to be working fine. Thanks all.
- 85 GL wagon
That is what is so frustrating. I know it is a common connector, but I asked at several auto parts stores and the first thing they would do is type on their computer and of course it doesn't come up as a Subaru blower motor connector. I get so tired dealing with auto parts desk people.
93 Loyale Starting Issue
That'll definitey do it. Glad you got it working. I always label things when I disconnect them with numbered tape on each end so I avoid mixing them up.
Thanks for the backgound on the connectors. I did have the feeling like I had seen them many other places which is why I assumed I could easily get one quick. I thought the dealer would easily be able to get me one. The dealer parts guy told me when he worked at GM getting connectors was no big deal but Subaru doesn't do connectors, only the harness. I do have a crimper so I should be fine. I will let you know how I get on.
Found another source: https://powerwerx.com/oemt-power-connector-source-side
I found this: http://www.cablesandconnectors.com/26000-26.HTM Cat.# 26162 / ARS id # 865668193 2P Does that sound about right?
