Everything posted by critical_max
"Mob"?
Ratio of running vs. non-running subarus
critical_max replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
One sedan, pushing 160k, runs and drives -
Yes
The connections for a tape deck and CD deck should be similar if they are both aftermarket. Metra makes the dash adapters, you might find that both stereo installations had used the Metra wiring kit as well, in which case your task is simple. Be sure not to blow fuses.
EA82T Diagrams on my website
critical_max replied to Dylan86GL10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks, great resource!! -
Allied Armament Super Christmas Group buy
critical_max replied to Shadyirishmen's topic in Products for your Subaru
I got my wheels yesterday... they make me drool... now I need to dig out another 500 for low-pro potenzas.... -
EA82 Platform
critical_max replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the kit is made to fit a 4wd EA82 Sedan, it will fit the RX Sedan; if for a Coupe, it should fit an RX Coupe. Wagons have different suspension bits in back, though. -
justy wheels, bolt and back spacing?
critical_max replied to mschmit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bump. Are these the same bolt pattern as EA82? -
1100 sounds like a good deal if it's in good shape. Look for rust, leaks and proper operation of everything, transmission solid, suspension etc. And rust.
go for the XT6, they are much harder to find and engine is not much more complicated than the 4-cylinders from what I understand.
side molding removal
critical_max replied to pkennedybluewrx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The moldings clip on at several points per piece. You should be able to pry them off, though you'll probably want to fill the small holes in the body where the molding clips used to be. -
So, how many people besides me have made deposits on wheels? I'm curious which discount bracket we will fall into. -
I got better mileage on a stock carb'd EA82 wagon (30mpg city/highway loaded down) than I get in my MPFI turbo sedan (25 or 26mpg city/highway). If you want more power I always hear about Webers...
Put me down for a set of 4 black 15x6 wheels. -
Most of us go to junkyards or have entire parts cars sitting around... no junkyards near where you live? what model of soob do you have?
Tie rod ends and wheel bearings
critical_max replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd suggest cold calling a number of shops, both local and chains... get quotes from all of them, then you should have a good idea of prices in your area. It shouldn't be more than a few hours of labor? -
I wanted to say a big "thanks" to Edrach ... the method he outlines in this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=2576 just got me through my first CV axle/half shaft swap. This morning, the RX shuddered and clicked its way around town... on tonight's test drive/burrito run, it glided (okay maybe not, but it felt like it!!) I'm sorta embarassed to say how long the job took me, but long story short I really only had to undo the inside bolt on the control arm, and the 3 nuts on the strut tower, and the e-brake cable bracket, in order to get the axles out/in. Most fun moment was breaking the castle nut loose - without a breaker bar, just a 1/2" Craftsman socket wrench and a 36mm socket, I had a hard time for a while, even standing on the wrench didn't do it (too skinny). I thought, "how can I make myself heavier?" and eventually got the idea to hold a floor jack (in its carrying case) far out in one hand while I stood on the wrench, this acted to put a lot more torque on the nut and it broke free.
Superlite Wheels
critical_max replied to Barry Knickerbocker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bump. these wheels are nice, thanks for the heads up. -
I have Chilton's and Haynes and at different times one will have good info that the other does not; also they have different photos, supplementary info and such, so it would be a good idea to have both.
those imported low mile motors??
critical_max replied to oddcomp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I too have a JDM engine in my RX, it doesn't burn oil like the blown mill it replaced... Perfectly ok for the money, I think it was $795 or so through a shop. Now, the accessories from your old engine, that's where you've got to watch out ! -
New Posterer Not running smooth
critical_max replied to aussie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Today is Friday (Hoy es Viernes). Also how's your exhaust system doing? -
Definitely use the Metra adapter plate, and replace your stock speakers if you want to hear anything at all. I only did the rears, so the fronts are drowned out almost entirely. New speakers are about 10x better than the OEM ones. I didn't have any problems with the common ground/shared ground setup, your mileage may vary. I have all 4 speakers working off the new head unit.
¡¡ help !! subaru leone '82 ( 1600 dl )
critical_max replied to yiyo_26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Anything specific you need information on? Also, http://babelfish.av.com is a good translator. Are Chiltons or Haynes brand manuals available in Chile for these cars? (edited for URL) -
Turbocharger Help Needed
critical_max replied to Havnfun2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I should have known that there are 4WD turbo EA81s hiding north of Clark County in the woods .... your back roads are almost as groovy as mine ... -
Peugeot wheels for all!
critical_max replied to cmiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This is awesome news. PM being sent. Like I needed *another* excuse to visit Hwy 34... I think I can spare $100 to replace my 13s with 15s, yeah.
