Progressive springs? - '97 Outback 5-speed
Legacy777 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's your budget? You're probably not going to find anything specifically for the outback, however there are probably quite a bit of stuff from the normal legacy and impreza of similar years that would work. You could put Legacy GT springs & struts on your outback, which will probably lower the ride height from what it current is, and give you better handling....without "slamming" it. I'd suggest searching on Nasioc http://forums.nasioc.com/forums in the legacy forum for more information on what's swappable.
93 Legacy, Hesitation, but only when hot?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhh....glad you figured it out.
replacing front struts
Legacy777 replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe there are a few threads that show pics and have instructions. You may want to search. It's pretty straight forward. To be honest, I'd highly recommend you replace all four struts at once. I've been down the road you're going, and you end up with issues in having mixed-matched struts with different damping rates.
Hi + '92 Leggy trouble...
Legacy777 replied to T.J.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what was the fix....? Also, what wiring is different between the wiring diagram and what the car actually is wired?
03 to 00 OBW Caliper Interchangability?
Legacy777 replied to Brokechump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat are you wanting to swap? Everything, or just calipers? How are the 03's brakes better? Does it stop shorter, or does it just feel better. Once you get into the "feel" portion of braking, you get into the non-calculatable part that can be different for different people. Things like brake fluid, brake pads, vacuum assist, tires, etc can affect how the brakes feel. So what I would suggest you do, make a list of what's different between your 00 & 03. Try to remove some of those things from the list....but do this after you've answered the question, what's better about the 03.
impreza lift question..
Legacy777 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe earlier imprezas should have roughly the same suspension setup as the early legacies. So I don't see any issue with using either the forester or outback suspension.
Stumble, 1998 Forester S
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse brake cleaner
2006 Climate Control Concern
Legacy777 replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo your problem is pretty much a transient issue at startup in cold conditions. Unfortunately, there's probably nothing you can do since the issue is with the sensors measuring dash temp....and waiting for things to warm up.
po505 ''idle control system malfuction''
Does it idle poorly, or do anything else abnormally?
Legacy777 replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDefinitely do the coolant temp sensor.
Diagnosis suggestions for H-6 stalling?
Legacy777 replied to bernie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest they check the IAC valve first.....it may be gunked up and sticking. How does the car run otherwise?
Auto to manual tranny
Legacy777 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out my write-up. All the info is there, as well as costs. It's not a project I'd recommend for someone without some good automotive knowledge.
Legacy777 replied to Top's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt 66, does the air still feel warm? One would think the flapper door on the heater core would shut all the way so you can only have outside air....but maybe not.
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, remove the battery cable for an hour or so.
96 Legacy Outback 4EAT Cluth Pack Question
Legacy777 replied to Wayne Boncyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis may or may not help http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg I had thought there were some pictures or someone that did this work....
Fog Light Replacement
Legacy777 replied to fontanlc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to get at the bulbs from under the car. You may need to remove some of the plastic under body tray to get at them.
Repairs Eastern Shore of MD
Legacy777 replied to BL99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMay want to post in the meet & greet forum as well.
Impreza TCU Code 16 Torque Control Cut Signal
Legacy777 replied to HX-20S's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't worry about it, especially if the code hasn't shown up again. If you continue to get the code, then you could have an issue with the TCU or wiring.
Final Gear Change?
Legacy777 replied to Pilgrim 54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis thread is done. Please move along
trying to find paint colour!
Legacy777 replied to Zefy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may be steel blue mica.... If you find a pic of a car, you'll probably find someone that can identify it. You'll probably have better luck finding a pic and someone to identify the paint on NASIOC http://forums.nasioc.com/forums
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you didn't do it, disconnect all the electrical sensor connectors, blow them out with compressed air, and put dielectric grease in them.
blinking seatbelt light 1st gen legacy
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThese may help http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/auto_seatbelt_wiring_diag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/auto_seatbelt_wiring_diag2.jpg
torque bind on 5-speeds?(im sure ur sick of it)
Legacy777 replied to seanski06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorque bind is more of an issue with automatics. I've heard of far less instances of torque bind on manual transmissions. This is assuming you're referring to manual transmissions with the 5-speed description.
Re: Please help the new guys out
Legacy777 replied to broke subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, you're in the right section. The board has several different forums, each forum has threads, and threads have posts replied to them. As for keeping tabs on your post, there's two main ways. When you submit a thread, there's an option below that says "Thread Subscription" You can set this up to email you whenever someone replies. The other way is use the search engine and simply type in your username, and find all any posts by you. Hope that helps.
Legacy777 replied to Randall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm.....have you done any routine maintenance on it recently, plugs, wire, filters, etc?
