is this true: a broken pipe affects your gas mileage
Legacy777 replied to stillfox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn exhaust leak might affect mileage slightly, but shouldn't be too noticable. How much of a drop are you seeing? You mentioned you smelled gas. Was it a raw gasoline smell? Or exhaust smell?
Dyno'd the turbo engine today
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think I have some laying around. I'll look this evening.
Convering Clutch from Cable to Hydrolics
I'm not sure if the older gen stuff is the same as the newer. If it's not, you may be able to. If it is the same or similar you may or may not be able depending or not if you fab up your own bracket. I sort of think the fork for the hyd. setup is different, which may also be the reason they change the pivot point.
Can anyone reccomend a North Carolina Mechanic?
Legacy777 replied to 11marka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure where Fayetteville is in relation to Teague's Auto, but they sell subaru performance & OEM/used parts. I'm not sure if they do service. If not, they'd probably be able to recommend someone to you. www.boxer4racing.com You may also want to post in the meet & greet forum too.
1990 Legacy Wagon Timing Problem
Legacy777 replied to BoomerBoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere are the factory manul pages. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg Also, here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt It's pretty straight forward. The thing most people screw up on is aligning the crank shaft gear with the front arrow instead of the mark on the back of the timing gear. If you're just doing the belt and no seals, you should be able to just line up the marks on the pullies & gear with their corresponding marks on the covers & oil pump, and slap a new belt on.
Torque Bind, TPS? VSS? Air Susp?...
Legacy777 replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 1/16" measurement is circumferance correct? I'll have to check my manuals regarding the 12ohms, but if they're both were that way, they're either both ok, or both bad. The speed sensor in the extension housing is VSS1. VSS2 is in the combination meter in the dash. It shouldn't matter about the ratio as long as the front and rear are the same. The biggy that leads me to believe it's the wiring, the duty c solenoid, or something else is the fact that inserting a fuse in the FWD fuse holder does nothing to alleviate the problem. If the duty c solenoid is functioning correctly, when it receives 12v it stays open 100% of the time. This allows the line pressure to bleed off, and not go to the clutch packs, which in turn gives you 0% torque split to the rear wheels. If something in the FWD fuse circuit, ie wiring, or duty c solenoid is not working, then the problem will still exist. Just a shot out of the dark, but did you check to see that you had +12v at one side of the FWD fuse holder while the car is running? If not, you may have a problem there.
sump guard for 98 legacy o.b. -other years fit?
Legacy777 replied to Scoobydoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere wasn't a 98 loyale. Do you mean legacy? There really wasn't a "guard" from the factory, just an under engine plastic cover to help with areodynamic drag losses. If it's a 98 legacy, and you want to replace the cover, a cover from a 95-99 legacy should work.
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, an n/a EJ22 should have no problem hitting mid 20's. When my car was FWD & automatic (higher final drive ratio) and I drove sanely, I'd get high 20's or low 30's on the highway. With the AWD & 5MT and in town, 23-26 was sort of the normal. I think I've got some papers of my old mileage if you're interested.
"spy" pics of new 05 outbacks! and i got to drive it!
Legacy777 replied to Ratty2Austin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGuys....let's take the whole government/big brother thing to OT please.
got my rotors in the mail and there is something unusual
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cryo-treating process will improve rotor longevity. You won't really see any braking benefits. I still think it's very beneficial for street use, especially since the rotors on the first gen legacy are a little small. With better brake pads, you're going to raise the temps of the rotors, and you end up with vibration issues. So do as you want.....
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy EJ22T is virtually stock. Other turbo legacy guys don't see much better....if you run separate engine management, you could probably get better.
Legacy777 replied to Mike W's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would check the wiring of the duty C solenoid. Since it happened after swapping extension housing, I would look at the wiring going from the TCU to the transmission. You may have wiring that is failing, and as it heats up, resistance increases. If you don't want to test it, or if testing is a pain, try running a separate wire for the duty c solenoid. Other thing I might recommend if you have a laptop is seeing what the ECU sees via a Vikash's scan tool. http://www.graphics.cornell.edu/~v/bcbfscan/ I don't see how the TPS or air suspension could affect the torque bind. If your VSS's are acting up, that could attribute to some issues. How "close" are your tire diameters?
What vehicle are you wanting to do this on? On the newer gen subarus, there are two different types of clutch engagement systems, pull & push. The pull style is all hydraulic. The push style was cable & hydraulic. To convert a push style to hydraulic, you will need a hydraulic pedal box, clutch master cylinder, clutch lines, clutch slave cylinder, (I think the clutch fork is different too), and any associated misc hardware. You'll also need to change the pivot point for the clutch fork. There's two bosses in the transmission. For the hydraulic setup, you just have to move it to the other position. I don't know if it's tapped or not.
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe turbo radiator is taller, and without modifying the lower radiator support, it's not going to fit. I don't feel like messing with that. I'm running a lower ratio of anti-freeze & water as well as redline water wetter. I have not seen any issues what so ever, temps are maintaining where they need to be. If I find that I'm running warm, I'll probably look at a custom two row n/a sized radiator, instead of the one row.
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter running lots of different rotors, including OEM, cheapos, and brembros, I still like the OEM rotors the best. However the best money you can spend on rotors is to cryo-treat them. I've been running a set of cryo'd rotors since the summer of 02 and no "warping"
Interchangeability of legacy rear 4wd wagon and 2wd sedan struts
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirstly, the FWD struts are inline with the axle. The AWD ones are offset back and raised slightly. Therefore height will be different. The AWD strut body is smaller. However irregardless of height, the way the metal at the bottom of the strut is bent will not fit on the rear FWD spindle. I tried it when I did my AWD swap. I was just going to use the rear AWD struts on the rear FWD spindles on the donor car, so it rolled. I ran into the issues I mentioned, so I had to swap the rear AWD springs on the rear FWD struts, so they would bolt up to the rear FWD spindles.
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4WD & 2WD rear struts are not interchangable.
ATTN Legacy777 - fwd to awd swap- Important note for all who've looked at this thread
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's good to know they aren't the same. The FWD TCU probably doesn't have the programming to control the AWD.
No check engine light 90 Legacy
Legacy777 replied to GregS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible the bulb is not in tightly, something is screwy with the combination meter, or the ECU is going.
Legacy777 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rotors you have that are in the brembro box are not made by brembro. They are manufactured by another company and packaged by brembro. They've been doing this for quite a while. I was told that about the brembros I bought several years ago. I wouldn't really worry about it.
Speedometer Question
Legacy777 replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno, the speed sensor is not related to the tachometer. What was the problem that you brought the car in for? It's possible the ECU needs to be reset. If that doesn't work, take it back to them and tell them to fix it, because it wasn't like that when you brought it in.
Drive Belt/Timing Belt same or different?
Legacy777 replied to Urban Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll the 2.2's up until about 96 are NON-interference. I can tell you with 100% certainty that the 90-94 legacies are non-interference.
New Subaru owner, just got a 93 Legacy 4WD
Legacy777 replied to subjfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out my site www.surrealmirage.com/subaru There's info in the notes & tips section on how to pull the codes from the ECU. Also, check out www.bbs.legacycentral.org there's a lot of good info on the first gen legacies.
2000 Legacy ECU issue, PLEASE HELP
Legacy777 replied to supersubbie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2000 was the first year of the 3rd gen legacies. They changed body styles and a few other things, so I don't think the 99 will work. A 2001 or 2002 may work.
Engine Installation Inc good/bad?
Legacy777 replied to sprite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't heard of them. You may want to post in the meet and greet forum too.
