Downloading Service Manual from Subaru...HELP!!
Legacy777 replied to mwells's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnfortunately.....no way around it that I know of.
IMPREZA L wont start
Legacy777 replied to DMOR319's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd double check to make sure the timing belt is installed correctly. It may be firing, but at the wrong time.
92 Legacy wagon overheating while idling
Legacy777 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet your power issues taken care of and see if that affects your temp issues.
Car Audio problems, ICE questions
Legacy777 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stock speakers are 6.5". I don't know the depth, but the stock front speakers have a bracket to angle them upwards. So you can get spacers and run a deeper speaker. I'm running infinity kappa 63.i's in the front, with 1" custom wood spacers. The front mount depth is like an 1". So if I can fit them in there, you should be able to fit most other speakers. The rears, you have a limited top mount depth due to the deck lid, but the bottom mount depth shouldn't be an issue.
P123 6 Cd Changer in a 2002 Outback?
Legacy777 replied to erickr123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know what car the cd changer came from? Do you have an owner's manual? You may want to check and see if it mentions anything about a 6 cd changer in it. What I'd do is try to find out what car the changer came from, get a wiring diagram for it, and get one for your car, then check that the pin outs are the same.
Dyno'd the turbo engine today
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the highway if I'm behaving....around 20ish. Around town 16-17 when I'm on it. I need to check my most recent couple of fill-ups though....I haven't checked them.
Disable 2006 Baja Factory Alarm?
Legacy777 replied to Jim Padgett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm...yeah I'm not really sure how to disable the alarm. Have you asked the subaru dealership? Have you looked to see if there's a fuse?
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBolt ons MSD Dis 2 ignition Stock sized lw pullies lw flywheel magnecor 8.5mm wires CES 3" turbo back exhaust modified stock air box I did datalog during the pulls. I'll have to check the time. Yeah, as for starting at a lower rpm, that would have been better. I mainly just wanted a baseline before I started doing any other mods, so I had an idea of how much I gained.
swapping ej22. pilot bushing on all motors??
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe pilot bearing goes into the flywheel. It doesn't matter about whether the motor came from an auto or manual trans car.
As some of you may or may not know, I rebuilt and swapped an ej22t engine from a turbo legacy into my legacy. The motor's broken in, and I took it to the dyno. I got 153 HP at the wheels, and around 156 ft-lbs of torque. Not too bad for a pretty much stock ej22t with bolt ons. The dyno I was on doesn't use any correction factors, so it's pretty accurate, and is probably lower then most. Other interesting note is the tuner guy mentioned I'm running a little lean until about 4500 rpm, most likely due to the fact the small turbo builds boost so fast, but then I'm running a little rich afterwards. So a little tuning will probably smooth out the AFR. Boost level stayed pretty consistent across the entire rpm range. http://www.main.experiencetherave.com:8080/subaru/images/tlegdyno1.jpg http://www.main.experiencetherave.com:8080/subaru/images/tlegdyno2.jpg Pics of the engine rebuild & swap if you haven't seen them. http://www.main.experiencetherave.com:8080/subaru/images/ej22t
Grumbling during tight turns
Legacy777 replied to nalsalam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour automatic does not have a center diff. Just change the trans fluid, and see if that helps things.
Rear engine oil separator??
Legacy777 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I don't know.....the plastic one on my turbo looked fine. I resealed, and put it back on.....
4EAT MODEL Numbers!!! Go Outside and HELP ME OUT! :)
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnfortunately, you can't tell the final drive ratio from the trans number http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/engine_%26_trans_decode.jpg Your duty c solenoid is more then likely fine. I say that because inserting the fuse makes the torque bind go away. You've either got different final drive ratios, or the clutch plates are going. Only way I can think to check the final drive ratio is the drain the fluid from the diff, pear inside, and see if you can count the teeth on the ring gear.
Rear wiper parking
Legacy777 replied to dave1rr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....might be the switch. I'm not sure how the wiring is setup though.
Good Subaru Mechanic in Eastern KY
Legacy777 replied to mwells's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to post in the meet & greet forum as well.
Need Manual Tranny 91 Leg LS
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe shop should be able to put the car up on a lift and determine where it's leaking. I think that would give you a pretty good idea whether it's a seal or something seriously wrong with the transmission.
Legacy777 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe aluminum ones were found more then likely on the 90-91 legacies. I'd venture to guess that in 92 they went to the plastic one. My 90 engine has the metal one. My 93 turbo engine I rebuilt had the plastic one. There's no difference to my knowledge and should be 100% interchangeable.
Sub Legacy Auto trans swap
Legacy777 replied to fubar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can not just swap on the extension housing an make the FWD transmission AWD. You must swap the entire transmission. Plus even if it would work, your front & rear final drive ratios would be off as the FWD transmission has a 3.70 final drive ratio.
Legacy777 replied to fubar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre these cars AT or MT? Are you planning to stay with the same type of tranny?
Mounting depth for door speakers
Legacy777 replied to bfg9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOriginally I didn't. Two years ago or so I redid the wiring, and decided to just put a small square bit of dynamat where the speaker mounts to the door. Dynamat really only helps with rattles by lowering the resonant frequency. I was looking for more road noise quieting, because of that I just put the dynamat around the speaker. As for things being any quieter or better....I don't know. Here's some pics http://www.main.experiencetherave.com:8080/subaru/images/stereorewire/
Legacy777 replied to bfg9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to add spacers to increase the depth. I don't really know the exact measurement. But I've got 1" custom wood spacers, and am running infiniti kappa 63.i's in my 90 legacy.
Broken Shock Mount Symptoms...
Legacy777 replied to Surfdougyfresh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you've had it up on a lift and felt everything in the suspension, and it's tight....the mount is probably ok.
Advice on grounded Impreza Wagon
Legacy777 replied to botscooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd start with the ECU. You could probably find a used one for 100 bucks or so. No idea if that would solve all the problems, but that's where I'd start.
Legacy Production Numbers from Subaru USA
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt was built before that. Like I said, I had a 1990 Legacy wagon that has an SIA vin number.
Feels like I'm swaying in the wind
Legacy777 replied to deiscient's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe struts are a common wear item. If you've got over 80,000 miles on the original struts, you're doing pretty well. It's time to replace them.
