8
Yeah I would think the torque converters are the same. As for electrical, I believe the only thing different on the AWD's is the duty c solenoid. So you should just verify that the pins for that sensor is there. I'd have to look at things more closely, to be absolutely sure, but you should be able to d/l the tcu i/o from my server.
If your suspension components are all ok, then I'd suspect the tires themself. If they have softer sidewalls, the car may sway slightly and not feel as planted. Also, if your struts are still original, they are probably shot, and in need of replacing. That will go a long ways to improve the ride/handling/feel of the car. I'd recommend KYB GR2's.
The idle motor is on top of the throttle body. It may just need to be cleaned. It's possible the plunger is getting stuck and causing the check engine light. Or that the electrical connections are not good. You may want to post in the meet & greet forum to see if there's anyone around that can give you a recommendation on a mechanic. You may also want to try the regional forums on NASIOC, http://forums.nasioc.com/forums . There's bound to be some other impreza owners near you that can recommend a mechanic.
You may still have oil flow, but low pressure. If you're getting some pressure at idle, and "normal" pressure at higher rpms to fill the lifters, and the lifters don't leak....I wouldn't necessarily say they are going to make noise. If the sender is working correctly, what I'd lean towards is the o-ring between the block & oil pump not being aligned/installed properly during the oil pump work. I'd recommend pulling the oil pump back off and checking things.
Honestly.....Sometimes I think the subaru community has better knowledge then subaru does themself I've already given my piece on the numbers not being accurate, so I'm not going to bother.... But they once again give incorrect information. There were most definitely first gen legacies 1990-1994 that were built in the USA. I owned one and stole parts for my swap from it. You can email Subaru again if you'd like, but I think it's a futile battle.
Our cars have a camber bolt already. It's the top bolt holding the bottom part of the strut to the spindle. They either don't know this, or they're trying to screw you. Either way, camber bolts don't cost $100!! If they have maxed out the stock camber bolt, and still can't get it aligned, then it sounds like you got something bent underneath. Personally, I'd go somewhere else.
