8
The only thing that comes to mind would be that the timing belt may have jumped a tooth if you turned it in reverse. If this did happen, it would indicate to me that the tensioner may not be providing adequate tension, and should probably be replaced. I'd look there, since it doesn't sound like you changed anything else that could have affected things.
Convering Clutch from Cable to Hydrolics
Legacy777 replied to Gravityman's topic in Subaru Retrofitting
I'm not sure if the older gen stuff is the same as the newer. If it's not, you may be able to. If it is the same or similar you may or may not be able depending or not if you fab up your own bracket. I sort of think the fork for the hyd. setup is different, which may also be the reason they change the pivot point. -
Here are the factory manul pages. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg Also, here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt It's pretty straight forward. The thing most people screw up on is aligning the crank shaft gear with the front arrow instead of the mark on the back of the timing gear. If you're just doing the belt and no seals, you should be able to just line up the marks on the pullies & gear with their corresponding marks on the covers & oil pump, and slap a new belt on.
The 1/16" measurement is circumferance correct? I'll have to check my manuals regarding the 12ohms, but if they're both were that way, they're either both ok, or both bad. The speed sensor in the extension housing is VSS1. VSS2 is in the combination meter in the dash. It shouldn't matter about the ratio as long as the front and rear are the same. The biggy that leads me to believe it's the wiring, the duty c solenoid, or something else is the fact that inserting a fuse in the FWD fuse holder does nothing to alleviate the problem. If the duty c solenoid is functioning correctly, when it receives 12v it stays open 100% of the time. This allows the line pressure to bleed off, and not go to the clutch packs, which in turn gives you 0% torque split to the rear wheels. If something in the FWD fuse circuit, ie wiring, or duty c solenoid is not working, then the problem will still exist. Just a shot out of the dark, but did you check to see that you had +12v at one side of the FWD fuse holder while the car is running? If not, you may have a problem there.
Yeah, an n/a EJ22 should have no problem hitting mid 20's. When my car was FWD & automatic (higher final drive ratio) and I drove sanely, I'd get high 20's or low 30's on the highway. With the AWD & 5MT and in town, 23-26 was sort of the normal. I think I've got some papers of my old mileage if you're interested.
The cryo-treating process will improve rotor longevity. You won't really see any braking benefits. I still think it's very beneficial for street use, especially since the rotors on the first gen legacy are a little small. With better brake pads, you're going to raise the temps of the rotors, and you end up with vibration issues. So do as you want.....
I would check the wiring of the duty C solenoid. Since it happened after swapping extension housing, I would look at the wiring going from the TCU to the transmission. You may have wiring that is failing, and as it heats up, resistance increases. If you don't want to test it, or if testing is a pain, try running a separate wire for the duty c solenoid. Other thing I might recommend if you have a laptop is seeing what the ECU sees via a Vikash's scan tool. http://www.graphics.cornell.edu/~v/bcbfscan/ I don't see how the TPS or air suspension could affect the torque bind. If your VSS's are acting up, that could attribute to some issues. How "close" are your tire diameters?
What vehicle are you wanting to do this on? On the newer gen subarus, there are two different types of clutch engagement systems, pull & push. The pull style is all hydraulic. The push style was cable & hydraulic. To convert a push style to hydraulic, you will need a hydraulic pedal box, clutch master cylinder, clutch lines, clutch slave cylinder, (I think the clutch fork is different too), and any associated misc hardware. You'll also need to change the pivot point for the clutch fork. There's two bosses in the transmission. For the hydraulic setup, you just have to move it to the other position. I don't know if it's tapped or not. -
The turbo radiator is taller, and without modifying the lower radiator support, it's not going to fit. I don't feel like messing with that. I'm running a lower ratio of anti-freeze & water as well as redline water wetter. I have not seen any issues what so ever, temps are maintaining where they need to be. If I find that I'm running warm, I'll probably look at a custom two row n/a sized radiator, instead of the one row.
Firstly, the FWD struts are inline with the axle. The AWD ones are offset back and raised slightly. Therefore height will be different. The AWD strut body is smaller. However irregardless of height, the way the metal at the bottom of the strut is bent will not fit on the rear FWD spindle. I tried it when I did my AWD swap. I was just going to use the rear AWD struts on the rear FWD spindles on the donor car, so it rolled. I ran into the issues I mentioned, so I had to swap the rear AWD springs on the rear FWD struts, so they would bolt up to the rear FWD spindles.
