Legacy Production Numbers from Subaru USA
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I don't know what's up with subaru's numbers.....but yeah they just can't be wrong. You could go on legacycentral and find five people that have a 92 turbo legacy
Heated windshield - 2000 obw
Legacy777 replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should have a fuse. It may not be a separate fuse though. Does anything else not work? You may want to try putting a voltage meter across both sides of each fuse to verify that they are good.
Air filter CA 2004 Outback wagon?
Legacy777 replied to bluie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried going to your local dealer?
Walker Valley
Walker Valley rules!! While I didn't do any sube driving up there, I did some mtn. biking, and it was a blast.
Throttle Body Warning!
Legacy777 replied to qjoshh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy specific issue was due to an oddity on the earlier throttle bodies. They had a bypass screw/needle valve that let you adjust how much air went by the throttle plate. They stopped doing this, and therefore removing the sealant isn't as "critical"....but personally, I won't screw with it.
Legacy777 replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose numbers are no way near being correct. Check out the sticky in the misc forum on www.bbs.legacycentral.org
Cold 97 Legacy
Legacy777 replied to Randy_B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace your thermostat and coolant temp sensor. Your car should operate correctly even in those temps
1991 Legacy Died & Won't Start
Yeah, if it just died.....it's probably the timing belt. Remove one of the plastic caps on the timing belt cover and verify that the timing belt is in tact, and/or the cam pullies rotate when you rotate the engine by the crank.
1990 Legacy wagon shutting off
Legacy777 replied to GregS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it taken care of.
Subaru master key??
Legacy777 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to buy a blank master key from any online dealer, and then take it to your local dealer for them to cut. That's what I did.
Legacy777 replied to qjoshh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe throttle body issues I ran into were because of a sealant/coating they put on the inside of the throttle body. If your throttle body had something similar, then yes cleaning that off will throw off the calibration.
Replacing OBW door speakers
Legacy777 replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they're like the older legacies, you have to remove the entire door panel.
Subaru master key??
Legacy777 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe dealer should be able to pull that info, however if they can't, if you have the original keys from the car, (valet key) the key code should be stamped on it.
IMPREZA L wont start
Legacy777 replied to DMOR319's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, Give that a shot and let us know. Good luck
legacy LE AWD touring wagon?
Legacy777 replied to turbomatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat number is not correct. The numbers subaru gives are no way near being correct. There's been at least 50 touring wagons on the legacycentral bbs.
Newbie and questions - 93 legacy AT 4WD non-T
Legacy777 replied to seattlelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou want NGK BKR6E-11 plugs They should be pre-gapped, however it's always a good idea to check. As for wires....NGK makes good wires.
Legacy777 replied to seattlelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah....unfortunately, it's probably on its way out. You're probably just best off driving it until it dies.
91 and 92 legacy combined
Yeah you have to swap everything for the front ends to be swapped. Even then....there was probably some tweaking to make things work.
heating problem 95 legacy
Legacy777 replied to hmdavis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend replacing the thermostat and flushing the system. In addition you may want to look into replacing the coolant temp sensor too.
replacing an auto trans
Legacy777 replied to bobbyboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to look for an independent shop. Swapping it out yourself can be done with the help of a friend and a weekend. The biggest pain is making sure the torque converter & shaft gets seated properly in the oil pump. You should use dextron III ATF fluid....any dex III fluid should work.
Legacy777 replied to seattlelegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome. I'd suggest changing the transmission fluid as starters. If you don't know the condition of the parts on the car, do a routine tune up, plugs, wires, air filter, pcv valve, fuel filter, etc. Check your brake fluid and coolant levels as well, pressure in the spare tire, as well as your main tires. You may also want to check out www.bbs.legacycentral.org too.
Car died on morning commute!
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd say it's a cooler line too. You may want to inspect the other lines as well.
Legacy777 replied to DMOR319's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo they put a cam sensor in place of the crank sensor? I suppose that would work, but I don't know if I'd recommend it. Have you tried checking for any additional codes? Have you reset the ECU?
Legacy central locking Fuse?
Legacy777 replied to macmonkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck fuse number 11, it's 20amp. It's the dead center fuse. Check this thread out, it has pics of the japanese fuse box, and links to my server with pics of the US fuse box. http://www.bbs.legacycentral.org/viewtopic.php?t=24248&highlight=%2Aegi%2A
xt6 alternator in 96 OBW
Legacy777 replied to redxt6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI sort of doubt it.
