93 legacy "manual" button? & cost opinion
Legacy777 replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe older tcu's will shift the tranny for you at redline. The newer ones (like 2000) won't. don't know when that change happened however.
Legacy777 replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need to make sure you're looking at the private seller portion and not the resale one from a dealer. They will be different.
What type of Refigerant am I running?
Legacy777 replied to EOppegaard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is not necessarily true. If done right, it will cool just as good. My conversion it actually cools better. I basically cleaned the system out. added specified esther oil, replaced receiver/dryer and charged the system to 3/4 of the specified r12 refrige amount and she cools very very well.
Legacy777 replied to EOppegaard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere will be a sticker on the radiator core support that will say. Plus the connectors will be a certain color, which again should tell you what you have.
Legacy777 replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmanual button......from my site: Manual Button The manual button has some controversy as two what its function is. But I'm here to disavow any of those rumors. Firstly, the automatic transmission normally runs a power split of 90% front 10% rear. (for awd) This is under normal driving conditions. Secondly, the manual button ONLY works when the shift lever indicator is in the positions "3" or "2". Ok, so you're ready to hear what this thingy does. It is a very primitive version of traction control. When the shift lever is either 3 or 2, and the manual button is depressed, it will keep the transmission from going into first gear. By doing this, you have less torque, more evenly distributed power, and a less chance to slip and slide around. So to recap, when the shift lever is in the 2 position the transmission stays in 2nd gear. When the shift lever is in the 3 position the transmission chooses between 2nd and 3rd gear. If the shift lever is any other position then the two above, the manual button does absolutely positively nothing.
Totally Weird Coolant thing going on
Legacy777 replied to Setright's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReally wonder if a new cap would help.....it's probably something I should look into. Also I think if your coolant level in the overflow is below the low mark the system has the possibility to suck in air which promotes the gurgling.
Brake bleeding on a legacy
Legacy777 replied to calebz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight Front Left Rear Left Front Right Rear
'94 legacy security system
Legacy777 replied to Powertraxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got a clifford intelliguard 800 alarm with prox sensor. Clifford makes excellent alarms. Hood & trunk are pinned. Any alarm/security system you get for the early legacies will require an additional actuator to have the door locks unlock & lock with the alarm. Cost of the part isn't much, but labor to put it in is what usually gets ya.
Door Lock issue Help!!
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe doors should not automatically lock. More then likely the spring behind the button has broke off of the tab and it's pressing against the lock button. So every time you open the door handle it puts more force on the spring which locks the door here's a good writeup on how to fix it. I used paper clips....been working great ever since http://www.geocities.com/hobiegary/locks.html
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is very common on the first gen legacies. The key lock cylinder has an arm with a tab that connects to the lock mechanism. The arm breaks off, and then you can just spin the lock. You will need a new lock cylinder. It can be had from the dealer. Unless you want to carry two keys, you'll need to take the cylinder to a lock smith to rekey it. Then you just put it back in, and you're good to go. PS: Make sure you don't put down the window when you have the lock cylinder out. My mom did this and bent the rod going down to the door lock mechanism. It was a complete and utter nightmare to put back in.
Torque Converter Not Locking P0740
Legacy777 replied to gruhfy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would check to verify both speed sensors are working properly in the trans. If you want to remove the valve body.....you could probably do so......there are different length bolts, and for this reason i highly suggest you have some form of manual to know where everything goes. You really probably won't be able to see much just by looking at it. There is a rebuild kit, they are not for the do-it-yourselfers. Trust me. I'd suggest dropping the pan, look at the oil, look and see if there's metal chunks around the magnet. you could try running some sort of flush through there....but that may make it worse.....not sure.
Need carfax report ASAP
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno prob. got it taken care of
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is acceptable for users of carfax to run vin's for others....it's in the user agreement. I was simply asking if anyone had one, and would mind running that vin. If not.....I'll run it myself. but thanks anyway:rolleyes:
sorry....I know it's slightly OT anyone have a car fax account? need to run the following VIN 4S4BJ63C2L6903987 thanks!
Carbon Build-up SeaFoam Product Question?
Legacy777 replied to pdigiacinto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I've used seafoam....great stuff! I've used it in the gas tank, in the injection system, and oil. The two I'd definitely recommend are the gas and injection system. When I did my injection system I just poured a little down the tube of the pcv at a time, and then followed the instructions.....turned the car off, let it sit for 10 min or so....then started it back up. The water injection method also does work.....I've used both. I'd suggest the pcv valve because it's centrally located on the intake manifold so whatever you put down will get to all cylinders.
Fuel Pressure Regulator
Legacy777 replied to Markus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbefore you say it's your fpr, get a gauge and test the pressure. You will most likely not see a change in how the car runs by just taking the vacuum off the fpr, or at least I didn't when I did mine. I ran a gauge to the fuel lines and everything was good and working the way it was supposed to.
Want to replace timing belt myself; any special tools?
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcam seals are just the seal....pull old one out....put new one in....there's really not two parts. The rear of the pass side has an o-ring instead of seal.....but no biggy. The driver's side front does have a small extension that uses an o-ring between it and the head....but I didn't replace that on my job. cam sprockets are held on by a bolt.....loosen bolt...remove sprocket. There is a special tool to hold the sprockets......if you don't have one, you can maybe use a strap wrench or an old t-belt to keep it from moving. remove pump....clean it up....you should use permatex gray. The #2 stuff is the anearobic stuff....which may work, but I used what the document that I posted said. The stuff that was removed was similar to a silicone....not the anearobic stuff. these should help http://main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/oil%26water_pump_install1.jpg http://main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/oil%26water_pump_install2.jpg
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://main.experiencetherave.com:8080/subaru/techinfo/subaru_sealants.gif
Intermittent check engine light
Legacy777 replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat car is it? if it's a first gen legacy you can scan the codes yourself....info is on my site.
ECU Power
Legacy777 replied to BoxersOnly's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit sounds like you have the right idea. In my mind....back up power is that....power to keep the ECU memory when the ignition is off.......but you may want to try and find someone that can prob those ports on their car and see if that's how it is.
Failed Emissions OX2
Legacy777 replied to pdigiacinto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo with just the black connectors connected, you get a steady blinking CEL indicating no codes? There is bound to be vacuum/pressure in the tank......I get that hiss when I get gas.....it's not a big deal. I guess try the cat stuff......
Legacy777 replied to pdigiacinto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause subaru uses a two part cat......if they replaced the cat improperly that could be the cause. Does the CEL blink all the time even when the diagnostic connectors aren't plugged in? You may want to check out my site for more info on how to pull any codes.
Knock Sensor- Anyone Have Pics?
Legacy777 replied to Atomic Robot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to test the knock sensor......if it's out of spec, it would be the cause or one of the causes for your CEL.
Legacy777 replied to pdigiacinto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys aren't really giving any solution to the problem....you're trying to fix the symptom. i hope I don't come across as an rump roast....not in the best of moods right now. NOx is high heat, and is typically caused when the mixture goes lean. The 90-94 legacies do not have an EGR valve. These motors also tend to run pig rich.....so to fail on a NOx test is a huge indicator something is not right with the engine or catalytic converter. Where did you fail the NOx test.....at idle or higher rpm? They didn't load test your car because it's AWD correct? I would check for a vacuum leak of some sorts, and I would also be curious to know the condition of the cat converter. If you pull the plugs out....what do they look like? If they look good and everything's normal......I'd really start wondering about the cat converter. Subaru uses a two stage cat converter. The first converter handles reduction stages of the chemical reaction and then the second handles the oxidation stage. I'm pretty sure that's the right way.
Got to ask this question.
Legacy777 replied to sisu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey started in 1990 with the introduction of the legacy. it went through some revisions/changes in 95 I believe, and think they ended it a little while ago. the boys on nasioc would probably know when it ended.
