Idle Trouble Rev n Stall? 91 legacy LS
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere was this part located? Can you find where it is on any of these pictures? http://www.main.experiencetherave.com:8080/subaru/images/injectors There is absolutely no electrical connection the ECU has with tire pressure. I'd say what you experienced is pure coincidence, and/or the ECU finally had enough drive cylces of everything being ok for it not to freak out.
Comptaible Transmisions?
Legacy777 replied to Danbob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike I said, the part #'s they gave you are either bogus, or someone screwed up. They are not valid. You can check them yourself at www.subaruparts.com Yes, you can tell what gear ratio the trans is from the outside, if you can find that info I mentioned. That number should be on the transmission somewhere. Thawa, what info are you talking about? gear ratios or part #'s? Gear ratios I pulled from the FSM's, and verified/feel comfortable with after talking with several owner's of various MY's. Part #'s.....I have the factory part book....plus can subaruparts.com to verify the #'s.
Legacy777 replied to Danbob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBTW.....those are not valid part #'s. Not quite sure what they relate to, or where you found them I doubt you'll find the orig part #'s. You should be able to find a # on the trans that starts with a TY or TZ or something like that. If you can find that #, I can tell you what year and model the trans came out of, as well as final drive ratio.
Legacy777 replied to Danbob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90-94 MT non-turbo trannies had 4.111 final drive ratio 90-91 AT non-turbo trannies had 4.111 final drive ratio 92-94 AT non-turbo trannies had 3.900 final drive ratio 91-94 MT & AT turbo trannies had 3.900 final drive ratio
Check Engine Light
Legacy777 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope......not unless you have a problem, or sensor that throws a weird signal. Unplug the tps or other various sensor with the car running. CEL should come on.
Legacy777 replied to Danbob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to swap rear differentials to match the 3.900 gear ratio, you can do that. Everything should be compatible then. You'll just have a different final drive ratio then you did before.
"Check Engine" Light and weird Idle
Legacy777 replied to Happyhighguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the first gen legacies you can check the codes yourself. Info is on my site.
Need AC retrofit help from pros 90 Legacy 134a
Legacy777 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it work before the conversion at all? Sounds like you've replaced a lot of stuff. Could be evap core, expansion valve, or possibly temp sensors related to the ac system.
91 legacy autotransmission or engine problem?
Legacy777 replied to legacy888's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a littel black button with a red stripe at the top left of the corner of the shifter assembly. Press that button and you can shift the selector out of park. The click you hear is part of the shift interlock system.
blinking power light
Legacy777 replied to Trinity200's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it's not showing up in the current codes, it just means there's nothing wrong/out of spec. yeah pull the EGI/TCU fuse now, and see if the power light continues to blink at startup.
Where's the Idle Air Control Unit?
Legacy777 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2470.JPG other various pics http://www.main.experiencetherave.com:8080/subaru/images/injectors/
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you're still getting code 41, I'd say it's a pretty sure fire bet the ECU is having some issues. You can clean whatever you want, but you're still going to have issues.
Legacy777 replied to Trinity200's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need to check for previous codes before pulling the EGI/TCU fuse. Previous codes may be nothing to worry about, however it may give you an idea into why the power light is going off.
93 legacy cruise question
Legacy777 replied to dasoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes you will need the cruise brain. I believe it is just to the right if you took the glove box out.
Retieved Error Codes-now what?
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe canister purge solenoid you can let go, it's just emissions crap. The knock sensor however I'd probably suggest replacing. My bad on the knock sensor price. You can get one for around 40 bucks from subaruparts.com part # is 22060AA031 http://www.subaruparts.com/cart/?pn=22060AA031+&submit.x=6&submit.y=1
Legacy777 replied to legacy888's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be coolant temp sensor, or possibly torque converter lockup solenoid.
help 90 legacy wagon overheating
Legacy777 replied to subaru5555's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you recently replaced the thermostat? Or has it been replaced at all. Any thermostat that is a non-oem unit tends to have issues. They are different shape, size, and have different characteristics for how they react to temp changes, etc. May be worth checking. Also suggest checking the things THAWA suggested.
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe canister purge solenoid is part of the evap emission system. It sits under the pass. side intake runners. it's about 100 bucks, and is something you should be able to replace yourself if you have a little mechanicing skills. pic http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2471.JPG this pic, it's the sensor with the blue connector. http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2470.JPG the knock sensor is about 60 bucks...maybe less I think. The old sensors tended to crack and give you CEL and other issues. The new sensor has a white connector. Again, it's not overly difficult to replace if you have some mechanic skills pic http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2481.JPG
Legacy777 replied to Trinity200's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you get the code checking procedure from my site? Did you do the previous codes check as well? You may want to try that as well, also you may want to try resetting the tcu. You can do this by pulling the EGI/TCU fuse out for 15 min. The number of blinks of the power light at startup (16) is a default blink sequence to let you know the TCU found a sensor or received a signal that is out of spec. The 16 really doesn't mean anything other then that.
How do I get 93 Legacy ECU codes?
Legacy777 replied to SVX_commuter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome
Where is that website?
Legacy777 replied to jmlaser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis it? http://wac.addr.com/auto/obs/obs.html
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa/f learning control is the ECU. That's a rather weird code to have show up. After you cleared the other codes and ran d-check, did the car stall and run weird? How has it been running since you cleared the other codes? Did any other codes come back after driving it for a little bit?
tranny failed on 91 legacy
Legacy777 replied to glyfx3d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgas mileage unfortunately is not really as good as some of the other manufacturers like toyota or honda with the same size engine. However the subaru motor is more powerful.....it's a trade off I guess.
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbefore you go replacing parts, I'd suggest resetting the ECU, and see what codes pop up again. You may also want to run the d-check mode. Instructions are on my site.
Power Steering woes... can I get some advice?
Legacy777 replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah.....the 90-94 legacies are all the same, and I'm pretty sure there's no difference between turbo and non-turbo cars.
