Horrible hesitation off idle. New to board :D Hi
Legacy777 replied to Boosted5speed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the CEL is flashing there is a code stored in the computer. Pull the codes via the information on my site. Once you've done that. Reset the computer, drive the car, if you get the CEL again, pull the codes and compair them to what you pulled earlier.
Help won't start and it has to be done today
Legacy777 replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvalves will be fine....it's a non-interference engine
Does Whiteline make a bushing kit for the 1st gen turbo Legacy?
Legacy777 replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM bushings are rubber....performance bushings are typically a harder rubber compound or polyurathane.....both flex less and allow for less play under cornering....however they will transmit more road noise/vibration to the car. You'll mainly notice a difference on the older cars where the bushings are just old and shot.
Legacy777 replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you had the battery out.....that should've cleared the codes. When you try to start it....what happens? Does it turn over, and just not start? If you check the codes after reconnecting the battery, it should display if there are any codes stored. If the IAC valve is out of whack, it's possible the car won't start. You can try just completely unplugging it, and then try starting the car.....that'd tell you for sure. If the car starts with it unplugged......then you found your problem.
Legacy777 replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is no egr valve on the first gen legacies. Have you tried resetting the ECU? It should clear any outstanding codes that are not present. If you do clear them, and they still come back, then you still have problems with that particular sensor. Have you looked at the IAC valve. that's what code 24 is?
Legacy777 replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes.....the bushings are pretty much the same as the first gen imprezas. So any bushings you find for the 93-01 imprezas will work on the legacy www.isrperformance sells the bushings
93 Legacy Wagon Rear Tire Wear
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can move things a little bit when loosening the strut bolts..... They do make aftermarket camber bolts you can add which will give you a little adjustability.
transmission swap
Legacy777 replied to maddog_4650's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they were both FWD or AWD, you could do it....They need to be replaced with like transmissions.
will 91 2.2l fit a 93 perfectly
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere's some very minor differences, but they should be completely swappable.
91 Legacy hesitating
Legacy777 replied to arracado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThree wire does have a ground, but it's for the heater. The sensor grounds through the exhaust itself. Over years of rust and what not, continuity between the exhaust pipes and the motor will degrade. The four wire has an extra ground for the sensor itself to ground through.
93 legacy
Legacy777 replied to jeff57chev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you checked the codes again to make sure there's no others in there? Also, did you remember to disconnect the connectors after you pulled the codes?
92 Legacy fuel sending unit trouble
Legacy777 replied to 4FOR4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool, yeah send it over when you get it scanned and I'll put it on there! thanks
what size bolts
Legacy777 replied to WRX1AB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure anyone's going to have this info. Can you take another stud bolt out, take it to a hardware store and use it for comparison? Or take the nut off and check it with the hardware there. You may want to search online, maybe you can buy a helicoil set online, or even from the states and have it shipped.
really newbiwe ?
Legacy777 replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg
JDM Headlights
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif they're jdm lights the cutoff will be on the wrong side, and really shouldn't be used on US spec cars.
2000 2.5 RS turbo install ?
Legacy777 replied to rguyver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah you're going to need some form of rising rate fuel pressure regulator, unless you get an upgraded fuel pump of some kind. Have you hooked up a gauge to the fuel line and watched what the pressure is at idle, and when you hit boost?
Front turn signals out (91 Legacy)
Legacy777 replied to snowmoa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm assuming you have a 91 US spec legacy correct? I also assume you're talking about the corner lenses right next to the headlights correct? If so....they are not meant to blink. The turn signals for these cars is in the bumper. You can see a nice pic of the lights on my car
trans swap - 99 AWD 5spd into a 95 AWD auto?
Legacy777 replied to Dennis ex24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou will have to do some tweaking with the neutral safety switch as well as reverse, and park inhibitor......all shouldn't be too big an issue. ECU....really depends....as long as you have the MT/AT identifier pin on the ECU you should be ok.
91 legacy (2.2) wagon consumption?
Legacy777 replied to anaphe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's not bad at all...my 90 sedan gets 21-22 in the city if I'm lucky
Legacy777 replied to Dennis ex24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDave's writeup is pretty good http://legacycentral.org/library/transmission/convert.htm
JDM Headlights
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat third bulb is a euro style parking lamp light. In japan and europe the turn signals are where the corner lenses (parking lamps) are for the US cars. Since they still need parking lamps, they are integrated into the headlights.
how do I find, TDC on piston #1 for timing?
Legacy777 replied to Tricky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you are just changing the t-belt.....there's absolutely no need to TDC the engine.....just get all the alignment marks on the cam & crank lined up and your golden. TRUST ME! I just did this job, and was quite surprised at how easy it was. You do need to make sure you pick the right marks and align them to the plastic covers. But other then that. It's simple.
Will these fit my '92 Turbo?
no these will not fit. The struts may possibly work....the sway bars will not work. Some of the guys on the legacycentral bbs have used WRX struts & springs......they however have a different spring rate.....which may make the car sit funny.
what soob has 2 piston calipers
Legacy777 replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only first gen legacy 90-94 that had twin piston calipers up front was the turbo legacy. Assuming you've swapped a standard legacy hub over, you should be good to use those calipers. You'll need at least 15" wheels to clear the calipers. You need the calipers and caliper brackets. The brake lines will be fine.....and you'll need new brake pads.
Legacy offset and bolt pattern
Legacy777 replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas mentioned 18's are going to be a little on the big side. Also, 8" & 9" rims are way to wide. You'll rub for sure. You should be fine with some 17 x 7" rims and tires that keep your overall rolling diameter the same as the stock tire.
