93 Legacy Fuel Pump & Starting Problems
Legacy777 replied to trs64's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to my site, notes & tips section, engine related. Read the info on how to pull the codes from the ECU. Pull the codes, reset the ECU.......drive the car....then pull the codes again to confirm which ones are truly causing a problem.....report back....and then either replace the part or take it to a shop and tell them "I want you to replace this part" If that's the case I suggest buying the part yourself and giving it to them. Cheaper that way.
90 Legacy In Accident
Legacy777 replied to biscuitb32's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah if the core support is bent beyond bending it back....you'll need to cut the old one out and weld a new one in.
Legacy speedo gear ??????????
Legacy777 replied to Esteban32696's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you absolutely positive that is the problem? The speedometer base is a very common point of failure for these cars. I replaced mine last summer. I was driving along and all of sudden it just died. If you haven't pulled that base out and confirmed it is still working. I highly suggest you do that. pic of the piece in question http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg
Very wierd handling problem with '92 Legacy Turbo
Brian, I haven't replaced mine yet. I'd like to do it this summer. I replaced mainly anti-sway bar component bushings. http://www.isrperformance.com has poly bushings. If you want OEM, you should be able to find the part #'s in the pdf parts manual.....if not let me know and I can help you....it's not exactly the most intuitive thing to look through....plus I've got a hard copy too, which makes it easier. More then likely you're goin to be around $250 for all new bushings in the rear for the lateral & trailing links.
'92 Legacy Rear bushings
You will need a press to get the bushings on the trailing arm for sure. The lateral links you might be able to get by without one...but it'd be far easier. My suggestion would be to dissamble yourself....take all the parts to a shop, have them press out old ones & press in new ones.....then you reassemble. That will save you the most amount of money. About the front......you might as well do the front.....it's only 4 more bushings in total. this pic should help. numbers 6 & 7 are the bushings for the trailing links numbers 4 & 5 are the bushings for the lateral links numbers 1 & 2 are the bushings for the front A-arm. Those are the bushings I would replace. So you'd need 2 (# 6) & (# 7) bushings & 4 (# 4) & (# 5) bushings. and if you do the front..... 2 (# 1) & (# 2) bushings. This page gives prices and drop down list of the different stuff. I'm not sure I'd mess with any of the other stuff...but that's me...especially if you're strapped for cash http://isrperformance.com/scripts/details.cfm?Item=PFF69-PFR69_legacy
92 Legacy Sensor question
Legacy777 replied to boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplacing the sensors is a little more difficult on the 90-94 legacies......the cam sensor is pretty simple and has been updated so there is a plug at the sensor and the connector. The crank sensor however you have to fish the connector/wire under the intake manifold....but it's still not a hard job. The new parts won't work on the old cars....... again....please try to keep all related posts in one thread.
95 Subie Parts fit 92 Subie?
Legacy777 replied to boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the part #'s I posted above and ask the parts dept if they cross-reference. If they don't......they probably won't work. BTW.....please keep all related posts in one thread. Thanks
Legacy777 replied to boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok I lied......I don't remember spending that kind of money when I replaced mine, but apparently I did crank sensor part # is 22053AA010 updated cam sensor part # is 22056AA070
Legacy777 replied to boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaruparts.com & http://www.1stsubaru.com
yeah...forgot about that......that will mess with the damping though.....and it may give you some unexpected handling results.
Poly bushings do not deform as much, hence stiffer. However some people report squeaking from them.....I have some poly bushings and properly greased, I haven't had issues. I would not recommend replacing just the fronts or the rear struts. You'll get some really funky ride characteristics. I had a set of monroes on the front and kyb's on the rear.....the car had crazy oversteer.....not good when you don't want it. There really isn't any that I'm aware of to raise the car..... You could probably get a scorpion lift....that's about it.
Water Noise from heater core
Legacy777 replied to Rich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup.....mine is bypassed. However that line also goes to the IAC valve.....and is one of the lines that was open......so....I'll try and do the bleed thing with the front end jacked up to try and get it as the highest point.
Legacy777 replied to Rich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine is making the same gurgling sound. I've noticed it recently. I probably should try bleeding the system again. When I did my t-belt this past weekend I did notice the overflow resevoir was at the low mark....so I did fill it back up. I'll bleed the system and see if it goes away. I suppose it's very possible for an internal headgasket leak. However I may have introduced air into the system when I did my injectors a while back.....and never completely got it out. I may try bleeding it tonight. I want to go for a drive tonight. I haven't noticed anything out of the ordinary in terms of overheating or high temps......
check engine, subaru dealership scam?
Legacy777 replied to kirk25h's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can find all the code information as well as reset procedures on my site. Go to the notes & tips section. Also to reset the ecu you can pull the EGI/TCU fuse for 30 min. I believe it's fuse # 14 in the dash fuse panel. Once you have the ECU cleared....recheck the codes and see what comes up.
'92 Legacy Turbo Sedan has ABS light on.
Yeah legacy brakes are so freakin simple.....just like changing the oil. I can do it in like 15 minutes.
Engine RPM's dropping
Legacy777 replied to Rich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you haven't done a tune-up recently.....I'd start there....plugs & wires, and all your filters, & pcv. I'd also run a tank of fuel system cleaner through. You may be having issues with the idle air control valve. They can be cleaned.....which might help. Or possibly a coolant temp sensor issue....
Yeah check out all the scans & pdf's on my server...... a lot of good info on there. Struts.....look at tire rack. GR2's are like 68 bucks on there I believe. Or if you want adjustability, go with the agx's. As for bushings.....might want to try some of the whiteline stuff, and or sti bushings..........or just get oem ones. I believe http://www.isrperformance.com has a listing of the different bushings that whiteline offers. they are polyurathane bushings. Not sure if you want to go that route or stay rubber. Opie on the bbs posted a thread with a fair amount of the hardened rubber bushings. He did something very similar with his turbo legacy.
you talking about dave's library or the stuff on my server? What weren't you expecting price wise.....the bushings or struts. The gr2's should run you about 65-70 a piece....which is pretty normal. I haven't priced bushings, but I'll probably end up replacing all the bushings on mine this summer.
91 legacy 2.2l knock sensor
Legacy777 replied to deane1935's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2481.JPG
You should be able to pull the codes from the abs computer. The light on the housing should blink a stored code. Computer is under pass seat http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/absdiag.jpg
Lash Adjuster Woes
Legacy777 replied to ejether's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsee if you can find seafoam near by. http://www.seafoamsales.com The stuff works wonders, and you can leave it in the crankcase....at least for a little bit.....it doesn't say how long...but I ran it in mine for a little bit to clean things up. Other possibility is that the lifters are just toast and you need new ones......
Is it possible to convert your transmission?
Legacy777 replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://legacycentral.org/library/transmission/convert.htm
Brian, You'll find http://www.bbs.legacycentral.org to be very useful/helpful.... as well as these little goodies from me http://www.main.experiencetherave.com:8080/subaru_manual_scans
Replaced sensors/solenoid.....NO power left
Legacy777 replied to Tricky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease refrain from posting several threads pertaining to the same thing. Please keep them in one thread, and if your existing thread is not quite on topic for what you want to post, but still has info in it...please link to it in your new thread Thanks http://www.ultimatesubaru.org/forum/showthread.php?s=&threadid=13564
2.2 Oil Pump Oring
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid he say how he knew the backing plate was leaking? Honestly Oil will be all around in this area of the pump......it will not be a perfect seal between the backing plate and housing. As long as the screws were tight.....I wouldn't think there to be a problem....unless something was worn out of spec.....I don't know....I didn't see any problems with mine.
