90
no, transmission type does not matter, unless you specifically need the cooling tubes for an auto... you can use the same radiator in a manual just fine, just cap the tube ends to keep dirt out (they should come with caps on them) It is far more cost effective for the manufacturers to make one radiator that will work in both applications than to make 2 different versions.
laugh all you like, but i hope you never have to try to deal with it - it is a pain in the backside. apparently he let a bad ps pump go for too long and got a lot of air in the power steering system... to the point that it was bubbling up and pushing fluid out of the reservoir when the car was turned off. yes, it does happen. I don't drive this car, so I had no idea things were that bad with it, and he never says anything until whatever is really bad.... so... when you change the pump, obviously, you also introduce air that has to be purged out - before actually running the car - it can be a process to get it all out.. (air needs to be purged before running to avoid damaging the new pump - ie: running it in a "dry" condition) - and even more so when an o-ring is compromised letting air in. and for the record, this is on a remote reservoir ps system, not one with the reservoir on top of the pump
if you can get your hands on a used genuine Subaru unit, you can always have it rebuilt by a local independent rebuilder (starter & alt shop) - that is what I did with my 95's unit.. yeah, i put a parts store one in temporarily while I had the original done and it worked fine for that.. Once i got the rebuilt unit back, it went in the car, and the parts store unit went back in the box & up on a shelf - still have it, i think, lol all in all, it was a little bit more cost wise to have it rebuilt locally, but i ended up with a much better unit than the parts store one, and i supported a local business.
oh, and to the OP - get a proper charger on that battery - do NOT rely on the alternator to recharge a dead battery. Alternators are not meant to charge dead batteries, they are meant to maintain a charge on a good battery. a bad battery can kill a good alternator, and a bad alternator can kill a good battery. you need both in good condition for things to work properly.
had a similar problem with my 95 Legacy at one point.. was having charging problems.. alt would test as fine, in the car, at the parts stores - multiple times at different stores.... I got frustrated and yanked the darn thing out and took it in to a local starter/alternator rebuilder... when I put the alt up on the counter a couple of bits fell out (diodes?).. He was like, yup, you need an alternator rebuild.
Funny Story
heartless replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
LOL, I have a house with those old style locks (box that is screwed to the outside of the door) - no coins found to date.. but have found all sorts of other evidence of kids - drawing on walls in closets, small toys in heat registers, those sorts of things. -
they can only show stuff that actually gets reported. owner goes to a small independent shop instead of the dealer for routine work (or does it themselves), chances are said work will not be reported, therefore, no record. routine maintenance is not what I would necessarily be looking for on a carfax anyway. They are more useful for accident info, flood damage, that sort of thing.
ya'll need to just stop responding to this crap, dont click on the video, just flippin ignore it and let it go away. Absolutely NOT. the best way to deal with this is to completely ignore it. Don't follow the link, dont view the embedded video, dont do anything but ignore it. and to the OP - GD said it best, so I second his statement.
