Everything posted by rcoaster
05 3.0 vdc slight miss, coolant smell (searched)
rcoaster replied to ampsucker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrection- Subaru has said that 92 Octane is recommended. The did not say it was required. When I first got my 04 H6, I used 92 Octane for a while, then when the gas prices skyrocketed, I switched to regular. The car ran so-so for a while then once the computer adapted to the lower octane rating, it ran fine. It only stumbles a bit if you floor the throttle quickly from idle. I figured out that if you start out gently, then give it gas quickly, the car will accelerate quickly without any hiccups. One thing I've realized is that it's not the engine and gas you use, it's how the computer handles everything, and it's not as good as the AC Delco computers. The AC Delco ECU's have excellent response time.
2.5 Outback Advise
rcoaster replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr for a little extra money, and without playing Russian Roulette wether you will get HG issues or not (my previous car, a 96 Outback with the 2.5 didn't have any HG issues at 136,000 miles before I traded it in for a newer one), do what I did- I went for a H6.
Fuel filter 05 legacy
rcoaster replied to vinder1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think that's really a fuel filter. More of a tank sediment filter to prevent the pump from picking up large particulates. I think with the 2005 and onward, they use a filter cartridge that goes onto the pump body. If you can't find an inline canister in the engine bay, usually mounted on the strut tower near the brake master cylinder, then they might have moved it somewhere else.
tribecca
rcoaster replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen they first came out, the local dealer did a lot of promotions on the car - test drive and get a 25 gift card and enter a drawing to win one. I test drove one, and didn't like it. The engine was underpowered, would rather go for the 5 seater instead of the 7 seater, and thought the dash layout was poorly designed. When I put my hands on the steering wheel, they are at the 10 and 2 o'clock positions, and my thumbs were actually blocking my line of sight to the fuel and temp gauges. They were placed too low. Aside from the poor dash design, the inside was very nicely laid out and that was the only good thing about the Tribeca. I see far more Outbacks and Forresters around here. I saw a few Tribecas when they first came out, but then they kind of went in hiding. At the dealer where I take my car for servicing there are only 2 Tribecas on the lot, and about 12 Outbacks and 12 Forresters on the lot. It seems that the Outback and Forrester are the top sellers at the dealer. I hope with the re-design, the Tribeca will sell better. I'm hoping for a Subaru with a higher towing capacity than the measley 3000 pound limit. The Tribeca would become a full SUV, while the Outback would hold the cross-over market.
SOHC 2.5L with Funky, Cycling idle ???
rcoaster replied to subaruVWnut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the IAC valve. It might be just dirty and can't meter the correct amount of air into the intake.
02 Outback 3.0L H6 SFI DOHC 24V
rcoaster replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, they reccommend premium. I've been getting away with regular gas, and the car runs fine. You will like the H6- more power, and a very refined engine.
ABS light on. Nut holding rotor came loose?
rcoaster replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEither your mechanic is wrong, or the other shop removed more stuff than necessary to replace the rotor. I've replaced the front rotor on my former 96 outback (before I traded up to a 2004) and the rotor replacement is super easy. It was just loosening the two big rusted bolts that holds the caliper to the spindle assembly was the hardest part. The rotor is simply held in by your tire! The rotor is actually a separate peice from the hub itself. I've heard some common problems is that the rotor gets somewhat stuck on the hub due to rust. A few taps with a rubber mallet is all it takes to break it free. For my car, it was just a firm tap with the palm of my hand and the rotor freed itself from the hub and the rotor slid right off. The abs teeth are on the hub itself. No axle nut to remove. I would suggest that you buy a Haynes manual for your car. You will be suprised at how some stuff are easy to replace on your Subaru. If you still want to have a mechanic do it for you, at least you are armed with information how to replace things and you will be able to tell if your mechanic is right, or trying to milk money from you.
headlights out, high beams still ok
rcoaster replied to Peter Shaw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the bulbs first. It might be something as simple as that. If that doesn't work, the next step would be to check the relays. They're located on the fuse block in the engine bay next to the battery.
Best brake pads
rcoaster replied to jpsnowbumb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would recommend getting ceramic pads. Napa's Ceramix pads are excellent. I have them on my 2004 Outback and they work great!
PLEASE HELP... car won't start...:(
rcoaster replied to Mjez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat about the engine temp sensor? I've heard that this sensor could cause difficulty starting.
Cold Weather, but my heater doesnt work. Any help would be apreciated.
rcoaster replied to Faithbleed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you say electronic, do you mean a digital readout for temperature? If there is, check for a motor that operates a mixing door that allows air to bypass the heater core. See if it is functioning or not. Also, check to see if the venturi tube that allows air to pass over the sensor so that the door will compenstate. Try turning up the heat all the way up and see if the mixing door will activate. Also, when you turn up the blower does the blower spin up and down? If it does, you may have a blockage somewhere that is preventing the flow of air. If the blower doesn't spin up and down, then there might be something wrong with the resistor pack or the electronic control unit that activates the blower. Worse case scenario could be that the control unit could be faulty and may need replacing.
Side Marker Lights Won't Turn Off
rcoaster replied to windrunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats. You are no longer a Subaru Virgin. Now, don't feel so violated!
01 V6 Outback vs 02 4cyl Outback
rcoaster replied to legacy48's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can run regular gas on a H6. Subaru "recommends" premium, but I've been running regular and the only thing I noticed was a hestitation when the engine is cold and a very small power loss, but it runs fine. With a turbo, you must use premium. The engine is more smoother and refined.
Used Outback Help, Please!
Just wanted to point out that I used to have a 1996 Outback with the 2.5L, and at 136K it didn't have any headgasket issues at all! I think the majority of the complaints come from 97-99 where the engine was tweaked a bit compared to the 1996. I really haven't heard from anyone who has a 1996 2.5 complain about headgasket issues. -RC!
Look Ma, Only One Door Lock!!!
rcoaster replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHuh?
can I turbo / supercharge an '00 OBW?
rcoaster replied to cidion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's why I got a H6. While premium fuel is recommended, I can run it on regular gas to save money. I've heard of others running thier H6 on regular gas with no problems.
rcoaster replied to cidion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't recommend it. With a car with high mileage and an oil leak, I would recommend against it. Also, as everyone said, there's a lot of work involved in doing the upgrade. Upgrading to a turbo is fine on a low mileage car but you are upgrading an engine that isn't designed for it. I would recommend looking for a used 05 Outback XT and trading in your 00 for the 05 XT. The XT is turbocharged and the engine/tranny is already designed to handle the extra power.
PA inspection is stupid
rcoaster replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWait a minute.. If the heated seats don't work, it fails inspection? If the radio doesn't work, it fails inspection? If one of the vanity mirror light bulbs is burned out, it fails inspection? Now that's retarded...
02' H-6 Idle Problem
rcoaster replied to soobcollektor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Idle Air Control (IAC) valve may have some carbon deposits on it, causing the valve to close improperly, causing a high idle and fluctuations. Simply remove, clean, and reinstall and that should help.
OK where to start
rcoaster replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince you removed the rear driveshaft, that's where you're wasting gas. The way the AWD works, it starts off with 50/50, then transistions to 90/10. So, without the rear driveshaft, you had about 10-50% power going to thin air. Once you get the torque bind cleared up and the rear driveshaft back in, you get all the power coming off the tranny going to the wheels. One quick question, didn't you try the FWD fuse? You could do this without removing the rear driveshaft. The FWD fuse disengages the transfer clutch (while the engine is running only) and makes it a FWD drive car. People here who have complained about the torque bind use the FWD fuse as a back-up so they could still get around and eventually to a shop to have it resolved. RC!
Tickled Silly!!!
rcoaster replied to Rodney7286's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly if you have a 2nd generation Outback (2000-2004). They switched to swing-away mirrors in the 2nd generation, and used body color shells for the mirrors. In the 1st generation Outbacks (1995-1999), the mirrors are not swing-away, and all of them were black. Just look for an outback limited, since those came with the cold weather package.
speedo stopped
rcoaster replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup- no more speedo cables.. I think Subaru did away with the speedo cable for two speed sensors- one on the front axle and one on the rear driveshaft. I beleive this is on the automatics. Since the AWD is electronic on the automatics, it uses two speed sensors to detect wheel slip, and feeds the info to the TCU and the ECU. It's also a data feed for the speedo and the cruise control. I think the speed sensors are wired into the ECU and then the ECU sends an signal to the speedo. That's why you have a CEL. RC.
Dumb thing to do..Cigarette lighter Help please !
rcoaster replied to subjfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's something fishy about that story. I mean, how can you swim in a swimming pool in -18 degree C ? It would have been frozen over if it was outdoor, and if it was an indoor pool, couldn't your gf use the blowdryer at the location that had an 120VAC outlet?
2005 Legacy 2.5i cruise control shuts off
rcoaster replied to banny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow can you tell if the gas pedal is depressed? Juan Yeah, I was wondering too because the 2005's are "fly by wire" systems. Your gas pedal doesn't have the throttle cable but a potentiometer attached to it which in turn, controls a servomotor on the throttle plate. You don't have the feedback with cable actuated systems. My 2004's crusie control is a fly by wire system, but still uses the actuator cables, so I do get the feedback.
ring of wear around me tires
rcoaster replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet's see... You're 16. Yup. That explains it. Have you driven your parent's car? If you did, that would explain it too. You should trade in your Outback and get a Civic instead. Nothing's wrong with the car, but there's something wrong between the driver's seat and the steering wheel.
