Everything posted by Dr. RX
	Once I pull them apart, I only put the LSD back together. I recycled a bunch of them about 6 months ago.
	Yes, I do it all the time, infact I have two of them to do for someone right now. You need to take the LSD diff from 3.7 ring gear and bolt it to the 3.9 ring gear, you just need to grind a few spots on the 3.9 case, those spots will be obvious.
				problem rx
Dr. RX replied to normand's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
RX????? What country are you in??? What about the front wheel bearings? Or maybe (but I doubt it) the wheels are out of balance. -
	Unless it was installed later, no RS came with a D/R tranny. In 1990, there were a few turbos, none in 91. The turbos had S/R 5 speeds or automatics. The turbos are actually rarer then the 89 1/2 Black RXs. I have only seen one, but I have seen 3 of the black RXs. The emblem changed in 1990, it just had the stars, with no lines connecting them. I have a set of the gold emblems for this car.
				Any Recommendations For Window Glue?
Dr. RX replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I get mine from Wesco, but it is about $20 a tube. -
	OK smarty pants, just where are you going to put the second turbo. I once had one of these engines and was going to install it into an EA series car. I am also a metal fabricator, so I know what it takes to fab new parts to make this work. The car that I was using didn't have that booster on the brakes so I had even more room to play with. Without dropping the turbo down so that it was right next to the tranny, there was no place to put the left side turbo. And that close to the tranny would only cause tranny heating problems. So, now you are talking about putting it into a car that has even less room the the car I was going to use, so tell me where you are going to move the left side turbo to and not create additional problems.
	Well, incase you are interested, I know that there is a front clip from a 95 WRX (260hp) coming into a shop in Tacoma early in October, they want $2500 for it. It comes with the complete front end of the car (from about 8 inches back from the door post, forward) and the complete drive train and rear suspension. Basically everything that you would need for the conversion. If you are interested e-mail me at corkysrocks@isomedia.com .
	An EJ20TT wouldn't fit, for the same reason it won't fit in any other left hand drive car. The EJ20G that came in the WRXs had more horsepower then the EJ20TT (by the way, the is not the correct engine code, but I can't remember the correct one at the moment), and the EJ207 even more. The twin turbo was created with a low end and high end turbo to compliment each other and give the engine a broader power range, not just more horsepower.
	Boy, I'm confused now, Subaru already competes with Audi and BMW, have you compared them lately. As for Joe Public not knowing about the wonders of Subaru AWD, I really think that Joe Public could care less and doesn't want to be told. Subarus, like Saabs and Volvos are niche cars, they appeal to a small group of people who appreciate what they see in these cars. Subaru is not, and I hope it never will be, a car for the masses.
	I wonder, if a wire got caught between two gears, would it make a similar bend as the one at the end? And if at that same time that wire got pulled around the shaft that the gear was on, would it not make a larger curve similar to the one on the piece in the photo? This is probably not the whole spring, but just part of one that somehow came loose and entangled in the gearing causing the bends and the shortness from being cut by gears meshing with others.
	OK, I broke out my 1991 Legacy FSM and looked in section 3, the trannsmission section. I scanned a few pages to show you the syncro springs (retainers) I was talking about. They may not look exactly like what came out of the tranny, but then it probably didn't come out the way it was suppose to and got bent and broken. Some here are the scans. http://corkysrocks.net/springs1.jpg http://corkysrocks.net/springs2.jpg http://corkysrocks.net/springs3.jpg Hope this helps.
	Merely repeating the assumption made. You know, your head will stop hurting when you stop beating your head against that wall. Are you willing to bet money that it didn't come out of the drain hole. When I first saw it and the explaination of where he found it, I thought it might be a syncro retainer, but then I'm not familiar with the inside of a Subaru tranny (at least not yet, I have two that need rebuilding), so I didn't comment. If it were a syncro retainer, it might answer the noise question.
	These were standard trannies in the EJ18s Impreza Wagons in Europe in 94 (not sure about other years), in Japan, there was a special Impreza wagon (can't remember the model number at the moment) that these were standard on. Since these cars are not the ones in demand by those who import JDM engines and trannies, we don't see them here. I have tried to get several people that I know who import JDM engines to try and get these, but no luck yet.
	Jason, you might have to go to 2002 to get the WRX, I believe that was the first year that they were imported to the USA. I prefer the older style, the GC series cars, so anything 2001 or older would be my choice. If you get a 2001 RS you should be safe. I think alot of the problem people are having with the second gen EJ25 are self inflicted, that is a nice strong engine. I believe the wagon version of the RS was called a TS.
				Wanna know why I named my new hatch "Ozy"?
Dr. RX replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If anyone took me up on my bet, looks like I won. -
				Walker Wheeling run On The Jeep Trail
Dr. RX replied to one eye's topic in Meet n' Greet. Your USMB Welcome Center
I'm going to copy this and put it with all my historical documents for safe keeping, this is truly a historical document. -
	Emily, the engine harnesses are almost identical, it is the body harnesses that are the problem, they aren't even close. I haven't looked, but I would bet that the pin out on the ECU is different too, so you just couldn't plug an ECU for a 2.2 into the 1.8 harness. I'm sure that there are a lot of people who have done this, and if you already had an Impreza with the 1.8, that might be the way to go, but if you are looking for an Impreza and plan to do the conversion later, why not save yourself all the hazzles and find one with a 2.2 in it already.
				EA82 86 OHV Carb -> 88 OHC SPFI
Dr. RX replied to singletrack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The car pictured above should have an EA82 (OHC) engine in it, unless it came from some third world country. But if it was imported to the USA originally, it should have the EA82 in it. If not, then someone has done a conversion. -
	Look for a 'L' model, not a 'LS', the 'LS' is the one with all the bells and whistles. If I were doing it, I would replace the whole wiring harness, but then I would probably have found a 2.2 car before I did that. LOL Food for though, I have an EJ22G (USDM Turbo Legacy) engine about 95% complete and a complete front wiring harness from a USDM Turbo Legacy.
