Everything posted by TurboSPFI
SPFI a/f q's
o2 sensors are made to have a "swing", this is the rich/lean swing as you describe. By having voltage vary from 0.00 - 0.999, it bounces from rich (0.99 volts) to lean (0.00 volts) to aquire an average 0.45 volts, equivelant to 14.7:1 stoichiometric ratio.
has anyone ever...
i was thinking the compressor side, sorry i didnt specify
has anyone ever...
has anyone ever.. painted their turbo? thought about painting their turbo? I'm thinkin engine paint, anyone think it wont work pm here!
IHI (RHB5) VF2-39 specs...
bump
Porting/Polishing
is there anything else we need to know? dremel sounds too easy for porting and polishing
Porting/Polishing
I've never ported or polished anything and was wondering if there were any certain processes to follow when doing this. been considering P/P my turbo and heads also, what kind of "grind bits" work best? do i need multiple? how bout carbide burrs? i know they can take alot off quickly, but that might be the issue? how bout P/P my VF2? bore out the wastegate? anything? thanks
still no specs for RHB5's *bump*
gotcha
if it was, it would say VF7 then instead of the VF2 stamped on the thing :-\ (wouldnt it??)
If i can remember right, the RHF's are different than the RHB. RHF = new school RHB = old school Eh, such things as: stock boost setting max avail. boost setting EGT tolerances basically anything that can distinguish specs between a VF2, VF7, VF11, VF39, etc etc etc
mine is the VF2, came off an XT im curious if the VF7 came from wagons? already know vf11 is the legacy turbo already know vf39 is the WRX STi turbo back to the point.. specs! specs!
Rancho Rear replacement shocks
does anyone have these? im certain ive seen posts indicating that people have them but the 4x4 shop i goto doesnt carry a part number for them. Part numbers for the RS 5000's and 9000's would be nice to have Thanks
can anyone find em? im having just the funnest time looking up specs *edit* mainly looking for VF2-7 *edit*
The Brat runs again. thanks to northguy
Tranny?
IHI VF2 RHB5 stock wastegate setting
anyone know what the stock wastegate setting on a ihi vf2 rhb5 is?
1.8 Normal Aspirated and Turbo Differences.
well torxxx, why would i bump it up to 10 psi if im already content with what i have now?
anchorage
Northguy - u know my digits..:cool:
I couldnt disagree more.. You dont need all of that. I run a 9.5:1 now (SPFI) @ 8 psi without any problems
EGR Valve
those solenoids go bad all the time
anchorage
alaska that is
has anyone thought of..
basically, when you get into deep mud, anything that can drag WILL! the diff bracket tends to drag alot... guess ill be doing this mod myself and reportin back
turbospfi conversion
nope, wouldnt be a bad idea though, thx for the idea
could be because im only running 2 psi .. i did run it to 10 psi and experienced some bogging (lack of fuel im guessing) until i turned it down to around 6 psi
havent hit a fuel cut yet
simple.. there would be less drag if the "blades" were 4 inches higher simply by flipping the bracket upsidedown
