jcniest5
Everything posted by jcniest5
AC problem
jcniest5 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, the compressor engages when I turn on the AC, just no cold air coming out. I use a recharge kit with a pressure indicator to measure it. Can there be such thing as a bad compressor even if it's engaging fine? -
	If my memory serves me correctly (which may not), I believe you have to turn the engine twice to get to the correct one. I think you may just be on the first turn, so turn the engine one more time, the timing mark should come back to the same spot, which should be the correct one. But like said, my memory may be completely off, but it's worth a try.
	There are three bolts holding the motor to the door panel. I did mine awhile back (the driver side) so I don't remember exactly how each step by step went but I think it was obvious what goes where. Nevertheless, it was a pain to work on it (especially putting it back together). Have someone stand by ready to help because you will need three hands at time. The glass keeps coming down and that is very annoying, so a second person standing by will save you lots of swearings...
	Just an update: Finally had to do it regardless if it was the correct component or not, and it was really the right rear bearing going bad again after only three years of service. Took it back to same Red Rooster's Machine Shop and the guy there managed to break the ABS wheel while trying to press out the bearing. I knew he did it because it was good when I took it there but I asked him to solder it back in place and it works okay so I didn't make a big deal out of it. Other people might have made a big deal out of it. The humming noise is gone now and all is good again (for how long, who knows!). The guy told me that aftermarket bearings usually never last as long as the original (or OEM) bearings. The bearing on the other side still going strong and I'm already putting the second aftermarket bearing on, that's pretty bad longivity. I forgot what brand was the first one, but this one is a Federal Mogul bearing...anyone heard of it? Good or bad?
	Does anyone know if the engine on a '97 Explorer is non-interference or interference? I see a Craiglist local here but I believe the timing chain/belt is broke. If the engine is non-interference, I might buy it and fix it. If it is interference, then I'm not going to bother with it. Thanks...
	Don't mean to hijack this thread, but does anyone know when to replace the idlers (bearing - 3 or 4 of them) without having to take off the cover and inspect them manual/visually? I saw all these kits that have the idlers as part of them and I'm just curious. Should they be changed as part of timing belt change?
	Well, I changed it when I was living in Sacramento, CA, but I'm not sure if it's a CA timing belt or not. My engine has no oil leak, so I hope it will last until summer as I would never do it in the winter (in MN, that is). It's too cold to touch anything when the snow arrives. If I can do it within the next few weeks, I think I still can (assuming snow doesn't show up yet).
	No, I didn't remove any suspension parts. Basically, I lowered the exhause pipe, unbolted all the bolts that hold the differential, then it just came down. I don't want to remove the suspension. Back in '04 when I replaced the bearing, I tried to remove the suspension but was unsuccessful. Too hard to loosen the bolts/nuts without air/power tool. So, if I can't remove the suspension, I guess I have to lower the diff again. Not good...
	Funny I ocasionally have it, too. So far, since about a year ago, I've heard it like five times, usually when I first start the engine (cold, I believe). Sometimes I rev the engine up a little and it will go away, other times, it won't. It would go away eventually. It seems to be coming from one of the sides, more like a valve is locked. You can hear "ta ta ta ta ta...." and no, it's not the regular ta that I hear everyday. It seems to be louder and more noticeable when it sounds. Not sure if I should try to figure out what's wrong or just keep driving until it goes to the grave.
