jcniest5
Everything posted by jcniest5
Guess what...
jcniest5 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wasn't that hard once I figure out the proper way to do it. One of the bulbs was blown and I had to take off the whole cluster again a second time. It was a piece of cake the second time around. The way I did it, I unplugged the speedometer cable from the tranny first and I was able to pull the speedo cable and the cluster further out to insert the end into the back of the speedo gauge. -
Guess what...
My actual mileage is 248,xxx. But since I replaced the speedometer gauge with one I got from a junkyard, it says 145,xxx on it now. I wonder if we are required to adjust the number to match the original mileage of the car or not? Do we? -
Okay, if I will be doing my Wires and plugs, would you guys recommend OEM or aftermarket wires? I know I will be using either NGK or just any Platinum plugs, but not sure about wires yet. The last time I replaced my wires, I did it with aftermarket ones. Should I go for OEM this time? What's special about OEM (other than it being more expensive) vs. aftermarket anyway?
So far, the only item I've replaced is the Speedometer gauge. No sensor of any kind has been replaced yet. The one I will do tomorrow is the Engine Coolant Temperature Sensor. Not even sure if the store I called has it or just the regular Coolant Temperature Sensor for the gauge (and not for the computer-ECU).
Okay, by reading the tech manual, I was able to unscrew out the sensor. I'm measuring its ohms according to the manual, but since I don't have a thermometer, I can't tell how hot or how cold the water I'm putting the sensor into. Just to isolate the problem, I think I'm just gonna replace it and see if it would make any difference. Update: I put it right next (actually stick it into) my AC's vent, which suppose to be around 65F and it's suppose to have a resistence of around 3 Ohms. It stays at 2.4 Ohms, so I'm assuming it's off by at least .6 Ohm. I just hope this is the culprit as poor man is running out of $$ to troubleshoot this car further.
Awhile back, I replaced my 'then' worn-out brakes with some "Silver" class brakes and they would always squeak no matter what I did. I finally got fed up with them and replaced them with some "Gold" class from Bendix and the squeak stopped. No noise has been heard since. Low quality (cheap) brakes have the tendency to squeak. If yours squeak, it could be a sign that they are cheap brakes.
Update: Okay, so I was tired of waiting for the new part to arrive at the dealer, I unscrewed out the adapter and I guess because of carbon/dust/sludge build-up inside the rectangle hole that the speedometer cable inserted into, the cable came out and wouldn't go back in. I forced it in a few times and then it went in smoothly afterward. I put everything back together and now my speed is working, but I continue to get terrible gas mileage. Last night, I took out the battery so the ECU resets itself, this morning, I continue to get very poor gas mileage. Does anyone have any more ideas where I should start checking on this culprit? I mean I could almost literally see the gas gauge moves! It's like the car is literally leaking somewhere, but no, there is no leaks anywhere.
The vehicle itself has 248K miles on it. But I just bought the tranny used back in '05, so don't know how many miles it has. Before that, the 'then' tranny was actiing weird, but if I was smart, I could have just adjusted the Brake Band. I could swear it's just that because when I was replacing it, I could feel the Brake Band screw was really loose, it could turn by hand. According to a tech manual I read, it's suppose to be tight (@ 18 lbs).
Well, I replaced the Speedometer gauge with a used one (assume good) and it's still doing the same thing, remains zero MPH when driving. The Check Engine light went out a few minutes after driving, though, and it remains off. I'm going for the gear driver next (or adapter - whatever it is called). Had it ordered and should be here within a week if not sooner.
