Struts
1 Lucky Texan replied to Sherman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles on the 05's struts? I'd put new on for the trouble.
Aisin timing belt kit for 2012 Outback
1 Lucky Texan replied to Mike V's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas a triple check, search online for the tooth count for your engine. Good to use especially after you turn the crank over with the wrench before firing it up.
Major oil leak has me stumped
1 Lucky Texan replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust make darn sure it isnt' the pressure sender - it's kinda behind the alternator I think.
2008 OB coil?
any oil in #3's plug tube?
1 Lucky Texan replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuh-oh, 'could' be the waterpump. It has a weep hole. Have only read of coolant coming out but, IIRC, it could also leak oil if the the other side of the pump has a bad seal. your engine may be different from mine - plus, seems like your leak could be under pressure and I think the WP's oil side is just splash. anyway, this older thread on another Forum might have some pointers; https://www.subaruoutback.org/threads/3-0-oil-leak-help.312057/
Starts; but let the key go to run position(dies)
is there a 'motor control relay' or similar? Had an old Nissan for my daughter that would intermittently stall - it was a relay dropping-out.
what year/model? if someone were spraying carb cleaner, starting fluid or maybe a stream of propane gas into the intake, would the car try to keep running? any CEL or pending codes?
Best source for axles?
search for videos - soob axle replacement and re-booting.
Sensor readings stuck at ZERO
1 Lucky Texan replied to aschwerin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome of that seems like a vacuum leak but, GD likely has more to go on now so, maybe he will reply. the fact that it was better after the reset does somewhat point to a sensor though......?
97 Subaru Brighton Wagon - If it ain't totalled, well it is.
1 Lucky Texan replied to Jedisir's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXglad you're OK.
1 Lucky Texan replied to aschwerin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso, would be no surprise a '99 needs a new knock sensor. and ground connections refreshed.
Crank but no start
1 Lucky Texan replied to 87r34's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis there any smell of gas at the tailpipe when cranking? if not, you have a fuel problem since it didn't fire. if you do, perhaps the cylinders are flooded. pull plugs to see if they are wet/crank with the pedal held to the floor to signal ECU to stop fueling. It's the 'clear flood' procedure. I suppose it's possible to have multiple issues, so, maybe check for spark.
2012 Outback no crank after engine and trans out
cycle the fob on/off a coupla times - maybe a security feature is in play?
Crank but no start
1 Lucky Texan replied to 87r34's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIACV hose drop loose?
Gas Tank Unable To Fill Without Pump Shutting Off
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a good thread with some great pics illustrating some of the crazy valves and piping involved in the fuel tank's operation; https://www.subaruoutback.org/threads/whats-inside-fuel-tank-edition-leaking-fuel-tank-autopsy.510193/
Looking for vintage KYB applications index
any different numbers stamped on the parts maybe?
Locating MAF sensor on 2003 Subaru Impreza 2.5 RS
1 Lucky Texan replied to Syncert's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe IACV hose is cracked or partly loose? is that timing supposed to be -10 ?
cam tower o-rings
if you have a part number, check ebay UK?
1 Lucky Texan replied to Syncert's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat codes come back (or show as 'pending') after the work that was done? is the car new to you? if not, has it gradually gotten worse or was there a wreck or some work done just prior to the problem?
HI there
details on car? and what are the symptoms of a/c problem. (seems like the blower fan?)
Transmission Issues - 2002 Forester X 4EAT EJ201
1 Lucky Texan replied to shlaggers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall I have to offer is, sometimes a bad throttle pos sensor will create trans problems.
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD - no chance of 'reverse soaking' or somehow flushing the top valves of the tank? Seems like they just gunk/varnish up and some fuel-safe solvent, and maybe a little persuasion with an air hose or ??? might pop them loose. Anyway, my MIL's Forester had that happen (she used here car very intermittently) and it took a LOT or persuasion to get Subaru to replace the tank.
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd consider pulling hoses off the canister while filling, to somewhat prove it was bad. there may be 2-3 hoses on it so, you really need a diagram.
1 Lucky Texan replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have read the the FSM has a weight limit for canisters? - if they are too heavy with fuel, they get replaced. Not cheap. The system in newer cars is supposed to limit the chance for fuel to get in there but....????
Intermittent starter motor issues
battery cables might be an issue, they can be quite corroded under the insulation and limit current to the starter. Feel of them and see if they get hot? Or wiggle them while someone is trying to start the car. Also, whack the starter with a piece of wood - sometimes that will 'encourage' better contact between the plunger's disk and worn contacts. If the starter never responds to that, the issue may be elsewhere.
