No brake pressure
I am unfamilar with models as old as yours - could brake fluid be pooling on top of the fuel tank or inside a crossmember or ????
coolant not returning to readiator
1 Lucky Texan replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhynot didn't mention overheating - but Ido is definitely right about that engine's reputation for bad HGs - maybe this is the very beginning? I'd for sure try a different rad cap - OEM or stant maybe.
2008 Tribeca issues please help!
1 Lucky Texan replied to ashnmason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank's Ido, I should keep-up better with this stuff. I bet they paid a lot and now haven't got any relief. Ashmason, you probably have a warranty if this shop has decent reviews and seems legit, take the car back and tell them it isn't fixed. Give them a chance to make it right. But, you may have to bail-out on them if they seem uninterested or incapable of diagnosing the car.
1 Lucky Texan replied to ashnmason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's a manual? didn't know that was available in Tribeca if so, typical failure symptom for manual's center diff viscous unit is to work OK when stone cold, then grab when warmed-up. a Colorado shop should know this so....I may be wrong. Either get the car up to retroroo in Denver and let Shawn check it out or, one idea, contact user 'traildogck' over at subaruoutback.org - he even does mobile repairs and casts his own line of bushings! Might come down to Pueblo for you....
No brake pressure
no sign of brake fluid dripping anywhere? does kinda seem like master cylinder could be at fault - very old car, sitting unused for a long time....add full travel pedal excursions and I could see the MC seals being bad.
1 Lucky Texan replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa rare condition can occur whereby the bottom of the overflow tube 'seals' itself to the bottom of the o'flow tank. many folks cut the bottom of the tube at a 45* angle. If the tank has debris in the bottom, one way to clean it is with ice cubes, remove it, fit some ice cubes in it and shake them around. make sure the little o'flow tube is clear. The rad cap has a valve 'should' allow one-way flow from the tank back into the radiator - it may be bad which is why we jumped on that first.
Outback Control Arm Rear Bushing Leaking
1 Lucky Texan replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it has only leaked it's fluid and seems otherwise solid, I'd keep driving. I did replace them (sorta twice) on our 03 - if it helps, here's a link to the old thread; (pictures sadly gone - unless there's an image shack hack available for your browser) https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html
1 Lucky Texan replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbad/'improper' cap.
EJ22 Random misfire when warmed
1 Lucky Texan replied to alexbuoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXto me, if the ECU reset didn't help, that points more towards a physical problem. it still may be useful to get live data. A smartphone app and a ELM327 BT adapter or, do as Montana Tom suggested and get comp. readings. Vacuum gauge testing is occasionally helpful.
EJ25 timing belt issue
1 Lucky Texan replied to WillRXsti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can be tricky to burp all the air out of a recently drained/filled soob cooling system. did you replace the thermostat? it MUST be OEM-style (see pic below) jiggle pin at 12 o'clock. get nose of car up on ramps/curb, squeeze hoses, confirm the rad is full with a good rad cap and the overflow tank is at proper level or a little above. Run car till fans come on, rev the car to get good flow, let it cool for hours, check that rad is full, top-off overflow, run again till fans come on, let it cool. Re-check overflow. The system 'should, be able to purge a small amount of air this way. If it still overheats, there is a problem. When the gauge maxed-out, was coolant pushed out of the overflow?
98 Impreza Wagon heat cuts out
the fan cuts off? or, does the fan continue blowing but the temperature is not hot? (why the heater in July ?)
1 Lucky Texan replied to WillRXsti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, belt needs to come off, leave the crank where it is, but re-position the cams , re-install the belt. on my WRX, the DS intake cam REALLY wants to flip - it can be tricky and some folks have tried to use document clips and visegrip pliers, etc. to keep things in line. there are several videos that give some pointers, here's one;
1 Lucky Texan replied to WillRXsti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmore info on engine would help. if you pulled the pin on the tensioner, re-compress it VERY slowly or seals inside can be damaged. search on-line for pics of the front of your engine type for alignment details, maybe a youtube video even. search also for the tooth count. After alignment and pulling the tensioner pin, rotate the crank sprocket with a wrench 2 times to bring the marks back around - do a tooth count to triple check before starting the car.
1 Lucky Texan replied to WillRXsti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit needs to go about 5 teeth more clockwise. there is a groove/dash/line on one of those tabs at the back of the sprocket - it should be aligned with the groove in the cast 'boss' right above where the crank pos, sensor is. the 'triangle/arrow' will be at about 3 o'clock
'04 Outback 2.5 stuttering, hesitating on accel.
1 Lucky Texan replied to heyhar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen the ECU is reset, the car is reverted back to a stock ROM 'map' of settings - ignoring the sensors until after a coupla 'drive cycles' and the montors are complete. That is, the computer has not learned anything from the sensors and starts with a 'locked in' A:F setting and 'typical' ignition advance. If there's little/no difference in how the car runs after a reset, I doubt you have a bad sensor. I think you should perhaps look for vacuum leaks, cap/o-ring issue on fuel pump, dropped valve guide or burned valve, transmission problem ,etc.
1 Lucky Texan replied to heyhar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the problem is gone immediately after an ECU reset (battery disconnect of maybe scanner) it probably is an a:f - related sensor or wiring to one , if not, could be something more a physical nature. Automatic? maybe try the FWD fuse. any torque bind when maneuvering tight - like parking?
Dealer Service Recommendation
1 Lucky Texan replied to cplourde's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso....what's the first year of the 'good' CVTs?
1998 Forester won't run suddenly
1 Lucky Texan replied to lichen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX440, very possible hole in fuel filler pipe (behind the plastic) or destroyed seal on gas cap on a '98, you can probably ignore the 136 for now (post cat o2 sensor) 1510/16 point to IACV, some folks have had luck cleaning it - some needed to clean it again, others have found bad wiring/connectoer - some need to replace it. 106, intake manifold pressure - saw one post that indicated a small vacuum line was loose? If you have a smartphone, Torqu app and a cheap bluetooth adapter can get you live data - check amazon for bafx or veepeak ELM327 BT adapter
1 Lucky Texan replied to alexbuoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook for wetness/fuel in the vacuum line from the FPR. sometimes the diaphragm leaks. does your scanner get fuel trims?
Noob mistake - Dropped seafoam hook guide into Throttle assembly
1 Lucky Texan replied to iceburg501's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd def. try horsehockey's idea like this; pull the 4 plugs, rig a way to keep the vacuum hose in place and rotate the crank pulley around with a wrench - that should present a chance for air to flow backwards thru each intake runner in case that part got down that far.
In need of advise
maybe look up - frankenmotor ;
1 Lucky Texan replied to iceburg501's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrotate crank to open intake on cyl 1, take out spark plug, attach compressor hose, blow the plastic backwards out the the way it went in?
1 Lucky Texan replied to cplourde's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, many dealerships will try to brow-beat owners into an 'accelerated' maintenance schedule. They just do it for $$$ reasons. Insist on following the schedule in the manual (which, you can have done by anyone, including yourself or independent shop) UNLESS the car actually is used in an 'extreme duty' manner.
In need of advise
generally, swaps are doable but are EXTREMELY involved. you can, however, make changes to the suspension and braking of your current car that will make it more fun to throw around the corners. Refresh the struts, heavier rear sway bar or even stiffer springs, sportier exhaust, lighter weight rims...
1st time owner, was given a 94 Loyale Wagon.
cool!, there's a way to get a blink code from the computer, might yield some clues as to what's wrong with it. http://www.troublecodes.net/subaru/
