105
even if the HGs are intact, they may have been stressed and lube may also have been stressed - risk of rod bearing going out early. you like to believe in most crashes, the engine is shut off quickly, but sometimes the car is on it's side or something....oil won't pump correctly if that happens. it's all in the details - you need to get it cheap enough that dropping in a used engine is figured into the cost. others here have MUCH more experience than I do so, just relaying info I've read.
most WRX SPORTWAGON suspension parts should fit - maybe not sedan parts due to different track width. I know anti roll bars are different. maybe axles.... dunno about control arms.... most parts places should do well if you include the VIN, there is always confusion due to the word 'outback' - your car shares very little with the Subaru Outback (Legacy-based) cars.
I recall some older Chrysler or maybe Mitsubishi-Chrysler imports ? using ATF in their manuals so, not surprising. The reason Subarus can be picky about the man trans lube is, they share a case with the front diff - so a compromise must be made to protect/lube both components. it really isn't so tricky if OEM fluid is used or fluids as suggested by the manual. Some synthetics are problematic because the synchros don't decelerate enough. LOTS of reading here about experiments with different fluids and fluid 'cocktails' if you need some help sleeping lol!; (might also be useful to 'search' that thread to find info about specific brands) https://forums.nasioc.com/forums/showthread.php?t=920674
we have 2-3 instances every winter that get below 25* or so for 2-3 mornings (as a kid, we called them 'blue northers' - a term that seems to confuse youngsters lol!), sometimes the upper teens. Doesn't stay really cold for more than a few days, but my car sits outside, no issues on cold mornings. It may feel just slightly 'sluggish' for a block or 2, but it shifts fine. Even typical 'balkiness' going into first when rolling feels about the same. Coldest morning I recall was around 13*F, slow to crank but shifting and even my StopTech brake pads were fine from first use. maybe you have some shifter bushings going bad? - not sure why the temperature would affect those severely....
first, consider a new thread asking for a shop recomendation near you. Someone may know of a soob-friendly mechanic. Is there a DTC after this happens? Even with no CEL, there could be a pending code. Have the computer scanned and post any codes here. If the car has a MAF sensor, those sometimes have an intermittent failure inside. Also, a common failure point is old knock sensors, they can kill power and might not cause a check engine light. It's one area where cheap ebay sensors work for most people. Not hard to swap either if you want to just try something. Any oil on the plug wire boots? leaking valve cover gaskets might put oil on the plugs causing missing. Old wires sometimes arc in moist/rainy weather too.
no question GD's recommendation would be a no brainer. I have also read the Walmart synthetic BLEND stuff is good - also cheap. I had to have my trans rebuilt when it ate 2nd gear. Local tuner guys put amsoil severe gear in it - seems OK. In the past, Redline Lightweight Shockproof worked well. many people swear by the Motul GD mentioned, $$$ many people report the synchros don't like most full synthetic lubes.
