Everything posted by Bobby_boucher
weber carb return line
i just capped the return and everything seems to be fine.
Teaser..
I beleive SJR could copy the design, if i remember right he casts him lift parts?
Teaser..
NICE!!!!!! even if you can get ahold of one i know somone out there will be able to copy the design!!!
Recalls?
2wd? 4wd? carbed? fi? if fuel injected what type?
How would you build the perfect sleeper?
Mine would have to be my 1974 Ford Pinto Runabout with a 2.3 Turbo coup drive train leave the paint in all 4 colors and leave the rear end jacked up like it is. Gut the interior and replace exploding fuel tank with fuel cell. I've seen 1 in my whole life and it ran 11.98 but if i had a little more money i would take the mustange 302 HO drive train only other problem besides money is keeping the front wheels on the ground.
What Jets????
What Jets are people running in there webers????
Jetting for a Weber
What Jets are you running in your Weber???
ok... i've exhausted the search button...(prob. solved)
axles are easy first on the front there will be a roller pin on the inside next to the tranny...knock that out and romove it from the splines. then remove the cotter pin and castle nut from the hub. then use a "gentle adjustment tool" a.k.a BFH and beat it from the outside in. Rears are 2 count'em 2 roller pins...first knock out the inside roller pin and remove that side from the splines then remove the outside roll pin and remove it from the splines....Remember take the inside off first or your going to have a hellava time getting the outside one off and you will probably have to remove lower control arm and such.....OOO and roll pins only go in 1 way.
85 EA 82 Oil pressure drops during driving
I'd start with the oil pump. Reletivly inexpensive at schucks i think its 37 bucks.
Oil Change?
Then Only thing i can say is NEVER USE PENZOIL If you go to long it will gunk stuff up horribly it my opion it sucks. Back in the good old days they had great oil but now its just crap.
The Skidplate Cometh
Bad Ace, i have some stainless to weld a little cup over the sending unit and it would be gravy!!!! NIce Pics.
85 Carbed EA82 Wagon Cranks but wont Start
Pull the plugs and make sure they arnt fouled. then clean them and retry. if no go check spark.
security questions....ideas
I Used the face off of an original stereo off of a 1970 cutlass and resesed the cd player and the original face plate just flips down and the cd player is right there. but you can also rig some stuff up to do damage to the person breaking into the car. But you have to remeber its there so you dont hurt yourself.
HELP new noise i cant find
Throw out bearing??? Just guessing here.
anyone up for a Seattle meet tommorrow?
I think when i come over to seattle i'll be having some beths for the first time.
attn Pac NW: Chaplin's Subaru Entry Level Job Opening
Dang it i wish i could take the job. I hate my current job and a dealership would be perfect..especially a suby dealership!!!!! I've been a service writer for a year and a half now.
More SPoKane Off Road fun!!
Spokane is just as close as seattle for me just let me know some dates and ill try and make it out.
Suberdave's got me thinking again, and thats not good for my wallet.
Xoomer arnt you suposed to be leaving for colorado here pretty quick??? i thought you had to be down there by the end of the month?
Dante's Contact Info....
Does anyone have Dante's emai addy or any way of cantacting him???
AA stuff+Liberators=issues
A wider rim with better back spacing would be SWEEEEEET:banana:
Questions Regarding '84 GL Clutch Replacement
Are you the one that was trying to sell the wagon on Craigslist???
Leaky rear diff cover gasket, '97 impreza
Bobby_boucher replied to shannon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there an actual gasket???? usually rear diff. are just sealed with gray rvt.
fuel injection manifold EA81
What all does that swap include??? I want Fuel Injection In my hatch but bratrus says id have to go with an ej series.
Official Lift Kit Group Buy
Thanks James i appriciate the quick response and i also appriciate the way you are doing business. i will be sure to purchase items from you in the future.
Cant leave 4WD!!!!!!! HELP
have you tried slowly rolling forward and gently pushing it down? or slowly backward and doing the same?
