Everything posted by bratsrus1
difference in flywheels
Hey Brian This is Jerry, no you don't need a different flywheel. You have the 8 and 7/8 flywheel and thats the flywheel you use on this change over. Everything is cool i have it handled, i have the other clutch disc that you need for the 5 speed already for you. Thanks Jerry
Back to the land of carburators!
Hey Caboobaroo This is Jerry, instead of the 4 speed install the 5 speed dual range tranny it's alot better tranny and alot more fun to drive. After all you are doing all this work just go another step install the 5 speed you will love it. Thanks Jerry
I can't believe this-- beware 56k carnage enclosed
Hi This is Jerry, your car is worth at leats 2 grand pluse your old car. If they don't let you have your old car with the 2 grand then tell them it will be 3 grand also tell the insurance adjuster that you have time how about you that really puts them in a bind. Because the insurance wants to close as soon as posable it cost then less money. This is exactly what happen to my brat about 3 years ago. It took about 5 or 6 months to get my money for my brat. I am still looking for a blue 86 brat that is in A 1 shape haven't found one yet. I also held out for 5 grand and got to keep my old brat. On the medical side of this accident hold out for at least 1 year that way you will find out if any thing is from this accident. Wow this is a flash back on my brat just makes me cry i mis my brat. Thanks Jerry
Headlight trouble ... **UP DATE** FIXED!! DAMN HELLA!!
Hey Dayn This is Jerry, on your brat there is 2 relays one for each side. The relays are located by the fuse box and they are round and silver in color. most likey with your 100w lights you melted the relay shut and that is why your lights don't turn off. I have alot of spares if you need any just let me know. Thanks Jerry
clutch component question
Hey capn_r This is Jerry, just get a complete set up for a 84 wagon or brat from 84-87 it is a bolt on set up. The EA82 pressure plate to fit on the EA81 flywheel you will have to machine off .090 from the front of the flywheel. The Ea81 flywheel is taller then the EA82 flywheel i know i have done this set up before. The EA82 flywheel has bigger bolt holes in it than the EA81 has. Thanks Jerry
Did some wrenching on the BRAT today Pic added
Hi Tom This is Jerry, forget the rear drums do a swap over to the rear disc. Alot better brakes and no adjustments just bolt them on and get the air out off the system done deal. I don't run any of my EA81 cars without rear disc. Thanks Jerry
Hatchback rear brake conversion
Hey Fullmoon This is Jerry, no you don't need to change that valve. I am the first person that done this swap over that i know of. It is very simple mod to do. Just unbolt the rear brakes and bolt the rear disc on and blead the brakes your done. Thanks Jerry
Mark your calendars: SubieFest 06
Hi Everybody This is jerry, i just printed off a copy to put inside of my tool box at work to remind me and everybody at work i will be at this show. Also to remind my coworkers that have those jeeps subarus are cool too we have are own show la tee dah. As you can tell by reading this i raz those jeepers just like they raz me. Thanks Jerry
what do you like about your suby?
Hey Buddy This is Jerry, a cool rig to drive and i can do alot of swapping of parts. Cheap on gas and you have 4x4 wow when you go to the gas station to fill up 16 - 18 dollars and look over to that big honken pickup 100 dollars or more. I have better things to spend my money on that just gas to haul my but around remember i drive 500 miles a week just to work and back. Then when you do these mods to a subaru and everybody sees it you get 1 of 2 looks it is what the heck or thats really cool. Now you know Thanks Jerry
Gasket Sealer Q's...
Hey Brian This is Jerry, pm me with your address i have some gasket sealer that is really good stuff. I work on CASE backhoes and this stuff is made for case. It really works i use it on water on gas on oil on deisel on hyd oil heck on everything. This stuff works good- do not use on head gaskets but everything else. Also use it on the crank case when you put it back together it won't leak. Thanks Jerry
4 x 140 PCD to 4 x 114 - :( help!
Hi Chris This is jerry, yes that is what i did but i move the holes closer to the inside of the rotor mount. There is more room between the bolt holes. I had to mill some of the rotor stand on the back side to get the holes ferther apart. I also cut down the outside diameter of the hub to lighten it up. I drive my hatchback hard in the corners lots of times. I have about 12,000 miles on them and i haven't broke anything yet. Thanks Jerry
crap.. some help please...
Hey Scrap This is Jerry, you say it runs fine when it is cold then as it warms up then starts to run like crap. You have a vacum leak, the reason it runs fine cold is because the choke is on. The car runs richer as it warms up it runs leaner runs like crap. Check the vacum hoses for one that you left off or has a crack in it or you got 2 or more hoses mix up. It also could be your carb at the throtle shalf, when you clean all the gunk off of it you open the hole up a vacum leak. Check the shalf see if it has a lot of play in it. Thanks Jerry
Hi Chris This is Jerry, the bolt patteren i am running is 4 on 4 1/2 inch is the same as toyota car. The bolt patteren is off set slightly. The bolt patteren that you want to run is to small 4 on 100mm is to close to the center of the hub. Thats why i chose toyota and there is all kinds of those wheels. Thanks Jerry
Hey Vortex This is Jerry, no it's not hard to put new holes in these hubs. You don't have to weld up the old holes. You need to get a rear stub shalf with the bearings and spacer and a set up for the front also. Bolt the hub on the stub shalf and chuck it in the lathe. Machine the front of the hub and mark the bolt circle with the cutter tool then center punch your bolt circle and drill holes. On the back side chuck the hub in the milling machine and mill the bolt holes flat. Pound the studs back in the hub X by 4 then your done. Thanks Jerry
Hi Chris This is Jerry, i have done 2 sets of 4 lug hubs. I didn't weld up the holes i just machined 4 new holes and turn down the hub so it wasn't so big. I have a set of hubs on my 86 hatchback that has a bolt circle of 4 on 4 and 1 half inch that is toyota car. The next set i will be doing is 4 on 4 and three quarter inch bolt pattern, i have a set of mag wheels with that bolt pattern. The hubs are cast steel i have welded on a set before and i have turn a set of hubs down in the lathe they are cast steel cast iron machines alot different and also welds didderent. I have alot of time in my hubs but not much money in them. Thanks Jerry
Heater control valve -Brat
Hey Andy This is Jerry, i have a 84 turob wagon sitting in my yard we can rob it if you need some parts. I also have a new heater core still in the box if you need it make me some knid of a deal on it. Let me know Thanks Jerry
should i or should i not
Hey Buddy This is Jerry, at my job everybody has a jeep poor suckers. I get put down just about everyday but now that winter is here it is a different story. On these slick roads my hatchback runs circles around them, all i say to them look who has the better car now. My hatchback gets over double the gas mileage than those jeeps like the word stands for just emptey every pocket of all your money. This has been on going for over 5 years now for me but now i have a coworker in a 80 brat won't be long before another coworker is in a subaru. Trade not a chance Thanks Jerry
measure your drive shaft
Hey brat This is Jerry, just bring your old drive shalf to a drive line shop and tell them you want 51 inches of new tubing install in it and have it balance. Problem solved. For the brats and wagons the lenght is 51 inches and the hatchback is 48 inches of new tubing. Thanks Jerry
Valve spring removal
Hey Gary This is jerry, if you use that tool make sure that the piston is at the top of the cylinder. If you don't and the valve drops into the cylinder how do you get it back into the valve guide magic. Thanks Jerry
Exide Maxxima Batteries
Hi This is Jerry, i have 2 of them. The first one i bought about 4 years ago that is in my hatch and the other one about 2 years ago it is in my hatchbrat. I haven't had any problems good battery and also mine haven't had any build up on the post. Thanks Jerry
Clutch Problem
Hey Fluid This is Jerry, i had a 78 brat that did the same thing. Well to get it unstuck you need to jack up the front end of the car just so the front wheels are off the ground. Then you need a rod about 3 feet long. Start the car in gear with the clutch pedal push in to the floor. Then rev the engine to about 2 grand with the rod, with your right foot dinamite the brakes. It will brake loose the clutch i had to do it 4 times before the clutch broke loose but after i did it everything was ok ready to drive. OH BTW make sure there is nothing in front of your car because if it falls off of the jack you won't run over anything. Thanks Jerry
Extended steering shaft length.
Hey Single This is Jerry, cut your shaft in half then get some tubing heavy wall that will fit over the shaft. Slide the tubing over 1 part of the shaft and install the parts on the car. Slide the tubing over the steering shafts and center the tubing. Spot weld it in place then remove it and weld it up and reinstall it. Done deal Thanks Jerry
aftermarket shifters for 5 speed?
Hey Guys This is Jerry, i have a B&M T shifter handle on my hatch chrome looks really great old school. The T handle has half inch fine threads in it they are close to the 12 mm x 1.25 and i use maxuiam strenght locktite on the threads let it set for 8 hours then you are good to go. Shift away hasn't come loose yet in 6 months. When people my age look at my hatch they say was this car built in the 60s and i tell them no i was. Thanks Jerry
Howdy.....
Hey Stumpy This is Jerry, i don't know how to do that on the computer. If you pm me with your address i can mail them to you. Thanks Jerry
Howdy.....
Hey Stumpy This is Jerry, my neighbor is building a subaru trike. He got a gold wing front end with the frame and stub it on the rear of a EA81. He has a EA81 engine with the 4x4 auto and has it in 4 wheel drive. The drive line is the front yoke and rear flange with one u joint. My neighbor is missing his left leg thats why he has the auto tranny. If you want pictures i can mail them to you let me know. Thanks Jerry
