April 6, 201015 yr I recently bought a 1992 Loyale wagon. I have also purchased a 4" lift from SJR Lifts and was wondering if anyone has some pics of how they extended they're steering. I hope to be putting the lift kit on in a couple of weeks.
April 6, 201015 yr I have no pics of it, but just unbolt the steering knuckle near the firewall, cut it in half, and weld it with pipe to fit. Be sure to use mild, low-carbon steel, and weld 'er up very well!!!
April 6, 201015 yr Author Thanks for the help. That gives me a better thought on how it is to be done.
April 6, 201015 yr literally cut it in half.insert it into the size of tubing appropriate(however big your lift is)in your case ,4"......then weld up.if the cuts are square on your tubing, it should come out fairly square all around, it is ok if the tubing is a little bigger than the shaft, as it will rest up against the base of the joints........my first one i used a tie rod tensioner from a 1950's ford...... cheers, brian
April 6, 201015 yr It can help to drill holes in the tubing on the ends where the shaft will be inserted and plug-weld through the holes to the shaft. This will give it more strength. Some folks have had steering linkages break after extending them so as mentioned be careful about how you weld it - strength before beauty in this case . GD
April 6, 201015 yr if you use the proper equipment, and materials, there is no need to plug weld anything.if your arms, and hydraulic assist can tear the linkage after it being done properly, you have way bigger issues to address .....
April 6, 201015 yr Make sure you have both pieces of this cut shaft in the car, and tack it in there. As it won't need to be exactly 4" longer (in my experience).
April 7, 201015 yr If you can find both a ps and a non ps linkage, you can combine them for a weld free extension
April 7, 201015 yr if you use the proper equipment, and materials, there is no need to plug weld anything. True - but there's a lot of people with 110v welder's and flux-core out there as well as no knowledge on how to properly prep and weld such a joint. Not knowing how he's going about it I figured it can't hurt to have him over-do it a bit. GD
April 7, 201015 yr everything you see in my build thread is done with a 110 v welder with .035 flux core.......... no root passes........so whatever....cheers, brain
April 7, 201015 yr And you know how to weld and what makes a decent looking weld vs. a pile of slag-included crap. Not everyone that is just starting out with that setup does - it's the most common home shop setup but a lot of folks that buy them have no real experience with welding. I know I didn't when I got my first welder. Luckily I've never had any of my welds break and cause and accident, but looking back on some of the stuff I did with that harbor frieght 110v..... I just got lucky. That and for the things I thought were important I had a friend with a 220v gas setup weld them for me. It has been my experience that it takes more skill to run a 110v flux machine than a larger gas equipped unit. Just because of the low power and the potential for slag inclusion on the welds. GD
April 7, 201015 yr you could cut in half, mill down ends of both pieces on a lathe to match the ID of a tube of similar diameter, press fit in, and then weld.
April 8, 201015 yr And you know how to weld and what makes a decent looking weld vs. a pile of slag-included crap. Not everyone that is just starting out with that setup does - it's the most common home shop setup but a lot of folks that buy them have no real experience with welding. I know I didn't when I got my first welder. Luckily I've never had any of my welds break and cause and accident, but looking back on some of the stuff I did with that harbor frieght 110v..... I just got lucky. That and for the things I thought were important I had a friend with a 220v gas setup weld them for me. It has been my experience that it takes more skill to run a 110v flux machine than a larger gas equipped unit. Just because of the low power and the potential for slag inclusion on the welds. GD somewhere in there is a compliment.i just know it........:grin:back to the subject at hand... i guess stating that one who knows HOW to weld, would have the ability to do it with a 110 welder.hopefully the original poster got what he needed before we stated bantering back and forth..... cheers,brian
April 8, 201015 yr literally cut it in half.insert it into the size of tubing appropriate(however big your lift is)in your case ,4"......then weld up.if the cuts are square on your tubing, it should come out fairly square all around, it is ok if the tubing is a little bigger than the shaft, as it will rest up against the base of the joints........my first one i used a tie rod tensioner from a 1950's ford...... cheers, brian sorry to correct you but the steering shaft is at a slope so its not as long as the lift, also on the 4" SJR lift the engine block is 3" tall , dont remember length but its extended less then 3" , also the swaybar shaft is a good size to use for the extension shaft material
April 8, 201015 yr sorry to correct you but the steering shaft is at a slope so its not as long as the lift, also on the 4" SJR lift the engine block is 3" tall , dont remember length but its extended less then 3" , also the swaybar shaft is a good size to use for the extension shaft material Hi Scott, I was thinking just the opposite, but after drawing a quick sketch myself, I see you are right. I tried to delete this comment, but it looks like I can only edit it. Edited April 8, 201015 yr by Rollie715
April 8, 201015 yr sorry to correct you but the steering shaft is at a slope so its not as long as the lift, also on the 4" SJR lift the engine block is 3" tall , dont remember length but its extended less then 3" , also the swaybar shaft is a good size to use for the extension shaft material well ,i am pretty sure that each case will be different(per lift manufacture)....regardless....i (three times now) have done just what i stated above... i have also gathered several steering shafts at the yard, and conglomerated them together....for the 6 inch lift i had on lilly. cheers, brian
October 5, 201015 yr [ATTACH]8096[/ATTACH] sorry to correct you but the steering shaft is at a slope so its not as long as the lift, also on the 4" SJR lift the engine block is 3" tall , dont remember length but its extended less then 3" , also the swaybar shaft is a good size to use for the extension shaft material haha. Sorry to correct you, Scott, but you mean it's longer than the lift (3") at that point, right? (a^2)+(b^2)=(c^2) where c is the linkage length, a is the horizontal measurement and b is the vertical rise. [ATTACH]8095[/ATTACH] so with the 3 inch lift at the engine crossmember the equasion for the length would be: c = [(a^2)+(b^2)+6b+9]^(1/2) anybody have a graphing calculator and tape measure? Make sure a and b are in inches. Or you could just measure, cut and weld... but I like to calculate... (nerd) Edited October 5, 201015 yr by kanurys
October 5, 201015 yr [ATTACH]8096[/ATTACH] Sorry to correct you, Scott, but you mean it's longer than the lift (3") at that point, right? No I ment what I said, from experience
October 5, 201015 yr I don't doubt your experience. I think we're talking about two slightly different things. Anyways, you're right that the amount you add to the the shaft is slightly less than 3 inches. I was saying that the total length (your original statement) is longer that 3". Just a simple miscommunication. None the less, the numbers and equation still hold true. I'm just about ready to do mine... just waiting for the mail
October 8, 201015 yr The angle is not in only one dimension. If you make the length of the steering rack one axis, and have another axis to be level with the length of the car, you'll see that it may indeed be shorter because it is pointing, in one axis, towards the firewall.
October 8, 201015 yr Axis and FORMULAS? Heck, I was just giong to cut mine in half stick in a solid rod bolt it back on, tack on some welds, pull it off and weld it solid. Looks like I'm gona have to get the wifes sister to run some calculations for me.
October 9, 201015 yr Axis and FORMULAS? Heck, I was just giong to cut mine in half stick in a solid rod bolt it back on, tack on some welds, pull it off and weld it solid. Looks like I'm gona have to get the wifes sister to run some calculations for me. Internet land is funny like that. Nothing beats trimming and fitting!
October 9, 201015 yr Axis and FORMULAS? Heck, I was just giong to cut mine in half stick in a solid rod bolt it back on, tack on some welds, pull it off and weld it solid. Looks like I'm gona have to get the wifes sister to run some calculations for me. Bingo
October 9, 201015 yr That's probably what I'll end up doing, too. But I'll also measure to see how close my calcs are - just for fun.
