My '95 Legacy: Trashwagon10
I don't think the rear got the wood trim. I really don't think my limited has it, although, I never ride in the back seat and haven't seen the car for a while.
Yes, Limited and GT have the wood trim on all four doors along with center console.
I should know, I have all but one piece.
  • Replies 1.3k
  • Views 204.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • TheLoyale
    TheLoyale
    Trashwagon will be making a return real soon!    I built a car created by MilesFox, only to sell it to him and then to get it back.
  • TheLoyale
    TheLoyale
    Trashwagon10 makes a triumphant return to MilesFox! We rescued the car yesterday from a kid who bought it in need of a car to get him to/from school. The outer bearing cage on the passenger side axle
  • TheLoyale
    TheLoyale
    We are The Subaru Alliance!  ____________
Posted Images
Hmm, interesting. Maybe someone messed with the rear doors in my car at some point. Or maybe I just don't remember it has the wood trim... The car is 1100 miles away with a seized engine.
For those of you running high-milage EJs, check the two coolant lines that run to the IAC. One of mine had a cut all the way down to the cords and didn't leak, best to replace them when you have the IAC off for servicing.
Hose diameter is 5/16" Fuel line.
XT6 anyone? Boiling water + ABS plastic = :Flame:
Why did you ruin it!?
In the name of Abstract Art.
Should have reset the trip counter 222.2 miles ago. :D
I see your 222,222 and raise you 12,345
I see your 1,767 Post count and raise you 2,233! :clap:
4,000 posts biotch! ;)
I've always wondered how post counts like that are even possible. . . . :clap:
but well done, however it's done ;)
Edited by superu
you have to post 2.31 times per day.
  • Posts Per Day: 2.31
My post count of 8,000 is low for how long i have been here.
  • Posts Per Day: 2.11
Yup, that's a lot a postin'! nice work!
checkit!
MY post count is LOW for how long I've been here... @ .24/day ;)
Two large Build Threads will increase your post count.
Safariwagon Restoration and Trashwagon10 are probably the largest and longest running build threads on the USMB.
Just scored a like new Outback skid plate from a '98 Outback which was involved in a flood.
For those that are interested,
Any EA82 skid plate will indeed bolt right up to the EJ chassis. I also want to say that the EA81 plates will bolt up as well (Might be a little shorter?)
So seeing that your post count is just 5 now, what two cars are you going to build up next? :D
That's interesting news! Do you happen to have a picture?
i thought you had to slightly modify the holes in the skid plate no?
so they couldnt fix your old screenname? thats a bummer. :confused:
here is how it looks on a 05 Impreza wagon. now i remember. Steve had to drill holes in that sub frame to mount it to. thats what it was.
Edited by xbeerd
So, where is tom this is his thread?
Having taken a closer look at both plates today, Scott, that is correct. But with the '90-'99 Legacy/Outback, there is no removable sub-frame like Steve's Imp. There are holes on the bottom of the rad support on my generation.
Indeed, you would need to drill two new holes for the front of the plate. Still simple and well worth it.
Now comes another issue, If you are running an UEL header, you will need to space down the plate so far that it is pointless. Suppose I could notch a section of the plate off to compensate the header.
yeah, i knew there wasnt a subframe on the leg's, just was showing what it might look like as an example, definately a simple reacharound to get the EA plate on it.
i second that on the UEL header skid plate spacing. especially if you dropped your engine cross member with a lift. i had to extend the front bolts like 2", as well as add a 3" block in the back of it to clear on my loyale (i know not a legacy but same general idea). might as well just make a custom plate. LOL!
