I went to see a Subie specialist about an engine noise and while I was there, he noticed my rack leaking (dripping on my downpipe and burning). I acknowledged that I'd be replacing it soon (its not that bad at all). He said he could fix it for $6.00 - or I could do it myself. Of course my ears perked up.
He suggested I add brake fluid next time I need to fill my PS reservoir. I acted surprised and receptive, but deep down, thought the guy was INSANE. He says the [caustic] brake fluid will soften the seals and swell them up - hence stopping the leak. He claims he had a Legacy that went from leaking 1qt a week, to not leaking a drop ...and he's seen this add 5yrs to the life of the rack. Keep in mind - I live in the heart of Appalachia.
My wallet says "yes" - my brain says "no" ...thoughts?
WOW!! Thanks for the responses!
Yeah, I was determined to replace the rack anyway because the inners are starting to go on this one. A new reman rack at autozone is $230. The leak is coming from the upper o-ring where the steer shaft goes into the box. I figure new inners and a non-leaky rack is worth it - no?
Here's another thought. I have this "engine pull" thread going now too because of my flexplate. If I do the rack at the same time, is it easier to get to my flexplate by dropping the tranny rather than pulling the motor? The rack has to come out for that - right?
no.
no.
and no.
the engine is always easier. if you are going to do the rack, do it with the engine out. it's easy to get the steering wheel and wheels straight then.
a used rack is a good choice, 60$ instead of 260$. they do not fail often.
http://www.car-part.com
i have seen many so called "Subaru experts" and have has private msgs, and as soon as they say they are an expert, i tell them to run the other direction.
This guy is nuts. Steering is as importatn as brakes (wonder if he ever pyts P/S fluid in the brakes to stop the fluid from absorbing water - same logic - none).
Just replace the rack.
nipper
Just in case I ever need to do it, what do you mean by «inners»?
you have an inner tie rod and outter tie rod end. the inner tie rod screws fast to the main part of the rack and is half covered with the black boot. then the outter screws fast to the inner and locked fast with a jam nut. they are very simple to change and cost a lot less than a rebuilt rack. if the rack isn't binding or leaking from internal seals no sense in replacing it. the only fluids you can mix is trans fluid in the ps. never mix any other fluids thoe.
Edited by rtcaravan
nipper
this was my original logic - we're on the same page. I'm pulling the motor next week to replace the flexplate - planning on doing the rack at the same time.
Thanks for the confirmation :thumbsup:
