Introducing the Subercoupe Now with 50% more cyl’s and 100% more RWD!
I want to see the video of the officer asking why there's an engine in your back seat.
  • Replies 86
  • Views 30.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Took the Subercoupe for its maiden voyage today...
went about 15 miles. car ran awesome. needs an alignment very bad. ill take it to work tomorrow and do that.
currently working on the trans and clutch issue. hope to have that done before WCSS...
ill try to get some more pics tomorrow when i have it on a lift.
-=Suberdave=-
Very kindly let me ask you this questions about the engine inside the Cabin:
► How hot will become the Cabin during Normal Driving?
► Does it blows odors / fumes to the Cabin?
► Do you plan to isolate the Engine's heat & gasses?
I ask because it Could be Dangerous to Drive with the Windows up (in example during Rainstorms).
All those issues could be solved, also I know it is not built to be a daily driver; but I am curious about the Overall car Behaviour and I have some ideas that could Help you to solve the above listed situations. :D
Kind Regards.
Yeah Jezsek, I think he mentioned he'll be working on a firewall in the back. But for now, just run without the hatch. :D
it has a firewall between the cabin and the engine. it has a plexie glass window in the top half so i can see out the back.
in the back on each side of the licence plate i have a 175CFM fan. they both turn on when the engine temp gets to 80*C or if the engine room temp gets to 40*C...
i am currently installing a 2005 WRX transmission and a stage II Exedy clutch.
-=Suberdave=-
-=Suberdave=-
Nice! How are you handling the transfer case? Just weld the center diff?
in the back on each side of the licence plate i have a 175CFM fan. they both turn on when the engine temp gets to 80*C or if the engine room temp gets to 40*C ...
Thank you for the Kind Answer! :)
I Believe it is a Really Good Idea to have automatic electric fans there, also the Plexi Glass... so you already controled the situation.
I was thinking about to install there some heat & Noise isolating barrier,
Like this ~► http://www.soundproofingamerica.com/ECHOLESS-ROLL-MAT.pdf
Because I used a very similar product in a VolksWagen Bus, long years ago, with great results.
I Really Like your Nice & Powerful coupe, almost can't wait to see it on a Video. :burnout:
Kind Regards.
got the new trans and clutch in tonight.
still have to put the suspension back together and a few bolts up top.
but its after midnight and i have to get up at 5:30am so id better get to bed...
-=Suberdave=-
P.S. ill get some more photos and even a video this Saturday or Sunday.
Nice! Very short vid, but plenty effin loud! It's weird to hear a sooby boxer motor with forced induction, and hear it rev and let off WITHOUT hearing a massive woosh from the BOV. :D
That thing is Killer Dave!
While watching the video all I could do was smile and think to myself holy crap!
I agree, awesome, more finished than I was guessing
:clap:
Awesome!
I Watched your video on a large widescreen via a game console XBox 360, and I was stunned, your Subercoupe is truly impressive, very well done and the rear engine is a very clean installation. icon14.gif
I Believe that this Thread should be Moved to the "Members Rides" Section.
Best regards and congratulations.
Thanks for this dave,it proves that what I am thinking of doing is actually doable,it will be very very similair EXCEPT the shell will be my brumby and the engine maybe a EZ30r :) oh and maybe no super charger for starters :)
So happy I got to see this thing in person, absolutely amazing! So well done.
Wish I could have seen it in action!
well took the Subercoupe to the WCSS this last weekend.
220 miles round trip.
Overall about 6 hours of run time on the engine.
Used 11.25 gallons of gas.
That's 19.5 MPG... not bad, since it has not been totally tuned yet.
Took home plaque for best Old School Engine Swap. witch i have won 3 out of the last 4 years with my wagon.
Did the whole trip without any issues, other than my but was kinds sore. i guess race seats are not meant to be sat in for hours on end...
-=Suberdave=-
Good to hear it made such a trip without incident. Got any more videos? Preferably a burnout or launch? :D
Great to hear it's holding up well. It would still be awesome if we could get a more detailed mod list! If you don't mind....
not much for mods...
Built by Suberdave
Tuned by
The Dyno Station at Drift Office
1987 GL Coupe
Engine: 1994 SVX EG33 (from junk yard, 100% stock)
Custom Made Intake Manifold
Supercharger: Eaton M90
Soon to be 2.7" pulley
ECU: Link G4 Extreme
Wheels: 2002 WRX
Front brakes: 2005 WRX front brakes
Rear brakes: 2002 WRX front brakes
Brake Lines: SS from Ebay
AWIC: Just-Intercoolers kit
Exhaust: DynoMax muffler and a lot of 2.5" mandrel bent pipe
Radiator: WRX (front mounted)
Radiator Hoses: 1.5" .062" thick aluminium pipe and lots of old Subaru hoses
Fuel System: STi Sidefeed 550cc
Pro Fuel Delivery 15G fuel cell
Mallory 110 GPH fuel pump
40 micron pre pump filter
100 micron post pump filter
-6 an fuel line
Transmission: 2005 WRX
Clutch: Exedy Stage II
(good to 400WTQ)
Custom 14 foot hydro clutch line
WRX pedal box
Axles: 2002 WRX front Axles in the rear
Center diff was pulled, cut and welded to run in FWD only
Custom built tail shaft block off plate
Seats: Ebay race buckets
Belts: are 5pt Gforce
Cage: BD Racing ( pre-bent for a 93-99 Impreza)
Firewall: Sheet metal and plexi-glass
Steering wheel and hub: Cheep Ebay
Tach: Autoguage 5"
Body kit: 1988 Subaru RX
Rear Wing: 1988 Subaru RX
Vent Fans: 120mm waterproof 175cfm fans (come on when engine bay gets to 105*F)
Engine is running full sequential fuel and spark. GM IAC and TPS, and AEM MAP but everything else is Subaru.
-=Suberdave=-
Front mounted radiator huh? The stock water pump doesn't have trouble pushing the water that far?
nope. i talked to some VW guys that put the EG into buses, they said they never use an extra pump.
the hottest it has gotten is 201*F and that was in stop and go traffic on a 85*F day. normally runs right at 194*F.
-=Suberdave=-
